Question about Yamaha HTR-5730 Receiver
My last Reciever, I had wireless speakers that worked by plugging into the headphone jack. When the wireless transmiter was plugged into the headphone jack I still had sound coming out of the main speakers. With the HTR-6140 as soon as I connect the headphone jack, it shuts off the main speakers. Any switch, button configuration I can use to achieve what I use to have? Thanks!
  • 4,234 Answers
Your system is designed to interrupt the signal flow once headphones are attached. It can not be changed without internal modifications. There is no control to do this.
Dan
Posted on May 13, 2009
The speakers no long produce sound after using the headphone jack,,disconnected jack , still no sound
When you plug in the headphones, the jack itself routes the signal away from the speakers. When you unplug the headphones, the jack has contacts that close again, routing signal to the speakers. If the jack contacts are dirty, they won't close correctly. I suspect were you to clean the contacts, you'd solve the problem.
Feb 25, 2015 | RCA Rt2760 Home Theater Receiver
My headset is not working
Most Dell computers have special hardware and software that are set up to automatically adjust the configuration of the headphone ports when headphones are connected, muting the primary speakers in the process. If no sound is coming out of your headphones, this is most likely caused by a configuration issue that can be resolved with a few simple steps.
Basic Headphone Troubleshooting
If no sound is coming from your headphones, confirm that the headphones work properly by using them with a different device. After this, confirm that the headphones are plugged into the proper jack. If your CD/DVD drive has a headphone jack in front, audio will only be played through this jack when you are playing a disc. On a desktop computer, the correct jack to use for headphones is usually color-coded green, while notebook computers will have headphone icons next to the correct jacks. Finally, check the speaker icon in the system tray to make sure that your sound output is not muted. b> Troubleshooting Notebooks b> Most Dell notebooks use a special type of audio jack. The jack, along with the sound drivers that are installed, automatically detect whether headphones or speakers are plugged in and adjust the sound output accordingly. If this does not happen when headphones are plugged in, the sound drivers may be at fault. Visit the Dell support website and download the most recent sound drivers for your notebook. If this does not help, some users have reported success with removing the sound drivers completely and letting Windows install generic drivers automatically. Last Resort b> If all other options have been exhausted, the last resort in troubleshooting a headphone jack is running a complete system recovery operation. This will completely erase all of the information on your primary hard drive partition and reinstall Windows along with the drivers for all of your hardware. This is an extreme measure, as you will lose all of the information that you have stored on the hard drive. However, it will resolve the issue if it is caused by a software problem. If the issue remains, the headphone jack must be replaced. Hope this helps.
b>
Jan 16, 2013 | Computers & Internet
I WANT TO CONNECT HEADPHONES TO 1/4 INCH PHONE JACK ON TECHNICS AMPLIFIER IN A WAY THAT WILL CUT OFF SPEAKERS SO THAT AUDIO IS SOLELY THROUGH THE HEADPHONE. HOW DO I WIRE THIS USING THE PHONE JACK ON THE...
Please plug/ connect this wireless headphone base unit in Line Out jacks at back of amplifier to get sound in headphone and turn down amplifier volume control to shut off its speaker sound.
Thanks.
Aug 11, 2011 | Technics DJ Headphones
I have a Panasonic Sa-HT930 surround sound system. Plugging in headphones does not turn off the speakers, yet I can still hear sound through the headphones. How do I get the speakers to turn off??
The switch of the main speaker does not engage when you plug inn your earphone it's suppose to turn off the main speaker.you need to clean the contact of the switch of the jack.Open the cover of reciever and go to the earphone jack spray it with a contact cleaner then try again.if the same thing happen replace the jack with a new one.
May 28, 2011 | Televison & Video
The antenna will not power up
I have the same model as you.
Plug in the transmitting unit into a good working power outlet. Make sure you have the audio connected to a loud source. Turn on the source device producing the loud audio to be transmitted to your headphones. Now see if the transmitting unit's LED light is on. Check headphones for audio. (May have to tune in the headphones and adjust its volume as well).
I recommend that the source of your audio have its built-in speakers off, while still providing audio out to your transmitting unit, via an external audio output. Check your source manual or look for audio jacks on the front or back. There may be a setting to turn this on and for the main built-in speakers to be turned off as well.
If this does not work, unplug the transmitting unit, and then plug it back in again, after waiting for about 10 seconds - all while audio is being provided to the unit. It should come on.
Remember that if the audio to the transmitting unit is quiet OR off for about one minute, the transmitting unit will turn off and you will hear FM noise, loudly, on your headphones. This is due to the "lack of audio" timer built-in to the transmitting unit.
May 16, 2010 | RCA WHP140 Consumer Headphones
Cannot get power to the unit the light indicating power is out
I have the same model as you. I have two transmitters and three headphones actually. Please see below:
Apr 24, 2010 | RCA WHP140 Consumer Headphones
How do i set up the Technika TA-709 Wireless Headphones to my tv. Have lost the manual and am not getting any sound only static on all 3 channel selections.
You should have all the necessary cables to do this with the package you bought, the wire which has a headphone style plug on each end should be plugged into the headphone jack on your tv.
If they dont work then there are two further things that could be at fault:
A: The headphone audio volume controls and the actual speaker volume controls on tvs are totally different and if the actual headphone volume is turned down then you will get an interference type noise thru your headphones as no sound is being detected by the reciever and therefore they go into kind of a standby mode. !!!!!!!!!!Try looking in your TV settings menu to make sure your headphone volume is turned up!!!!
B: being an owner of a pair of these headphones I know how audio the cable can easily turn faulty from prolonged use us. The wires can easily break inside but look fine from the outside so get a new one. Headphone jack to Headphone jack cable.
I use these along with my xbox 360 wireless earpiece (fits nicely under the headphones) and I think they're far superior to the Turtle beach headphones +++ My setup is 100% wireless which also makes it better than any turtle beach setup on the market.
Jan 07, 2010 | Audio Players & Recorders
Power goes off!
May 18, 2009 | RCA WHP140 Consumer Headphones
Can't connect wireless stereo to sylvania 6620LF4
you can hook this particular unit up to your stereo reciever if available. if i am not mistaken the original design purpose of these headphones were to be powered through a stereo reciever, at least it is a sure fire way of keeping your tv's sound in tact and using the headphones when needed. most receivers have a speaker a and speaker b configuration if you attach the lead from the headphone unit to the opposing speaker input then you can have the functions you desire and the performance you have indicated. hopes this fixya.
Best regards
Ryan
Feb 19, 2009 | Sylvania 6620LF4 20 in. EDTV-Ready LCD...
Yamaha HTR-5730 Receiver Logo
174 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
