Question about IO Magic Corporation GigaBank 8.0 IUSB8HD10 Hard Drive
Wont show at all (E drive ) when i go to my computer
It is not detected by my laptop ..but if i put on another it is detected  help
    Brigadier General:
  • 6,966 Answers
Possibly 2 reasons:
1. A tweaking utility (such as TweakUI) was used to remove drive letter assignment.  You need to use the same utility to restore it back;
2. USB port error which could either be software or hardware:
2.1 Software - try uninstalling all instances of the USB in your Device Manager, reboot. Windows will autodetect and auto reinstall;
2.2 Hardware - the port(s) could be faulty which could either be the +5V supply (which would mean a burnt surface mounted fuse or fusible link) or the I/O where the data pins go to.
If you have other USB devices and they work, then chances are it's #1; if they also do not work then it's #2
Hope this be of some help. Post back how things turned up or should you need additional information.
Good luck and kind regards.
Posted on Oct 15, 2007
Acer aspire 7736/7736z series wont boot and operating system not found. Tried f8 just keeps beeping. Help.
First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Feb 19, 2013 | Computers & Internet
My installed formatted hard drive won't boot!
maybe the HDD was the problem... but try your HDD to other laptop instead.. but if still it wont show/detect.. so i guess the HDD was the problem... so if the problem is the HDD.. all you need to do is to replace it....or you can contact your dealer..
Aug 06, 2012 | HP Compaq NC6220 Business Notebook
Gateway mp8708 s/n t23691006485 showing disk error won't boot just shows disk error help me
First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.
Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
May 20, 2012 | Gateway Computers & Internet
My hp laptop shows non system disk or disk error
First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
Apr 04, 2012 | HEWLETT-PACKARD MINI 5103 Netbook
It wont detect a dvd on my acer aspire 5315 laptop
If your laptop won't detect DVD drive try and check connection first. Turn your laptop upside down and remove three maybe four screw (deepens on laptop) directly over a DVD drive and pull drive out. Blow some compressed air inside of laptop and check for anything abnormal on drive itself. Then put it back in and check if it works. If not it's either bad DVD drive or bad motherboard. Thanks and good luck.
Apr 17, 2010 | Acer Aspire 5315 Notebook
My Maxtor Hd Wont show up anywhere in my laptop when i plug it in
it should still detect even though your using vista does your bios setting have usb2 enabled?? otherwise try a different usb port
Jun 17, 2009 | Maxtor OneTouch A01B080 80 GB Hard Drive
My Acer Aspire 5100 Laptop wont detect the hard drive
If it works on another computer then either the ide cable in the acer is bad/loose at either end or the ide controller on the motherboard is bad. I would try a known good ide cable first as if this is the problem it is fixable alot cheaper than a motherboard. Hope this helps.
Mar 27, 2009 | Acer Aspire 5100 Notebook
No bootable device--strike f1(please help)bios wont read cd or hd
I think your lap top fails to detect your hard disk. Enter Bios settings and confirm that the hard disk is detected.
Mar 25, 2009 | Dell Inspiron 2200 Notebook
Acer aspire can't find the dvd to play cd's
Most likely the drive is dead, they die from time to time, sometimes they can last years and sometimes but less frequently they just go belly up one day and its very typical for the Cmos and computer to recnognize there is a device there, but Windows cannot access it at all. Try purchasing an external USB or Firewire if your PC has a port for it - and you can then access your CD/s that way. Otherwise, you can purchase a new drive and have it installed. Locating the drive replacement may require some research and time depending on the notebook's specific model number. Also check to see if your PC is still under warranty by any chance, that drive would be covered in most cases.
Mar 22, 2009 | Acer Aspire 5315 Notebook
In the device manager, select the DVD ROM and UNINSTALL / REMOVE the device.  Restart Windows . . . did this work?  If not, boot into your CMOS and see if the drive is being detected by the motherboard... if yes, look further and make sure the settings for the drive are correct. Make sure that all IDE interfaces are enabled in the CMOS settings (both)
Dec 13, 2008 | Acer Aspire 5315 Notebook
IO Magic Corporation GigaBank  8.0 IUSB8HD10 Hard Drive Logo
151 people viewed this question
Top IO Magic Corporation Computers & Internet Experts
Mohamed Ismail
Mohamed Ismail
Falling star
M_Butkus
Are you an IO Magic Corporation Computer and Internet Expert? Answer questions, earn points and help others
