Question about HP Computers & Internet
Tower won't turn on
The tower will not turn on, the surge protector was turned off accidently and when It was turned back on the tower isn't responding.
Brandi,
Please check the following:
1. Make sure the the surge protector is securely plugged into the wall. Test this by plugging in a light / lamp to it, to make sure it's working.
2. Make sure that the surge protector is turned on.
3. Check to make sure that the power cable from the computer to the power surge protector is securely plugged in.
4. Check to see if the computer will power on now.
5. If this still isn't working, remove the power strip/surge protector and connect the computer directly to the wall.
6. If this STILL isn't working, try plugging your computer into a different outlet in the house to see if the outlet in your home might be bad.
6. If your computer STILL isn't powering on then I'm afraid the worse has happened, which is one of the following issues:
1. Bad power supply (they are cheap, around $20-40)
2. Bad motherboard (they are sort of pricey, around $50-200)
3. Bad CMOS battery (they are cheap, around $5-10)
I can fix all of the above and order parts for all of the above, if you are in need of parts.
I hope this troubleshooting guide helps you! If this resolves your issues, please mark this question as resolved and select my answer. This will assure customers that I can help them with their issues.
Thank you,
Larry Braziel
Posted on May 12, 2009
No power to computer, flashing green light by power cord
reset the surge protector first!
then investigate the power supply
Mar 27, 2012 | Compaq Computers & Internet
I reset my surge protector and the computer wont power up. i think i need a new power supply. the power cord is working fine. Please let me know where i can find a power supply for the aspire...
The Acer Aspire L100 is a desktop computer powered by a special DC adapter and power cable. The computer's motherboard incorporates a fuse designed to prevent any power surges from damaging the computer. If the fuse burns out due to a power surge or for any other reason, the computer will no longer function. You can check the motherboard fuse for damage yourself, then take it to a trained technician for replacement if needed
Shut down the Acer Aspire L100 and turn the tower around.
Press the "On/Off" button on the front of the tower. If the computer will not boot and the fan does not turn on, the fuse may be burned out.
Unplug the power cord from the rear of the tower
Turn the tower on its side and remove the Phillips-head screws connecting the back panel to the Aspire L100's cabinet.
Pull out the motherboard assembly gently from the back of the cabinet. The internal fuse is located on the motherboard behind the DC power jack, which is to the right of the monitor jack
Let me know if this helped..
  • 2 Press the "On/Off" button on the front of the tower. If the computer will not boot and the fan does not turn on, the fuse may be burned out.
  • 3 Unplug the power cord from the rear of the tower.
  • 4 Turn the tower on its side and remove the Phillips-head screws connecting the back panel to the Aspire L100's cabinet.
  • 5 Pull out the motherboard assembly gently from the back of the cabinet. The internal fuse is located on the motherboard behind the DC power jack, which is to the right of the monitor jack.
  • Read more: Fuse Location on Acer Aspire L100 ' eHow.co.uk http://www.ehow.co.uk/how_7815704_fuse-location-acer-aspire-l100.html#ixzz1XUVwmxuA
    Sep 09, 2011 | Acer Aspire L100 PC Desktop
    Screen frozen, can't turn off
    Hold the power button down on the actual tower of your computer. After about 10-15 seconds the computer will turn off and you can restart it. If that fails, as a last resort pull the power cable out of the tower. It isn't as damaging to the computer as most people think but should only be used if the computer won't turn off any other way.
    Apr 07, 2011 | Computers & Internet
    Well, ihave an older compac sr1053WM presario, and I had a power failure of and on all last night, but the pc was not in use all night. it was turned off. And i have a very good surge protector. So I tried...
    Its a long shot but try unplugging the power lead from the power supply in the back of the tower. Wait 2 minutes then plug it in again and try powering it up. Regards, nicam49
    Feb 09, 2011 | Compaq Computers & Internet
    The tower nor keyboard wont come on and its pluged in
    Advise, c
    1) Check to make sure THE receptacle in the surge protector that the computer is plugged into, is good.
    I have had a few surge protectors where just THAT receptacle was bad.
    ("Hmmm, monitor, router, and printer has power from the surge protector." Checked the receptacle in the surge protector that the computer was plugged into, with a table lamp, found THAT receptacle was bad)
    2) Receptacle in surge protector proves to be good?
    Suggest performing the test to see if the problem is the Power On switch, or the Power Supply.
    (The Power On switch is located inside the plastic Power On button)
    The test involves bypassing the Power On switch, by using a jumper wire on the Soft Power On, in the ATX main power cable's connector.
    Has nothing to physically do with the switch itself.
    Using the jumper wire the computer (Power Supply) comes on?
    Problem is the Power On switch.
    [ Example of a generic ATX power on switch that I have found fits many computers,
    http://www.directron.com/atxswitch.html ]
    Using the jumper wire the computer (Power Supply actually), does Not come on?
    The problem is the Power Supply.
    Replace.
    http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain20
    (Green wire {PS_ON} is the Soft Power On wire. It is jumped to ANY Ground {Black} wire)
    Want to know how to Properly perform the above test? Please post back in a Comment.
    Also post the computer manufacturer's name, and the Model Number.
    (On the back of a desktop computer next to the Windows Product Key, or up on the side of the tower)
    Regards,
    joecoolvette.
    Nov 08, 2010 | Computers & Internet
    No power cannot turn on
    Suggest you check the simple stuff first.
    Not checking is akin to a car that won't start, and tearing apart the entire fuel system, only to find it was just out of gas.
    1) Make sure the receptacle the surge protector is plugged into, has power. Surge protector Power On light should be lit.
    2) Check THE receptacle in the surge protector, that the computer itself, is plugged into.
    Have had a number of expense surge protectors, where just THAT receptacle was bad.
    ("Hmmm, surge protector Power On LED light is lit. Monitor, printer, sound system, and router plugged into the surge protector has power. Should be good to go.
    NOT!
    Plug a table lamp, or similar device into THAT receptacle.
    Make SURE it has power)
    Surge protector, and receptacle in surge protector checks out?
    Bypass the Power On switch.
    See if the problem is a $5 Power On switch, or the Power Supply.
    (Generic ATX Power On switch that I have found fits many computers,
    {The Power On switch, is located inside the plastic Power On button assembly}
    This is information about computer Power Supply's,
    http://en.wikipedia.org/wiki/Computer_power_supply
    This is a basic example of an SMPS, (Photo at upper right. You can click on the photo to enlarge), and info about.
    (Switched-Mode Power Supply. The main type of power supply used in personal computers),
    http://en.wikipedia.org/wiki/Switched-mode_power_supply
    By bypassing the Power On switch, you will be able to determine if the problem is the switch, or Power Supply.
    Bypassing the Power On switch turns the Power Supply on?
    Bad Power On switch.
    Bypassing the Power On switch does Not turn the Power Supply on?
    Bad Power Supply.
    A jumper wire is used on the 20, or 24-pin ATX main power cable.
    The jumper wire goes to the Soft Power On, (PS_ON. Green in color), to ANY Ground wire.
    (ALL Black wires are Ground wires)
    A MOMENTARY contact is used.
    (Example of a 24-pin ATX main power cable, and it's respective connector,
    http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain24 )
    In order to guide you in this procedure, I need to know the computer manufacturer name, and Model Number.
    On a desktop computer this will be located on the Back of the computer tower, (Next to the Windows product key), or up on the side of the tower.
    Some models have it where there is a door you open in the front, and the product number, or model number is located there.
    Post back in a Comment.
    Aug 07, 2010 | HP Computers & Internet
    When my computer is turned on green light is not display and the screen does not display anything than what should i do ??
    If the green light is not glowing in the tower check the status of the light on the back of the tower where the power cable goes.
    If there is no light in the back of the tower than it might be an issue with the wall jack or surge protector so try connecting the power cable to a different jack and see what happens. if it remains the same than try with a different power cable and check.
    If the light is glowing on the back of the tower but there is no light in the front than it may happen the power supply of the pc might have failed. try to open the tower reseat the RAM cards, reseat the Harddrive cables as wells as try to reseat the cables of the power supply. if the light on the back flickers and goes away than it might be a faulty motherboard. So do a Motherboard test by turning on the pc without the RAM cards, if the motherboard is fine you will hear beeping noise if not than motherboard is faulty.
    Aug 02, 2010 | Smart Modular SV3170A
    I have a HP Compaq Presario Media Center computer, it is plugged to a surge protector, the other night the electricity went out and my computer was turned on, and now I cannot get it to turn on at all, the...
    try removing all power cables of your computer that are connected to the surge protector. reset the surge protector. wait for about 5 minuets before you turn on the surge protector. then plug all cables that your remove from your computer the turn on the computer.
    Jun 03, 2010 | HP Compaq Presario Media Center SR1750NX...
    PC won't power up
    Hi! Try to check if there is any power light or any lights on the machine whenever you try to turn it on, also, try to directly connect the power cable directly to the wall outlet.If you have a spare power cable try to use it.If you are getting the same result, try to unplug the power cable at the back of the computer, press and hold the power button for 10 secs and after that plug the power cable back in and then try to press the power button.Check for indicators if the system is getting power for example, check lights, check if the fan is spinning at the back, check if the dvd/cd drive will open or check if the tower is emitting any sound.If still the same and still no light coming from the tower then it might be a issue with either the power supply or the motherboard, you can call your manufacturer and have the machine serviced if its still under warranty.Hope this helps...
    May 20, 2010 | AcerPower FH (APFH-EP9150C) PC Desktop
    Xps generation 3 won't turn on
    you might need to have replacement for the power supply and motherboard of the system, i would suggest to contact dell tech support since you can purchase the parts from dell.
    Sep 02, 2009 | Dell Computers & Internet
    Computers & Internet Logo
    169 people viewed this question
    Top HP Computers & Internet Experts
    Tony
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
