Question about Dell Dimension 8400 PC Desktop
Dell 8400 is not starting
Hi I have Dell 8400, since lat few days all of a sudden i stared seeing machine getting stopped abruptly. I restarted few times and it used work. Some times i used to see memory parity error. From last 2 days machine is not starting. I am hearing a beep sound but i don't see any thing on the screen. What could be the problem. How do i debug
  • 413 Answers
Sir it is all about RAM and you've already mentioned that it gives you beep sound which testifies that It is the time when the RAM should be replaced
Thanks And Regards
Posted on May 12, 2009
    Scholar:
  • 152 Answers
I would attempt to remove all of the expansion cards from the system, remove all of the IDE/SATA connections from the motherboard, and see if it can even get to the power-on self-test (POST) with nothing attached. If that works, start re-adding components until you get the failure again - that will help single out the faulty device. If you get memory parity errors, I'd also try to remove all the RAM and try booting with just one DIMM inserted at a time until you isolate the bad strip.
Please rate this solution if you feel it has helped you! Thanks!!
  • 3,267 Answers
Check if the RAM is seated properly and clean too. Check your power supply(SMPS) for the 3 voltages it should generate. RAM will not need any replacement however your SMPS may require replacement...sodeep
I have recently added more ram memmory to my Dell dimension 8400. A few days later my pc starts up till everything is on the screen then switches off completely. Is this a possible power supply problem??
If you added ram of a different make that can happen.What I mean is that if you put ram of a diferent make on twoslots then you can have that problem. Your ram should be all of the same manufacturer. However sometimes some different ones work. Try changing your ram's position and see what happens also take of the ram and see what happens. If your computer starts working then the ram is the problem. Try this and tell if it worked.
Nov 18, 2011 | Dell Dimension 8400 PC Desktop
Stopped abruptly won't restart
tThe flywheel is indexed to the crankshaft with a soft aluminum "shear" key, when the blade is stopped suddenly the key is broken instead of the crankshaft. The flywheel will need to be removed and a new key installed. Make sure to clean the shaft and flywheel mating surfaces so they fit tightly or the new key won't last too long.
May 27, 2010 | Toro Lawn Mower With Toro Power Tools
Dell 8400 No Boot, not even POST
It sounds like your bios were improperly flashed or went bad. The X300 SE message is your video card. So your video card works, the system mostly works, but the BIOS isn't starting up. You should contact Dell and tell them the situation.
Apr 19, 2010 | Dell Dimension 8400 PC Desktop
Sound suddenly stopped on the dell lat d810. I
Use the System restore utility (programs -> accessories -> system tools -> system restore) to restore your computer status to a date when your sound was working properly.
Thanks
Apr 12, 2010 | Dell Latitude D810 PC Notebook
Dell inspiron 8400 gets a error message of 00f0 136C
Try to open Windows on safe mode (follow the steps below).
1. Restart, and when you see Dell screen, hit F8 few times.
2. Next screen select Windows Safe Mode.
3. If you can get in Windows Safe Mode, Click Start, Run, type cmd, click ok
4. In the prompt, type chkdsk c: /r and hit enter.
It will ask you if you want to run the chkdsk next time you restart, type y and hit enter. Close the command screen and restart.
5. Let it run, it will take several minutes and it will correct all the problems in the hard drive. After it finishes, it will restart and take you to the log on screen.
Hope this work for you.
Apr 02, 2009 | Microsoft Windows XP Home Edition
Dell Dimension 8400 power supply
It not a common problem. The problem that you are facing is is beacuse of faulty motherboard. The blinking amber is caused , becasue the motherboard is not able to distribute the power signal to the devices . You can follow the link below to trouleshoot the problem if you are comfortable in opening the computer chassis
http://tinyurl.com/8mkpnm
Thanks
Proton
Jan 20, 2009 | Dell Dimension 8400 power supply ** FREE...
Dell inspiron1525 laptop trouble
This is going to be a problem either with the sound card malfunctioning after the machine warms up, or feed back from the speakers due to a wiring issue. Either way, this is a hardware problem, and you shouldn't have this or any problem with the machine, especially with it only being 10 days old. Take it back for an exchange. Demand an exchange and don't let them give you the run around. When you get the new machine, you will see that you shouldn't have any problems with it for years to come. Also, don't let this bother you about Dell machines, they're one of the best machines on the market. Just like everything else, there are a few lemons.
Jul 25, 2008 | Dell Computers & Internet
Dell dimension 8440
Do you have any USB devices connected to your computer. Disconnect your USB devices and restart your computer. Keep tapping the F1 key to go to the BIOS. Fress F5 and then F10 and wait till the computer boots to the desktop. And check if it would still shut down. If yes, then probably the issue is with the motherboard.
Jun 05, 2008 | Dell Dimension 8400 PC Desktop
Won't boot Dell 8400
Could be power supply, video or power switch to name a few. See this diagnostic chart.
http://www.fonerbooks.com/power.htm
Dec 29, 2007 | Dell Dimension 8400 PC Desktop
Dell Dimension 8400 PC Desktop Logo
167 people viewed this question
Alun Cox
