Question about Apple M9034LL/A Keyboard
We use Apple Keyboards in our testing centre, but would like to disable the side USB ports, so that students cannot smuggle in answers on their own thumb drives. How do we disable the ports?
    Scholar:
  • 152 Answers
Sorry, there's no way I can see to disable any of the USB ports either in software or hardware. How about a third-party keyboard that doesn't have any ports to begin with? Or, you could also physically block the ports... That could get a little pricey at around $10 a port (from what I've seen online), but it certainly seems fairly fool-proof (or at least student-proof!!).
Please rate this solution if you feel it has helped! Thanks, and good luck!!
Posted on May 12, 2009
I bought an old Mac Mini Intel Core 2 Duo, 2 GB Hard Drive, OS X Yosemite, with serial # C07CS2TPDD6H. What adapter cord could I use to connect it to an iBox C1752, TFT LCD Monitor?
That Mac has a hdmi port and a mini display port. The monitor has a saga port. So ether a hdmi-svga. Or miniDisplay port-svga.
Any usb keyboard will work. So any Mac keyboard newer than 12 years should be good, and newer pic keyboards will work. Beware of older keyboards that have round plugs. On macs these were ADB ports. On PC's, they used PS2 (ADB, ps2, usb are all different, you want the flat rectangle USB)
U.S. pc keyboards also have two modifier keys wired different than the U.S. Mac keyboards, but this can be adjusted in the system preferences. Can't say for non U.S. KBs. They are the windows/alt keys. Vs Opt/Command keys. That is, if you are soused to using a Mac, the key that is closest to the spacebar (command key) is applied by the second key over rather than the first. Again, this can be modified in the Sys Prefs.
Jun 06, 2015 | Apple Mac Mini Desktop
Enable keyboard
First, make sure it is plugged in. If it is a USB type, try the other USB ports on the computer to see if one or more ports have failed.
Still no luck? Try differen USB ports each time you boot up. During the boot, enter the computer's BIOS or Set Up area (usually pressing DEL, F1 or some other key). Check for setting regarding keyboard and keyboard type. Make sure they are enabled. If nothing works, the keyboard may be broken - not disabled. Try with another keyboard instead.
Apr 09, 2014 | Computers & Internet
Usb Power Problem
Hi check in bios if the usb port is not disabled, also try to connect another device to it for example usb stick. If it's working you may need install drivers for your device first.
Mar 29, 2014 | Generic for Dell Inspiron 14R N4110 M4110...
Error message usb ports force stopped because of too much power
It will still be covered by the warranty, take it to an apple repair centre, they will have Apple hardware diagnostics software that will be able to determine the cause of the fault. Worst case scenario will be they have to replace the logic board.
If you are using some sort of USB hub the number of devices you are connecting to that single port may be drawing too much power. Try to determine how much power each device is drawing then ask at an apple store how much power the USB port can supply.
Feb 22, 2014 | Apple MacBook Mac Notebook
My (apple usb keyboard model m2452)'s usb ports does not work properly with dell cpu. it want driver, witch i need now.
first format u r laptop then u install all the driver u had my key board plz install the drivers plz download form the internet
Jul 20, 2011 | Apple (M2452) Keyboard
Drivere sk-8125 pentru windows 7
If it's doing nothing then you have a bad USB port (move it to another USB port) or the USB keyboard is disabled in CMOS (usually hit F2 or Delete button during start up to get to). If the keyboard is working but isn't working correctly, there is something wrong with the keyboard. You probably just need a new keyboard.
Jan 30, 2011 | Dell SK-8125 Keyboard
I deactivated my usb ports coz my sister puts a lot a of virus thru her USB. Thru bios i deactivated itnow i cant use my keyboard anymore. how can i active it again?
You have to go back to your bios setting and re-activate the usb ports, try getting usb lock software to lock the usb ports rather than disabling them.
u can get one following this link
http://www.4shared.com/file/hiuMteKe/USB_LOCK_AP_23.htm
Jan 10, 2011 | Computers & Internet
My usb doesn't work with it. (apple m7803)
If it is not working with your usb ports, it is possible that it is no longer compatible with your operating system.
May 07, 2010 | Apple M9034LL/A Keyboard
I put the usb into any my laptops usb ports and it just doesnt disable my touchpad or even want to work when a couple of days ago it did.
it shouldnt disable your touchpad unless theres an option for it too but if its not working try reinstalling the driver in control panel
Apr 08, 2010 | Logitech Cordless Mouse
The usb ports will not work,therefore the mouse nor the keyboard will work
Try the mouse in a computer where the USB ports *DO* work.
It is possible that your system does not have the correct "device-drivers" for the USB ports. Thus, those USB ports seem to be "dead".
Turn the computer off.
Connect a PS/2 keyboard and a PS/2 mouse.
Turn the computer on.
Click START
Click Control Panel
Click System
Click Hardware
Click Device Manager
Expand the "USB ports" section of the tree.
Look for "yellow" or "red" marks.
Double-click one of those "problem" devices.
Choose "Reinstall Driver".
If it asks to be able to connect to the Internet, click "yes, this time".
Hopefully, this will install the correct drivers for your USB ports.
Nov 05, 2009 | Dell 2 Button Mouse 6u226
Apple M9034LL/A Keyboard Logo
94 people viewed this question
Top Apple Computers & Internet Experts
paulcarew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
