Question about Canon i9100D (Bundle) Photo Printer
Waste Ink Tank is full and printer will no longer work. How do I repair this problem?
Canon S9100 printer no longer working due to printer stating "waste ink tank full" message. How can I override the counter?
    Sergeant:
    Novelist:
  • 197 Answers
I wouldn't override that error message. Best bet is to open up the printer and give it a good cleaning. If you're unfamiliar or not comfortable with the procedure, take it to your closest computer repair store to have it serviced.
Posted on May 12, 2009
    Problem Solver:
  • 7 Answers
Gleaned from justanswer.com (applies for Canon i9100)
Tried this on my i9100, worked like a charm. BTW, my waste tank was only 1/4 full. So this fault is most likely generated based on number of hours printer has been operating.
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
Posted on Sep 01, 2009
Tank absorber full and lights blinking
The POWER Lamp Flashes Orange Eight flashes: Waste ink tank almost full
The printer has a built-in waste ink tank for the ink used during print head cleaning. Eight flashes indicates that the waste ink tank is nearly full. Press the RESUME/CANCEL button to cancel the error so you can continue printing. Before the waste ink tank becomes completely full, contact a Canon service representative.
Note
Canon recommends that you call for service as soon as this error occurs. Once the waste ink tank becomes completely full, printing will no longer be possible.
Sep 14, 2009 | Canon i350 InkJet Printer
Canon mp760 printer overflow full, have parts and service manual. Need code to get going again
there is no need to change the ink absorbing sponges at all ,,as i hve solved this problem myself for many of my clients i m sure that it will work for u too if followed properly step by step:
It could be due to "waste tank full" alarm; you may need to reset the waste tank counter.
reset sequence for a MP760 printer that works for F30 and F50 as well. Try:
Resetting the Waste Ink Volume Counter
1) Enter SERVICE MODE.---
By pressing Menu-Copy-#
2) Select TEST MODE.
3) Select [8] PRINTER TEST in TEST MODE.
4) Select 3. [EEPROM CLEAR].
5) Select 0. [INK COUNT].
6) Press the [OK] key.
7) Press the [Stop/Reset] key (returning to the state of 3)), and then press the [ON/OFF] key.
ur printer absorber will reset and will work properly and u will be back to work.try doing it one more time if u miss something .
please take a moment to rate the solution after u get ur problem solved
Oct 03, 2008 | Canon PIXMA MP760 All-In-One InkJet...
WASTE INK ABSORBA FULL
Inkjet printers have a fibrous pad inside them that collects the waste ink from cleaning the print head. Over time, this pad fills up with ink and can no longer hold any more. When this occurs, the printer indicates a "waste ink tank full" error.
Replacing the waste ink absorption pads is something an authorized canon service facility can take care of for you. Once they are replaced, it'll be functional again.
May 23, 2009 | Canon Office Equipment & Supplies
Waste absorber full
May 19, 2009 | Canon PIXMA iP4600 Color InkJet Photo...
Message "wasted ink tank near full" on Canon Multipass F80
May 17, 2009 | Canon MultiPASS F80 All-In-One InkJet...
Waste tank is full, How do fix it, can I clean it myself?
Inkjet printers have a fibrous pad inside them that collects the waste ink from cleaning the print head. Over time, this pad fills up with ink and can no longer hold any more. When this occurs, the printer indicates a "waste ink full" error.
May 15, 2009 | Canon PIXMA MP460 All-In-One InkJet...
My Canon I550 quit printing.
An error has occurred in the printer. The number of flashes indicates the type of error, as outlined below. Check the cause and take the appropriate action.
bullet.gif Two flashes: Out of paper or paper feed error
Replace the paper correctly and press the RESUME/CANCEL button.
bullet.gif Three flashes: Paper jam
If paper has jammed in the printer, clear the jam, replace the paper in the printer correctly and press the RESUME/CANCEL button.
See Paper Jams
bullet.gif Four flashes: Empty ink tank
If you press the RESUME/CANCEL button, it will continue printing with an empty ink tank. However, when printing is finished, replace the ink tank immediately. If you continue printing with an empty ink tank, it will be a cause of trouble.
See Replacing an Ink Tank
bullet.gif Six flashes: No print head installed
Install a print head.
bullet.gif Seven flashes: Defective print head
Contact a Canon service representative.
bullet.gif Eight flashes: Waste ink tank almost full
i_note_us.gif Note
Canon recommends to call for service as soon as this error occurs. Once the waste ink tank becomes completely full, printing will no longer be possible.
bullet.gif POWER lamp flashes alternate green and orange:
An error that requires contacting a Canon service representative may have occurred.
Turn the printer off and unplug the printer from the power supply. Plug the printer back in and turn the printer back on.
If the problem remains, contact a Canon service representative.
Apr 14, 2009 | Canon BubbleJet i550 InkJet Printer
Waste ink tank full
please help me for repair waste in tank full canon ip3300.
Nov 01, 2007 | Canon PIXMA iP3300 InkJet Photo Printer
Alarm light on. F80
This worked for me on an F60 and someone else on an F30. Re: Check Printer error message on Canon MultiPass by watsonk (6/7/05 11:16 PM) reply + / - It could be due to "waste tank full" alarm; you may need to reset the waste tank counter. I found a reset sequence for a MP730 printer in this website that works for F30 as well. Try: Resetting the Waste Ink Volume Counter 1) Enter SERVICE MODE.--- By pressing Menu-Copy-# 2) Select TEST MODE. 3) Select [8] PRINTER TEST in TEST MODE. 4) Select 3. [EEPROM CLEAR]. 5) Select 0. [INK COUNT]. 6) Press the [OK] key. 7) Press the [Stop/Reset] key (returning to the state of 3)), and then press the [ON/OFF] key. Skip step (6) since there is no [OK] key on F30 printers.
Sep 29, 2007 | Canon MultiPASS F80 All-In-One InkJet...
Canon i9100D (Bundle) Photo Printer Logo
172 people viewed this question
old marine
old marine
