FixYa.com
Tags:
LG RH1999H DVD Recorder / HDD Recorder
Blank DVD discs that used to be recognised are... (by 2 users)
posted by debchocolate on Oct 14, 2007
Blank -rw and +rw discs that previously were able to be read in my LG RH1999H suddenly are unabel to be read. I also had to key in a cheat code to get it to read region 4 DVDs as it had stopped playing most DVDs that it previously played.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by Guest, posted on Aug 23, 2008
Blank DVD discs and discs copied on my LG that used to be recognised are suddenly not able to be read
Best Solution
posted on Nov 01, 2007
Helpful (85)
AllTaken
Rank:Apprentice Apprentice
Rating: 85%, 1 votes
I've found that once a disk is formatted in certain formats with a pc it prevents the LG from reading it.  Format it again in the LG (if you can!) or use the pc to format it using the UDF1.5 setting in a pc (which sort of resets it so the LG can at least see it as an unused disc again).
All in all I have found my RH19991H really confusing as far as disk initialization and formatting and finalizing is concerned.  Sometimes you can select to finalize a +-rw dvd and sometimes not (the latter is the the case according to the manual) and sometimes I can select the format mode and sometimes not.  Sometimes the machine auto finalizes the dvd+-rw (the way it should be says the manual) and sometimes it does not and then I cannot use it in the pc.  I have also created some disks with DivX files and was able to play them in the LG and then using the same pc, same type of discs, same video editing software and same settings created other DivX files I could not play on the LG.  It seems the software on the machine needs some work...
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Nov 02, 2007
Thanks for Trying (70)
Guest
Guest
Rating: 0%, 0 votes
I worked it out - the problem was a fault with the machine. Apparently pretty comon. I sent it back to LG and they returned it fixed.
Can you Help with these DVD Players problems?
live in region 2 want to play...
i have a phillips dvd player... Answer This...
LG RH1999H DVD recorder/player...
When the power fails, I lose... Answer This...
lg dvd player rh1999h
my dvd player will only player... Answer This...
Problems with dubbing from HDD...
Hi. I have a problem with... Answer This...
Doesn't regognises disks, keeps...
My LD RH1999H recorder has just... Answer This...
Repair Service
Find DVD Player Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
