Question about Panasonic PT-53WX53 53" Rear Projection HDTV-Ready Television
There seems to be a green haze throughout my screen. I have adjusted it and readjusted over and over with no success...can u help me? What is the problem????
  • 261 Answers
I'll do my best!
Well there's a little test i need you to do, when you have that green haze on the screen selesct the menu guide and if it also shows the green haze you will need to replace the video board, and if you have na LCD tv, you will need to replace the optical block .
Posted on Jun 30, 2009
I have a Maxent TV ( MX-42XM11) The picture is always tinted too green. I tried adjusting the tint. No success. What should I do?
You will need to readjust the screen bias and drives. If you are not familiar with this procedure, refer to a qualified service technician.
May 04, 2015 | Televison & Video
Green Screen
put a fan behind it, if it works then its heat related if not then you probably need a new main board.
Aug 29, 2009 | Proscan PS52690 52" Rear Projection...
Blue haze on the lower part of rear Projection TV
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Mar 23, 2009 | Philips Magnavox 51MP392H Rear Projection...
Green Shade on tv screen
This is a typical example of a convergence amplifier failing (any brand would be the same).
More than likely there are 3 amps and they should all be replaced together. Parts shouldn't be too
expensive but I would expect approx $100 US in North America and about £100 UK. Bear in mind thats for the repair not any transportation costs to/from the repair centre.
Nov 11, 2008 | JVC AV-48WP30 48" Rear Projection...
Sony KP-51WS510 has a haze or back glow that cant be adjusted
It seems U are having no screen voltage.
U need to get it repaired
Rifaa
Nov 10, 2008 | Sony KP-51WS510 51" Rear Projection...
Pink haze top left hand corner of screen
loose integrator lens/ readjustment is possible, or the lcd for green is contaminated( red + blue mixed gives pink)
Jul 14, 2008 | Sanyo PLC XU35 Multimedia Projector
VT45 Projector: Blue pixels throughout screen
If the problem is what I describe as a blue haze over the entire image projected, I was told this is a defect in the cable - we have a Dell Video Projector 2300 - and it takes only a dell VGA cable.
So, the problem is in the cable - solution is replace cable.
Feb 28, 2007 | NEC VT45LPK Projector Lamp for VT45
SLIGHT GREEN TINT TO PICTURE
most atimes if i adjust the screen adjuster on the voltage multiplier i always observe that the screengoes green(lg 21" television),and if i readjust the screen,the greengoes off.Rubberhead,try adjusting the sceenknob on your voltage multiplier(line transformer).
Feb 26, 2007 | Sony FD Trinitron WEGA KD-36FS130 36" TV
Panasonic PT-53WX53 53" Rear Projection HDTV-Ready Television Logo
395 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
