Question about Mitsubishi WS-55805 55" Rear Projection Television
During a power surge my tv turned off and it wont turn on now at all
Our Tv turned off during a surge problem with our electricity our other tv came back on but the mitsubishi never did. We had never had any problems with it prior.
I have a rca television and my t.v. just cut off when i was looking at it and , when i tried to cut it back on, there was no sound and no picture and the power button did not want to cut off on it's on i had to unplug it.
Posted on Jul 28, 2009
Please my tv with on the standby mode when i try to put it back it couldn't the indicator now goes on and off with picture show please help
The standby light on a Sony television indicates when the television is turned on and operating, or turned off and in "standby" mode. However, this light also serves a secondary function: indicating when there is a problem with the television by flashing. When the standby light begins to flash, there are two reset options that can be performed to resolve whatever issue it's indicating -- a power reset and a factory reset
POWER RESET
1. Turn off your TV
  • 2. Unplug the television from the electrical outlet. If you're using a surge protector or power strip, disconnect the television from the strip itself. Only by disconnecting the power cord from the outlet can you ensure no power reaches the TV during the power cycle.
  • 3. Leave the television without power for at least 60 seconds. This gives the television enough time for all components to power down during the power cycle
  • 4. Plug the television back into the electrical outlet. If you're using a surge protector or power strip, plug the television directly into the wall outlet instead. The surge protector may otherwise interfere with the power-up cycle, especially if it is old or damaged.
  • 5. Turn on the television. If the blinking standby light continues, you'll need to move on to the factory reset process.
  • FACTORY RESET
  • 1. Turn on the television.
  • 2. Press and hold either the "Reset" or up arrow button on the remote control.
  • 3. Press and release the "Power" button on the front of the television, while keeping the "Reset" or up arrow button on the remote depressed.
    4. Release the "Reset" or up arrow button.
    5. Allow the television to reset after the "Reset" message appears on the screen.
    6. Make no adjustments to the television for at least one minute after the reset has completed. This is to allow the television time to finish auto-configuration and initial set up.
    7.Turn off the television and unplug the power cord from the electrical outlet.
    8. Wait ten seconds, then plug the television back into the electrical outlet and turn on the TV.
    9. Follow all on-screen instructions to complete setup. These are the instructions displayed the first time you set up the television, for configuring channels, menu language, time, display properties and more.
  • Dec 30, 2014 | Sony FD Trinitron WEGA KV-32FS120 32" TV
    Sony KDL 46HX820 turns on, then off and red light blinks four times.
    Re: Bravia KDL46EX720. Red LED blinks 4 times and TV wont turn on. What is the problem?
    Do a Power Reset.
    1. Turn off the TV.
    2. Unplug the power cord of the TV from the electrical outlet.
    3. Let the TV remain without power for 60 seconds.
    4. Plug the power cord back into the electrical outlet. (If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.)
    5. Turn on the TV.
    If the issue still persists after performing power reset, that may be an indication that the TV needs service. You may refer to this link to locate the nearest Sony authorized service center in your area.
    Oct 21, 2014 | Sony KDL-46HX820 - 46" BRAVIA 1080p LED...
    A power outage last night. The tv was off, now it wont turn on. A blinking timer light on the front of tv is on.
    Always include model numbers since problems are sometimes associated with particular models. This may be a sign that a line surge during power fluctuations has damaged the power supply. There are a least two supplies in any modern set; a small supply that provides voltage to the remote circuitry and this one is always on. The second supply is the main one that is turned on when the set is to be used. Reluctance to turn on is often a signal that certain components (capacitors) are failing in the main supply and they will continue to degenerate. Try pulling the plug and leaving the set overnight without any power. If a circuit is only 'confused' (locked up) this should reset everything. If it still will not turn on, then either the small supply for the remote circuitry was damaged during a surge or that the main power supply is not responding to the power on command.
    Jun 09, 2011 | Mitsubishi Televison & Video
    Tv was surged via hdmi by electrical storm. The tv appears to power on and then shuts off within 4-5 seconds. The screen looks as though it is turning on during this process, but doesnt stay lit long...
    Unplug tv and cable box.Replug both about an hour later.Still have the same problems.The power supply board is dead.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply for the replacement.
    Aug 13, 2010 | LG 50PS60 50 in. Plasma HDTV
    Does my samsung tv keeping turning itself off because of not having plugged it into a surge protector or is it more a fault with my tv
    It is a fault with your power supply module actually inside the tv...take it to a local service center or if its under warranty take it back. surge protectors help prevent issues like this occuring due to damage to the power supply from surges but not having one wont cause these problems unless it has recieved a surge.....in future i would use a surge protector on all your expensive appliances, surges and power fluctuations are very common in mains power i live near the mines and we have power problems all the time!! hope this helps,ben
    Aug 11, 2009 | Samsung LE40R74BDX 40 in. LCD Television
    My tv won't turn on after it went out during a
    Leave the TV off and unplugged for 24 hours then try it. If it still doesnt work you may need to consult an engineer. The TVs power supply board may have blown due to power surge/spike. I recommend getting a surge protector to avoid this happening in future.
    Jul 10, 2009 | Panasonic Televison & Video
    52" LG DLP
    you may have had a power surge
    Jun 17, 2008 | LG RU-52SZ30 52" Rear Projection...
    Tv wont power up makes a noise but no picture
    Your power transformer is likely shot. It'll cost at least $200 to have it replaced. Someone can come to your house to diagnose it. Usually costs around $65.
    Nov 03, 2007 | JVC AV-56WP74 56" Rear Projection...
    Blinking light wont turn on Toshiba TV CE19H15
    Yes, it's quite possible that you indeed may have sufferd from a Power Spike, induced by lightning during the storm, esspecially if plugged in during said storm. I have had quite a few customers ova the years with this exact problem. I always advise my clients to unplug ALL devices during a storm, and for ones that simply cannot be unplugged then some sort of Spike/Surge Protection device MUST be used. As a matter of interest, I have written many a report to insurance companies to support a claim for a replacement.
    Aug 08, 2007 | Toshiba 19A26 19" TV
    Mitsubishi WS-55805 55" Rear Projection Television Logo
    507 people viewed this question
    Top Mitsubishi Televison & Video Experts
    matt martin
    matt martin
    Jaime Hernandez
    Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
