Question about Pentax Optio 33LF Digital Camera
Pentax otio 33lf camera suddenly won't go
The camera was on, I inserted the scandisk 256 card, the camera screen said 'card is not formatted', then it shut down and has so far absolutely refused to switch on again,new batteries unsuccessful.
Any ideas?
  • Deemoe1 Jan 25, 2008
    I am having a similar problem now. I put a new 2.0 GB in May (mother's day) and it was fine. Recently put new batteries in it, Had not used it in about 2 months, and the camera won't even turn on. It just beeps. At first the lens would come out and go right back in and then shut off. Now it won't even turn on at all. I'm the only one that uses it, so nothing untoward has happened to it. I took the card out and tried it. It doesn't work. Not sure what to do now! I tried what you suggested ...nothing ... anymore suggestions?
Try removing the card and see if it will turn on with just the internal memory--or try different memory card if you have one.
Had a somewhat similar problem with a new 1GB card when I shut camera off while it was still saving an image. Camera would come on, take a picture all by itself and freeze up. After using a couple of other cards it magically worked on the bad card
gmcn
Posted on Dec 08, 2007
Sd card not formatting
Are you sure your card is an SD card and not an SDHC card? The 33LF works with SD cards, 2GB or smaller. It will not work with higher-capacity SDHC cards.
Sep 21, 2013 | Pentax Optio 33LF Digital Camera
This camera accepts a 512 mb sd card maximum. If you try 1 GB or bigger, takes a couple of shots and freezes.
Mar 08, 2013 | Pentax Optio 33LF Digital Camera
It says card not formatted. why/
There are several possible causes for "memory card locked", "memory card error", "not formatted", or "no memory card". The most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out. Other causes include problems with the tiny slide switch on the side of the card, or the electrical contact switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link.
Jun 06, 2011 | Pentax Optio 33LF Digital Camera
When I put my 2gb Sandisk memory card in my pentax optio 33lf, it turns on, the lens goes out, it takes a photo and freezes. What is the problem? If I take the memory card out, it works fine?
My 33LF won't work with even a 1gb Memory Card. It freezez up as you describe.So far it seems happy enough with 512mb cards. A camera shop operator told me that the capacity of the card exceeds the capacity of the camera and it seems he was right.
Jan 08, 2011 | Pentax Optio 33LF Digital Camera
How do I delete the pics from the memory card in my Pentax Optio E60 camera
The easiest way to erase the entire card is to go into the menu and find "format"...follow the on-screen instructions
May 05, 2010 | Pentax Optio 33LF Digital Camera
How do I upgrade the firmware on my Pentax Optio 33LF? Camera goes crazy. Does not recognize any more my SD card (2 Gb)and I'am afraid to loose the photos. I hope if I upgrade the firmware ( vers...
According to the Pentax web site, there is no firmware update available for the 33LF camera. As far as your pics are concerned, you can use a card reader to download them to your computer. Then, you can format the card in the camera and everything should be ok.
Jan 09, 2010 | Pentax Optio 33LF Digital Camera
SD card problem
here is a list of compatable memory cards
http://www.4allmemory.com/index.cfm?fuseaction=search.memorySearch&model_id=42425
.. any SD or MMC card should work up to 4 gb ... so your 2gb should be ok .. i suspect that it may be damaged .. you can try formatting it in a USB card reader if you have one on your computer .. some laptops have the SD slot built in .. there was some compatability issues with memory cards for older cameras but there shouldnt be any with such a new machine .. make sure the contacts are clean and the "protect" switch (if any) is in the unprotected mode .. when you format the card it may take several minutes so give it time .. if you are going to take movies then its better to use a "high speed" SD card .. like the 133x mentioned in the above URL .. slow memory may cause missed frames or 15 fps instead of 30 fps record rates.. .
the specs on your camera do show SD and MMC compatability .but they dont show any brand preference .. .
Oct 06, 2009 | Pentax Optio 33LF Digital Camera
Won't turn on at all
My Optio 33LF gave the same "card not formatted" message and then shut down completely at a family party.  I took it to the Pentax Canada depot which is nearby and the technician said the main circuit board was gone.  A C$130 part + labour estimate = time for a new camera !
Sep 17, 2007 | Pentax Optio 33LF Digital Camera
256 Sandisk SD card problem with an Optio 33LF
Optio 33LF Firmware Upgrade Information & Instructions: This firmware corrects "camera freezing & cannot display images" issues with Sandisk & Black's 128MB & 256MB Secure Digital Cards. This problem is occurred because Sandisk changed the manufacturing location from the Philippine's to China during production of the Optio 33LF. They also change the electronic chip used the SD Card which caused a compatibility problems with Pentax, Minolta, Palm and other digital device manufacturers. In turn this also caused a problem with Black's SD Cards as they are manufactured by Sandisk. Therefore, we had to release a Firmware Upgrade for the Optio 33LF to correct compatibility issues with these SD Cards. HOW TO CHECK WHAT THE CURRENT FIRMWARE VERSION: Confirm the current firmware version by pushing and "HOLDING DOWN" the "Right Arrow & Right Zoom" button located at the back of the Optio 33LF. While continuing to hold the "Right Arrow & Right Zoom" button turn the POWER on the Optio 33LF. The current firmware version will be displayed on the LCD. If the firmware version reads "Current Version 01.01.05.04" then your cameras firmware is up to date. If you do not have the current version, then please refer to the information listed below. Please be sure to upgrade your camera. You can download the firmware from the following link. Please be sure to follow the instructions listed below. Firmware Download: http://www.pentax.ca/support/digitalsoftware/fwdc113p.elf Firmware Update Instructions: Please refer bellow to learn how to upgrade the firmware on the Optio 33LF. Should you have any problems please contact our customer service department. I have included our contact information bellow. PLEASE NOTE: 1. It is very important that the batteries do not deplete during the firmware upgrade as this will damage your camera. Therefore, please check your battery indicator prior to the firmware upgrade. FIRMWARE UPGRADE #1. Save the attached firmware "fwdc113p.elf" to your Desktop. #2. Put a Secure Digital Card in your Camera. #3. Format the Secure Digital Card to be sure that no other information remains on the Card. (Refer to page 86 of your Operating Manual) #4. From your Desktop right click on the firmware "fwdc113p.elf" and select "COPY" #5. Double Click on "My Computer" you should see your "REMOVABLE DISK" #6. Right Click on the "Removable Disk" and select "PASTE" Once the "fwdc113p.elf" file has been copied to the Secure Digital Card, be sure to properly disconnect your USB device if you are using Windows Me, 2000 or XP. For instructions on how to disconnect a USB device with Windows 2000, please refer to the Optio 33LF Operating Manual. Now that you have the Firmware on the Secure Digital Card. #1. Be sure the Secure Digital Card containing the Firmware Upgrade "fwdc113p.elf" is in the camera. #2. Be sure that your batteries are fully charged as you do not want the
Sep 08, 2005 | Pentax Optio 33LF Digital Camera
Pentax Optio 33LF Digital Camera Logo
93 people viewed this question
Top Pentax Cameras Experts
mohamed salim shaikh
Jerry Greenberg
Jerry Greenberg
Are you a Pentax Camera Expert? Answer questions, earn points and help others
