Question about ASUS P5RD1-VM Motherboard
Asus P5K-E Wifi/AP configuring sata as raid
The motherboard does not see my sata drives when set to raid in the bios.  I have download the updated intel drivers and the JMicron JMB363 driver from the support CD and installed at the F6 prompt, and still no drive is recognised.
I have tried with a single drive connected, and also a mirror array with two. Computer works fine in IDE mode, but I bought this board because it does raid...
ASUS are impossible to contact as their website doesn't recognize my serial numbers.  Have they a bad reputation?
Thank you for this wonderful service.  I've practically been in tears over this!!
  • 1 more comment
  • mcfawcett Oct 26, 2007
    After setting SATA to RAID in the BIOS, the machine restarted and I did then go into the Configuration application, and created a RAID volume - this is the mirror array I referred to in my initial posting.  Then tried to set up windows on this volume using what I thought to be the correct drivers at the F6 prompt.  I accept that I may have been using the wrong ones because other people must have managed it!
    In despair I changed my motherboard to an Abit IP35 Pro, a very similar process to set up the RAID, and it worked perfectly!
    Thank you so much for responding to my problem, I kind of wish I still had the Asus board so that I could give it another go to make sure I hadn't missed anything, but you know what they say about being careful about what you wish for!!!
    Kind regards, Mark
  • bignacho79 Dec 17, 2007
    i try to install winxp sp2, i connect the sata disk into sata1 and sata2, they are 500gb each, i start my computer, i go to bios, make my satas as raid, then on boards device configuration controller mode as SATA, boot as 1st floppy, then dvd, and 3rd raid volume0, then save and exit, and entry on raid advance menu... or whatever is call, sorry, i create the raid, one volume, i just have to disk.... everything ok?? so, i start with the instalation, i press F6, and i install like the manual says the driver jmb363 raid, the one from the cd intaller, or the one from the support page, that is a piece of... booth of those driver take after the computer restart to ask if you want to install reestore or exit the intalation menu, i don´t get to that menu, it´s says to make a chkdsk /F, and give me the error 0x0000007B... if i take away the raid, and try to install like ide it's works, and windows see two hd,
    how i can make my raid work??? someone can help me. thanks
  • snc3 Jun 16, 2008
    I have the same motherboard, ASUS P5RD1-VM, BIOS American Megatrends v 02.58. I don't see any feauturies in BIOS setup to make my SATA drive to be recognized on IDE, the same in Raid Setup, so when I'm trying to install winodws xp sp 2 and pressing F6, I'm inserting the disquette which I've created using utility on "motherboard drivers cd", the setup program is loadig drivers, but still can't recognize any hard drives installed in my system. Why i'm sure those drivers are correct? because these drivers were on the CD which I've got with this motherboard, and the RAID-controller is integrated to this motherboard, wo why drivers shouldn't be correct?
I have tried every drive jmicron and ICH9R as well nothing helps.even to the point of downloading from asus nothing helps.
this is a bios problem.
Posted on Feb 09, 2008
One more thing for the record i have flashed my bios for the latest version.
I shook the hole time that it took to flash and reboot.
Asus P5K-E Wifi/AP configuring sata as raid - icon_cool.gif Crowley icon_cool.gif (An Angel who did not so much Fall as Saunter Vaguely Downwards)
Hello to start with.
Here are a few specks from me to start with.
1) E6850 core duo 2 x3ghz
2) 2 gig Corsiar Ram 4 4 4 12 timings 2.10 v
3) XTX 8800GTS 512 mb ddr3 ram
4) HD321KJ Samsung Sata II 320gig
The SATA II drive doesnot and i repeat not have a problem in windows. Everytime you recieve your blew screen go straight into bios and then tell me what you see on the first screen it shows for one your sata drives and the positions please refer to user manual for postions. At the moment in my config it should show on port 2 my hd321, but sometimes it failes to find the drive.
Now you try and Put windows onto your drive.
This is were it gets critical what with all the new starts remember in bios sometimes it doesnt find the drive BIOS needs to be updated. Windows works fine untill such times as you put stress on the hard drive because then it will loose the plot somewhere.
Once you have got to that position the board then shows what its been baught for Crysis was all on hi in graffik department anti alaysing x4 and the resalution 1298 960 and it played like a dream.
I also play Battlefield 2 + BF2 special forces inclusive patch 1.41 .now the stress starts for the drive BF2 no prob BFSF2 the machine just cant handel the info a blue screens press reset and go into bios no drive wonderful. Its been like that for the month my solution is simple and not very expensive PCI e SATA II + IDE Buss card.
I hope i havent put anyone of this board for that is not my intention the board it self is a dream peace of work. Windows for once is not to blame but please the driver Dudes come on sort this conflict out.
Try the ICH9R intel RAID drivers on the utilities disk.
Posted on Jan 30, 2008
I have 3 hard drives, one I have my windows system files on, and on the others I was planning on doing a mirrored raid. Is this possible? I couldn't get it to work, I put the hard drive mode into RAID mode or ACPI (or whatever the other mode was) and it doesn't allow me to boot into windows or anything, blue screen of death.
Only works in IDE mode, but I cant make it raid using IDE mode :"(
Posted on Jun 05, 2008
  • 661 Answers
You have to ensure that you are using the correct SATA drivers from the disk at F6.....You are on the right track. but I am not sure you are using the correct driver at F6
If memory serves there should be a RAID configuration notice during boot,  I think you configure there (not in the windows install)
it is similar to how you get into BIOS,  you need to configure this RAID module first, as it will then present the RAID protected volumes to Windows Setup (you will most likely still need the J micron Driver too)
I think that as this has not been configured that is why it is not showing up in the windows setup (as you have not created any volumes for windows to see)
Posted on Oct 26, 2007
P5k-e front pannel audio not working
Make sure you check that the front audio cable is connected properly on your motherboard. You can see how it's supposed to be hooked up and where it is located on page 2-32 in either of the manuals I have linked up for you below. And if you haven't already make sure you have the correct audio driver installed.
Drivers & Downloads for ASUS P5K-E/WIFI-AP:
Manual #1:
Jun 14, 2012 | ASUSTeK COMPUTER Asus P5k-e/wifi-ap Lga775...
there should be a little push button located somewhere on the case where the access panel meets the case itself, if pc is started with access panel off you will get that message, there are two ways of disabling that feature,... locate the little push button and there should be a wiring harness coming off of it going to the motherboard, just disconnect from the motherboard, or if you dont want loose wires in your system you can go into bios and disable it from there, should be under security or something similar to that, hope this helps
Jan 29, 2010 | ASUS P5K Deluxe/WiFi-AP, iP35, S 775,...
Want to run both Raid 5 (4 drives) and a single SATA boot drive
Download the latest beta BIOS 1238. I had the same problem when adding a Samsung 1TB HDD to my RAID config. Updating to BIOS v1238 solved the Intel RAID Matrix "hanging" instantly.
You can't download it through the official Asus support page yet, but there's a topic in the Asus support forum with a link. You could also call Asus support and request the file, or just download it here: :)
Feb 07, 2009 | ASUS P5B Deluxe/WiFi-AP Motherboard
I have a new P5E3 Premium WiFi-AP MB. I have fitted one new 500Gb SAT drive to SATA1 connector I am trying to load Windows XP Pro, but each time I try, I get STOP 0000007B message. I know the drive is OK...
Why do you have your SATA configuration set to IDE compatible if you're using an SATA drive? You only need to do that if you have an IDE drive in the system in most case. Try setting your BIOS to failsafe mode and see what happens.
Dec 31, 2008 | ASUS MB P5E3 PREMIUM/WIFI-AP X48 RT...
Raid sys on p5k/epu
You are correct. The Asus P5K does support SATA RAID configuration. Page 4-14 in the user manual.
Congifuration [Enhanced]. Only real option is IDE. That does not mean the SATA drives will run like an IDE. The SATA's will function faster. In order to get RAID function you would need to have bought the Asus P5K Deluxe.
Jun 06, 2008 | ASUSTeK P5K Desktop Board - Core 2 Extreme...
Powering up
You need to remove the cap from 8-pin EATX12V connector and connect 8-pin EPC +12V power plug from your P/S, otherwise it will not work. Your power supply should support 8-pin EATX12V. If you P/S comes with 4-pin connector only you just use your 4-pin open spot and leave the cap on.
May 22, 2008 | ASUS P5K Deluxe/WiFi-AP, iP35, S 775,...
Setup powering down after 5 minutes of being on.
Enter you're bios & head to CPU section. There should be a section to check CPU & motherboard tempture. Sit back & watch the temp settings. (Check for over-heating which can & will shut down the system). It's best to do this with the case closed. Normal operation.
Did you add thermal grease between heat-sink & CPU. Same can happen if memory over-heats.
May 18, 2008 | ASUS P5K Deluxe/WiFi-AP, iP35, S 775,...
Not driver audio asus p5k/p5kc
Please expand "audio problem" to a question giving symptoms etc.
I hope you don't tell your mechanic "car problem" when taking it in for repairs! LOL
May 10, 2008 | ASUS P5K Deluxe/WiFi-AP, iP35, S 775,...
The P5K motherboard has a four port vanilla ICH9. There
Is no RAID on the Intel, when the chip has only four ports?
So S1, S2, S3, S4 are not RAID.
In the P5K manual, the RAID function exists on the Jmicron
Controller. One drive connector is internal (SATA_E2, on the
Left of the motherboard picture in the manual), and one
Drive connector is external (F_ESATA on the back I/O area).
This is not convenient for building a RAID0. (The intent is
To allow making RAID1 backup disks.) You'll have to snake
The SATA cable back into the computer, if you hope to use
It with two internal SATA disks.
The manual has full instructions for setting up RAID on the
Jmicron JMB363. The manual says to set the Jmicron to RAID
Mode in the BIOS. Two disks must be connected, in order to
Be able to press <control-J> at the start of the BIOS, to
Enter the Jmicron RAID setup in the BIOS. At that point, you
Can declare an array in the BIOS setup.
Then, when Windows is installing from the Microsoft install CD,
You’ll need to press F6 and offer the Jmicron RAID driver.
Section 5.5 of the Asus manual, describes how to make
A RAID driver floppy. The application in the mother board cd is available for make drivers disk
Dec 07, 2007 | Intel D101GGC Motherboard
ASUS P5RD1-VM Motherboard Logo
3,626 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
