Question about Cycling
Will not keep running
My 1981 honda atc 185 three wheeler will idel in full choke,but if you hit the gas or take it off choke it stalls out
  • 200 Answers
Hey pal! this is an easy one...i suspect your atv has been in storage without putting a gas stabilizer in the tank and running it thru carb...Well your carb has gummed up jets luckily on a little 185 that carb is easy to remove. Turn it upside down, remove 4 screws holding bowl on then above the float there is 1 or 2 brass hollow srews which are jets...find a skinny srewdriver that fits these perfectly cause they are Soft metal and will gouge easily....remove and clean very thoroughly...reinstall is opposite of removal....if your thinkin' this is too much 4 you then take it to a competent mech....Good Luck to you my friend....Tim
Posted on May 12, 2009
Where can i find a Honda repair manual for 185 ATC.
Contact Honda Guru eric the car guy who should be able to help with that. Just register on the forum and pose the question. They are good people there. Here is a link...
http://www.ericthecarguy.com/kunena/index
Feb 28, 2015 | Honda Cars & Trucks
1980 Honda GL 1100 Interstate Gold Wing only runs with choke on
Hi, Eric and the usual suspects are:
1. Fuel cap or fuel tank is not venting properly.
2. Fuel filter clogged.
3. Fuel line pinched or kinked.
4. Vacuum line from the petcock to intake manifold cracked.
5. Float needle and seat sticking.
6. Float level too low.
7. Carburetor bowl vent line clogged/blocked/pinched.
8. Idle adjusting screw set too low.
9. Air/fuel mixture screw set too lean.
10. Idle port, transfer ports, slow air jet clogged.
11. Slow fuel jet clogged.
12. Faulty fuel pump.
For more information about your issue and valuable "Free" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
wont stay running without full choke GL1100 Information Questions...
GL1100 wont start without full choke won idle
Honda GoldWing GL1100 Service Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda Goldwing GL1100 Interstate 1981 Owner Manual
Apr 16, 2013 | 1980 Honda GL 1100 Innerstate Gold Wing
Runs only with full choke
clean carb,then adjust, do not use low end gas,(to many contaminates.use carberator cleaner in gas(read instructions, small tank)
Aug 30, 2012 | 1985 Honda VT 500 C Shadow
Repair Manuals honda 3 wheeler ATC 185s 1983
we have a honda 185 3 wheeler but it has no spark. what is it?
Aug 27, 2010 | Sport & Outdoor - Others
I have a 1985 honda atc 125M it shuts off for no reason
Sometimes Honda ATC's wont idle if the exhaust valve is too tight. Check and clean the slow circuit of the carburetor this should fix the other part of the idling problem. A carb gasket set from Honda should have all the components you need to properly seal the carb. Lastly, buy a new carb float needle this should stop the dripping unless you have damaged the drain screw on the bottom of the bowl. This can only be purchased as part of the complete bowl assembly.If you still are having problems after this, try adding an additional fuel filter between the tank and fuel petcock, just in case tank rust is the cause of the needle sticking open and dripping.
Jun 10, 2010 | Honda Activa Motorcycles
I need to know what the valve settings are for a 1984 suzuki 185 atv!
General settings on Valves for scooters, atv's , and three wheelers are .002~.004 on intake and .003~.006 on exhaust side.
Aug 27, 2009 | 1981 Suzuki TS 185
In 4th and 5th gear at full rev seems like
If it is hard to start after it stalls, it is probably getting too much fuel. Could be dirt in the float valve. Also try running a hotter spark plug
Jun 17, 2009 | 2005 Honda CRF 450 X
Cycling Logo
278 people viewed this question
Top Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
