Question about Adobe Acrobat 6.0 for PC
Adobe acrobat 6.0 professional patch 6.o.1 fails to download as corrupt
I need your assistance , as when it needs to download this patch it goes right through , then fails to implement , as it " says something like file corrupt. It comes through from adobe reader .
I am not a computer wizard , so please just tell me what to do for this patch to come through. many thanks Isabel
  • 265 Answers
Re: adobe acrobat 6.0 professional patch 6.o.1 fails to...
Have you activated your copy of Acrobat 6.0 Pro? If not, any patch will give this fault.
Posted on Dec 20, 2007
0 characters
3 Points
Activation of adobe professional 7
S/n no.1118 - 1211 - 8774 - 2056 - 8650 - 9703
A/c no. 1842 - 1183 - 4682 - 8251 - 3749 - 6248 - 3106
I need authorization code
Jan 21, 2013 | Adobe Acrobat 7.0 Professional
Error "the application is being terminated because of memory corruption"
When you exit Acrobat 7, Acrobat returns the error message,"the application is being terminated because of memory corruption."
Do one of the following solutions:
Solution 1: Install the Acrobat 7.0.8 update.
If you have Acrobat 7.0, choose Help > Check For Updates Now to install the update. Alternately, you can download the update from the Adobe website at .
Solution 2: Remove the files from theAcrobat Organizer folder.
When you remove files from the Acrobat Organizer folder, you force Acrobat to rebuild the Organizer database. This process replaces any damaged files in the Organizer that may be causing the error message.
To remove the files from the Acrobat Organizer folder:
1.Choose Start > Run.
2.In the Open text box, type:%UserProfile%\Application Data\Adobe\Acrobat\7.0\Organizer70.
3.Delete or move all filesfrom this directory.
Solution3: Remove the files from the Updaterfolder.
You may receive this error message after a failed update, indicating that the files in the Updater folder are corrupted.
To remove the files from the Updater folder:
1. Choose Start > Run.
2. In the Open text box, type:%UserProfile%\Application Data\Adobe\Acrobat\7.0\Updater.
3. Delete or move all the files fromthis directory.
on Mar 20, 2010 | Adobe Acrobat 7.0 Professional
Hi, can i get a adobe acrobat 6 patch thanks
Start the Adobe software.
Click Help
Click Check for updates.
Download the recommend update(s).
Dec 26, 2009 | Adobe Acrobat 6.0 for PC
Is adobe professional 6 compatible with Autodesk 2010- when i publish a Pdf in AutoCad 2010 - Adobe pro 6 says i need an updates version - so i updated as much as possible and it still does not work? Do...
Acrobat Pro 6 has some limitation and since you're using Autocad 2010, the algorithm is much more complex than a standard documents. I suggest that you check the answer in Adobe forum
Nov 16, 2009 | Adobe Acrobat 6.0 Professional for PC
Missing PDF Maker files
what is your version of acrobat? if it's acrobat 7, this version works only with ms office 2003 and below. Also, you can do these steps:
1. Open office application>go to help > about [name of program]
2. go to "disabled items" and look for the addin for acrobat (i think it is named adbmsofficeaddin.dll) and enable it.
3. restart the application.
if you need further assistance about IT trouble, SEO or if you need professional writing services, then you can visit my site at
Mar 12, 2009 | Adobe Acrobat 7.0 Professional
Acrobat 6.0
Jul 24, 2008 | Adobe Acrobat 6.0 for PC
Reading files
hi,uou can download the latest version of acrobat reader from this link
if you want the adobe 5 click this link
Dec 17, 2007 | Adobe Acrobat 6.0 Professional for PC
Patch 6.0.1 downloads , then says corrupt something about windows not letting through
Uninstall Adobe Reader, do a search for all "Adobe" files and delete them. Go to the Adobe website and install the new Adobe Reader 8.1 program.
Oct 14, 2007 | Adobe Acrobat 6.0 for PC
Adobe Acrobat 6.0 for PC Logo
506 people viewed this question
Top Adobe Graphics Publishing, Design & Multimedia Software Experts
Laxman Bisht
Laxman Bisht
Are you an Adobe Graphics Publishing, Design and Multimedia Software Expert? Answer questions, earn points and help others
