Question about RCA R56WH76 Projection Television
Lost convergece and not on the tv menu
Rca 56 inch hd projection tv has lost its convergence on its menu and can not converge all three colars. Is this a blown fuse and can I replace it? And if so, will this blow again? The tv is 3 years old.
  • 147 Answers
Simple problem to fix for a professional; pretty hard to do yourself. There are bad connections on the flyback transformer and a fuse is open. Where do you live; i'm due for a road trip.
Posted on May 13, 2009
I have a 56 inch RCA HDTV projection screen. the convergence is gone off the main menu. The TV is 4 years old. Please help.
These are the best repair kits I have used for convergence issues.
http://www.tvrepairkits.com/xcart/home.php?cat=3909
Please follow the link, buy the kit and follow the instructions they supply...
You can't go wrong.
Thank you and best of luck!~
Jul 07, 2011 | RCA R56WH76 Projection Television
Picture looks like 3d i have ajusted screen but keeps going back to 3d and picture is bowed
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
•Screen looks 3D
•Colors don't line up
•One or more colors can't be adjusted when using the convergence menu.
•Screen is bowed or warped.
•TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems
fcabb43.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya - CLICK HERE
Aug 25, 2010 | RCA P56923BL 56" Rear Projection...
We have a Zenith 56 inch rear projection tv. Model num# R56W36. The picture did the 3-D thing on us when I hit auto-convergence button. We ordered new parts from TVRepairKits.com. Replaced parts and now TV...
•Screen looks 3D
9e1b49a.pngCONVERGENCE SOLUTION
Aug 22, 2010 | Zenith R57W46 57" Rear Projection...
HDLP50W151 50 in. Rear Projection HDTV Television: have a 48 inch rca projection tv and the picture i...
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 17, 2010 | RCA HDLP50W151 50" Rear Projection HDTV
Rca 7302rd5 56"hdtv tv looks like a 3d moive
•Screen looks 3D
Jul 03, 2009 | RCA R52WM24 52" HDTV Projection Television
Big Screen problem
What did you put in. convergence amp or convergence power. this is a rca hd52w59? i always ask the question in customer menu under setup can you see the option of convergence. if not this is the fl231 fuse problem. consult the article fl231 under tips and tricks section of my profile. the curved picture is an indication complete loss of convergence power. there is a board that does provide convergece power. The convergence on this set is controled by three diffrent boards. power,amp and the small signal board. the small signal board is the most expensive and most complicated to replace ussally a tech has to replace that.
Nov 08, 2008 | RCA HD52W59 HDTV Projection Television
Rca rear projection hdtv lost color convergence
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 07, 2008 | RCA MM52110 52" Rear Projection HDTV-Ready...
HDTV convergence going bad
convergence is tricky.. there are three seprate boards that it is split with.. do you have NO convergece at all.. could be convergence power board...one color... convergence amplifer board.. it it could be the signal board.. there's even a chance it could be a descrete fuse... shoot me some more info..
Nov 20, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Trouble Aligning Colors
If the convergence is missing in the menu in screens,you have a bad reg ic on the convergence power supply the part number is 215530,the power supply is located on the black plastic above the right module with all the heat sinks
Nov 15, 2007 | RCA P56930BL 56" Rear Projection...
Where is the convergence control?
Unplug the set wait five minutes then try again go to menu where closed caption is............
Dec 07, 2006 | RCA P56923BL 56" Rear Projection...
Open Questions:
RCA R56WH76 Projection Television Logo
161 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
