Question about Homelite Mighty Lite Lawn Trimmer
How do I put new trimmer string in the above Homelite weedwacker. product number UT 20042a. I cant seem to push and unlock to piece to replace the ''string''
SOURCE: Replacing the bump head on homelite string trimmer
undo the 2 screws on top of the carb. The bulb is part of a 2 piece cap undo that and it fall out.
Posted on May 16, 2009
  • 27 Answers
SOURCE: how to replace string in a homelite trimmer
have the same weedeater, see utube vids too hard to explain with words
Posted on Jun 10, 2009
SOURCE: Brand new Homelite Mighty Lite 26cs String Trimmer
carb setting is too lean,need special tool to open,go to mower shop.This model also has problems with starter mechanism,I hope you have a warranty
Posted on Jun 14, 2009
  • 6 Answers
SOURCE: st185 Homelite string trimmer starts then dies
I resolved my problem by taking apart the carborator and cleaning it. There were clogged passaged that had stuff come out of them when I used airisol carb cleaner to blow them out. I only had to make one gasket the carb mount gasket which is pretty basic only 5 holes.
It ran for the next 3 hours, ran fantastic!!!!!!
#1 Taper
  • 1040 Answers
SOURCE: homelite st-175g trimmer
This is for a duel line trimmer. I hope this will help.
Cut two separate pieces of string, about 7 ft. each.
Stick the end of the line in the hole on the inside of spool.
Wind clockwise onto spool, putting the line that is closest to the ground on first.
Once you have winded this piece on, lock the last 4 inches of line through the slits on spool.
Repeat process for second piece of line, locking the last 4 inches in slot opposite the other locked in piece.
Put the spool on the trimmer, feeding the end of lines through either hole on trimmer.
Before you push the spool all the way on, pull the strings out of the locked position. Put cap on and GO CRAZY!
Jim
Posted on Jun 19, 2009
Homelite y 2500 yardmachine trimmer
http://www.odref.com/homelite/string-trimmers/ut-20612r.PDF
May 22, 2014 | Homelite Garden
NEED TO REPLACE SPARK ARRESTER ON HOMELITE LITE 26CC STRING TRIMMER
Remove the Torx screws holding the rear cover on. Then remove the larger Torx screws holding the muffler on to the exhaust port of the cylinder. There will be a gasket there. The spark arrestor will be mounted in the opening to the muffler. You can scrape or burn the carbon off of it. If the spark arrestor is real clogged up, then the muffler probably is too. It should also be cleaned. The inside of the engine probably is carboned up too( if arrestor and muffler are). They all should be cleaned of carbon. It helps the engine perform at its' best and breathe like it needs to.
Oct 15, 2010 | Homelite Mighty Lite Lawn Trimmer
How do i respool the line
Align the arrows under the bump feed, push in on bump knob, unscrew in counter clockwise direction, remove spool. Wind string in direction arrows advise on the spool, reassemble. You will be back to weedwacking asap.
Jul 05, 2009 | Homelite Consumer Products 4.0 Amp, 13 In....
Installing new line on my string grass trimmer
Jim
Jul 03, 2009 | Homelite Mighty Lite Lawn Trimmer
How to change the string
If it is a duel line trimmer then:
If it is a single line trimmer, just wind a single piece of string clockwise onto spool.
Jim
Jun 29, 2009 | Homelite Mighty Lite Lawn Trimmer
Homelite st-175g trimmer
Jim
Jun 17, 2009 | Homelite Mighty Lite Lawn Trimmer
How do you fix homelite st 185 weedwacker pull start
Here is a link to that weed cutter...
http://www.odref.com/homelite/string-trimmers/ut-15039a.PDF
you need to unscrew part#37 .. it may be on very tight... hope this helps
Tobaz
Homelite strin trimmer head wont rotate
The only way to access the bottom of the metal shaft is to break it. This is fused on at the factory. It sounds like your flexshaft has twisted in two. Remove the flex shaft from the engine end and see if it is in one whole piece or is damaged in someway. If it rotates at the top but doesn't rotate at the string head this is probably the problem. However, Homelite no longer offers just the flex shaft for purchase. You would probably have to purchase the shaft and the tube as a unit.
But if you are saying the spool and string is not turning at the bottom it could be that the cup which holds the string has worn and can not longer be turned by the shaft. Replace the cup that holds the string.
Another possibility is that the shaft have moved forward, away from the engine and just need to be jammed back in, and retightened (the handle grip and the boom clamp).
Homelite Mighty Lite Lawn Trimmer  Logo
738 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
