Question about Pentair Kreepy Krauly Suction Side Inground Automatic Pool Cleaner - Universal
Need operational manual
Do you have free manual on kreepy krauly, for in ground swimming pool, so we can print off
  • 20 Answers
The manual is available at this web add, thanks be sure to leave a good rating.....
http://www.novem.com.mx/mkreepy.pdf
Posted on May 12, 2009
    New Friend:
  • 13 Answers
Http://www.poolsupplyunlimited.com/Products/Manuals/145260_20131029141358.pdf
Posted on Oct 01, 2014
My kreepy krauly wont clean the deep end of the swimming pool.
Your situation is unusual in that most of the time these will stay in the deep end and not get to the shallow end. Make sure that your hose is the proper length and the hose weights are in the right positions
Up to 4 feet water, 1 weight at one foot away from Kreepy
4-7 feet water, add a second weight at 6 feet from Kreepy
7-12 feet water add a third weight at 10 feet from Kreepy.
It can take some trial and error to get the Kreepy to cover the whole pool. This includes adding or removing hose sections, and adjusting the pool return "eyeballs" to different directions.
Feb 21, 2014 | Universal Kreepy Krauly In-Ground Pool...
BROKEN SUCTION HOSE CONNECTOR DOWN IN SUCTION WELL
Contact them direct. This is not something that can be answered by Fixya, especially as this is an Australian product and we are a North American self help website.
Pool Cleaners ' Automatic Pool Cleaner - Kreepy Krauly Pool Cleaners
https://www.kreepykrauly.com.au/Kreepy Krauly is Australia's most trusted and innovative automatic pool cleaner. Request a free pool cleaning demonstration with one of our pool cleaners today.
Kreepy Krauly Google Search
Aug 25, 2017 | Universal Kreepy Krauly In-Ground Pool...
Kreepy krauly not cleaning whole pool
If the pool hose has been used for a long time it becomes set in a particular position. Twist the hose at least at leasr 90 degrees so that the hose is set in a different configuration and the Kreepy krauly will go to a different part of the pool.
Feb 27, 2012 | Universal Kreepy Krauly In-Ground Pool...
I need a skirt for my Kreepy Krauly in ground pool. What is the part nr etc???
The flapper portion of this automatic pool cleaner is called a flapper or pleated seal. I believe that this is part number K12896.
Mar 13, 2011 | Universal Kreepy Krauly In-Ground Pool...
Hi, I also bought my Bull Shark Kreepy Krauly recently - 3 months ago. Since day 1 it liftes up at the end and does not move flat on the surface of the swimming pool. Please assist.
First, check for debris in the pool cleaners flapper. This can cause a lack of suction the floor. Also, check for proper hose balance. If the hose rests at a greater than 45 degree angle, the hose is too light and you need to move the hose weights closer to the cleaner. If the hose rests at a less than 45 degree angle, you need to move the weights away from the cleaner.
Feb 11, 2011 | Universal Kreepy Krauly In-Ground Pool...
Hi, I bought my Bull Shark Kreepy Krauly recently and from the start it lifted up at the end and does not move flat on the surface of the swimming pool. Please assist.
If it has never worked properly, it could be that your pump and filter system are too small for this particular automatic pool cleaner. If you don't feel that this is the case, there a few things that you can check. Make sure that there is not debris in the flapper. It could be causing a loss of suction, making the pool cleaner rise off the floor of the pool. Also, check your water flow coming from your return line. It could be too high. You can adjust it with an eyeball diverter if necessary.
Jan 17, 2011 | Universal Kreepy Krauly In-Ground Pool...
MY kreepy krauly does not move around the pool, appears to have too much suction and I hardly pull it off the floor of the pool even! I have a new sole, does it need a new tongue! Thanks Vikki
First, make sure that the main drain and all other lines are closed except the one that your pool cleaner operates from. You might need to install a manual by-pass valve (Part #K12094). It could be that your pump is too powerful for this cleaner, which would be solved by the manual bypass valve.
Nov 19, 2010 | Universal Kreepy Krauly In-Ground Pool...
Kreepy Krauly In-Ground Pool Cleaner: my creepy crawler wont hammer...
This usually happens when there is a small stick jambing in the bottom of the openning in the Kreepy Krauly where it sucks in the water and rubbish. It is the rubber tube that has a ****, usually something is jambed in the **** to prevent it from thumping.
May 16, 2010 | Universal Kreepy Krauly In-Ground Pool...
Hi my kreepy krauly wont stay flat on the bottom of the pool???
Do you have any hose weights fitted to the kreepy hose? If you do,take it off and see if it makes a difference.Is this happening while the kreepy is operating?
Nov 21, 2009 | Universal Kreepy Krauly In-Ground Pool...
Pentair Kreepy Krauly Suction Side Inground Automatic Pool Cleaner - Universal Logo
563 people viewed this question
Top Pentair Pool & Spa Experts
Jay Finke
Jay Finke
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
