Question about Frigidaire GLER642A Electric Dryer
Back of dryer gets extremly hot!!!
My frigidaire gallery dryer is electric have cleaned everything hose, vent etc.. our dryer gets extremely hot in the back !!
  • 181 Answers
Put hand at the outlet to see if the warm air is freely coming out. if not there could be a blockage in a pipe inside or the propler fan on the motor has failed.
Posted on May 13, 2009
Rattle vibration
Dryers do what they are designed to do, Dry things. In the process everything inside the drying cylinder makes dust and airborne particulates called Lint. The Biggest bane for dryers is Lint accumulation. Clean the Lint filter screen. If it detaches from the dryer housing with screws remove them. Clean out what you see if you have a wet vacuum with a small hose carefully push this down into the opening and vacuum it ou. Another thing pull your dryer out from the wall disconnect the power and remove the vent hose. Vacuum inside the opening in the back of the dryer. You would be surprised how much lint accummulates here. Lastly check your vent hose for lint accumulation or blockage. If you find it blocked, disconnect the hose from the vent going outside and clean it all out with a vacuum . Put it all back together and run a load of clothes if you dont see a marked improvement in circulation and drying time, then either the blower fan is n't working properly or you have a burned out thermostat. If you have heat flowing turn it up to max heat and see how hot it really gets if on opening the dryer you feel extreme heat then it is either working right or the thermostat is not shutting off at the high limit. the Thermostat is a piece of Bimetallic metal that is extremely sensitive to certain temperatures. When they reach the preset heat limit they shut off allowing the heating elements not to burn out. A good investment is to keep dryer maintenance at regular intervals. They sell dryer cleaning brushes and Vacuum hose attachments for getting into the deep crevasses and nether regions of your dryer. Good luck and happy drying
Apr 06, 2014 | Roper Dryers
Dryer is extremely hot inside back of dryer, top of dryer back and the back of the unit
Hi laurie a pow...
Check and clean if necessary your vent hose.
If you vent hose "seems" to be clean then,try running the dryer with the vent hose off and see if the dryer is not running hot anymore.
Make sure your lint screen is in place and has no tears or holes in it and is still firmly attached to the frame.
If you are running too hot you are not moving enough air thru the system.
It could be that the fan blade is plugged up.
The problem could be a large lint ball build up in the center of the fan or a sock,thin pants,a pen,etc. that has gotten into the fan by falling down the hole where the lint screen is normally inserted.
You have to find the air restriction to solve the problem.
It also can be a loose or worn out blower wheel/fan.
Please take time to rate me.
Aug 22, 2011 | Kenmore 62872 Electric Dryer
My GE Electric dryer model DBXR463EB0WW takes 2-3 times as long to dry a normal load of clothes. I have cleaned the lint trap, etc. What could be the cause? Please advise. Thanks.
You could have several problems.
You could have a vent problem. usually when this occurs, the top of the dryer closest to the backsplash is extremely hot to the touch. check outside to make sure that your vent does not have an obstruction. also check behind the dryer to make sure the flex hose has not crimped or collapsed.
if everything is clear and clean with the vent and you still don't get much air flow out of the vent - your fan on the inside of the dryer could be blocked or bad. usually when the fan is bad you may hear somewhat of a growling sound near the front
if all this looks good then you probably have a bad heating element. if the dryer is heating some, you could have one of the two elements bad. replace both of them even if only one has failed. they make a re-string kit for these elements.
if the dryer is not heating at all then first check to make sure that you have 220volts coming to the dryer. your house breaker to the dryer could be half thrown allowing only 110vols to the dryer. this would let it run and not heat.
Aug 06, 2010 | GE DBSR453EBWW Electric Dryer
Frigidaire electric dryer; model # FDEB34RGS1- gets TOO hot!
I could not find the model number you listed. I also would be very concerned about over heating until we can find and locate the problem. Look inside the door and compare number with the on listed here at Fixya. Thanks, Sea Breeze
Mar 25, 2009 | Frigidaire FGR341AC Electric Dryer
Dryer turns on, gets hot, but knob does not move with timer.
could be your operating thermostat on your heater or your timer if it runs on timed dry but not auto dry then it is a thermostat issue if it just does not run at all then it is a timer issue also make sure your vent is clear check by removing vent hose from back of unit and running a load if it works properly clean your vent.
Feb 23, 2009 | Hotpoint NVL333EY Electric Dryer
Dryer gets hot to the touch
If you didn't install new venting I'd start by checking the vent hose from the back of the dryer to the outside vent hood to make sure there is no blocked airflow. Could be something else but that is where I'd look first. Good Luck.
Jan 15, 2009 | Frigidaire GLER331A Electric Dryer
Back & top of dryer get hot, clothes take long time to dry.
First thing to check for is blocked airflow. Check the dryer as well as the venting from the back of the dryer to the outside of the house good airflow is neccessary. You could remove the venting from the back of the dryer and run a load to see if that helps. Do not leave it off as it is exhausting lint and if a gas dryer spent fuel.
Jan 08, 2009 | Maytag MDE2600 Electric Dryer
Very hot to touch on top
Sounds like you have a clogged vent hose or clogged duct work leading to the outside of the home. Make sure you have no obstructions in the exhaust system including a functioning flap on the outside wall cap.
Jan 03, 2009 | Frigidaire GLER341A Electric Dryer
Overheating and Won't Start
Does your dryer run at all? If the drum turns, but the dryer does not heat, click on the follwing link for advice:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
Now, if your dryer does not run at all, you can use this link for more thorough information:
http://www.fixya.com/support/r385301-thorough_dryer_advice
I'm sure you've already made sure the dryer vents are clean, but if your dryer is running extremely hot like you mentioned, it usually means there is insufficient air flow. If you have ensured all the external duct work is clear, you may still have a clog INSIDE the dryer. In addition, if you are in the habit of pushing the dryer all the way up against the wall, you may be crushing the dryer vent hose to the point where it cannot push air. I mention most of this in these write ups. Please take the time to read through the information. If you have any questions, need help in diagnosing the problem, or assistance in locating parts, please let me know. I hope this helps you.
Jul 10, 2008 | Frigidaire FDE336RE Dryer
Dryer not drying
be sure vent to outside is not blocked or hose behind dryer flattened..quick ck is to dry a load with rear hose disconnected..if problem still there suspect heating element ..ge/hotpoint elements are double strung if 1 coil is open (burnt into) dryer will not get hot eneough
May 19, 2008 | Hotpoint NBXR463EBWW Electric Dryer
Frigidaire GLER642A Electric Dryer Logo
343 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
