Question about Frigidaire 24 in. FDB750RCC Stainless Steel Built-in Dishwasher
Water standing in dishwasher. 1st time ever. What to do.
Water is in the dishwasher. I have removed filter and found grit removed as much as possible. Water is still there.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,632 Answers
Re build pump by changing the impeller. Vitally
Posted on May 13, 2009
Grit left on dishes
The arms do accumulate gunk that clogs the sprayers. Disassembly, cleaning and reassembly are not difficult.
However, I think that your problem may be in the main filter and strainer, which are located around the base of the bottom arm. Download the diagram of the model and remove, clean and reassemble. My bet is that you'll find a layer of sediment in the filter that can be removed with a soft brush and running water.
If you have pets that shed, be ready to find fur in the filter.
Nov 30, 2013 | Maytag 24 in. PDB1420 Built-in Dishwasher
The washer fills and runs through the cycle but leaves a grit on the dishes
If detergent is left in the compartment:
? Be careful not to load items so close to the dispenser
that the cover will not open to release the detergent.
? The dispenser is not supposed to open when you
use the Rinse program.
? Your dishwasher detergent should be fresh and
stored tightly closed in a cool, dry place. Old or caked
detergent should be thrown away because it will not
dissolve properly and will leave a gritty residue on
the dishware.
? Wait until you are ready to start the dishwasher to
add the detergent.
? If you are using the Delay program, make sure the
dispenser is dry before adding the detergent.
? The detergent compartment only opens in the main
wash programs, not the Rinse program.
YOU MAY NEED TO CLEAN THE FILTERS MORE OFTEN
IF YOUR AREA HAS HARD WATER
This can cause low water pressure.
In hard water areas, it may be necessary to clean chemical buildup from the filters every 12 to 18 months. To do this, remove the coarse filter by squeezing the
tabs and lifting it out. Next, unscrew the fine filter and lift it and the main filter out. Wash all three filters gently in hot, soapy water and rinse them thoroughly.
Your spray arms may be clogging causing low pressure too.
Spray-arm jets and bearings may sometimes become clogged with hard water chemicals. To remove the spray arms, screw off the nut and take off the washer on top of the spray arm and lift off the arm. Wash the spray arms in warm, soapy water. Use a soft brush to clean the jets. Rinse thoroughly and replace.
Try cleaning the drain pump so it gives you more water pressure.On occasion something may get through the filters and into the drain pump. The drain pumps on ASKO dishwashers are designed to automatically reverse if anything should get caught in the propellers, thus ejecting the item back into the sump area or down the
drain. Should you need to remove an obstacle from the drain, first turn the power off then remove the filters . Next, lift out the small black insert
from the sump area. (You might want to remove any standing water first.) You can then look into the sump area for the item causing the obstruction. Should you
find something, simply scoop it out. Be sure to replace the black insert before you put the filters back in.
You could also try to clean the dishwasher with ' Dishwasher Magic '. This would work like charm :-
http://www.dishwashermagic.com/
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Nov 26, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
Dishwasher deposits dirt on dishes. Grit, small particles.
I have the same problem. We cleaned the dishwasher out because the grit was coming from the dishwasher...however, we still have dirt/grit in our dishes, but a lot less. How do we get rid of this all together?
Oct 03, 2010 | Maytag Dishwashers
Dishwasher pump keeps running
This is caused by a water leak into the base pan,it will trigger the anti flood and the machine will continously drain out even with the door open,you need to establish what is leaking,if you leave the appliance standing for a few days it will start again as the water will evaporate however if the fault returns you will definetly have aleak on the appliance which will require further investigation.
Jul 29, 2009 | Neff 24 in. S5443X2 Built-in Dishwasher
Kenmore portable dishwasher not working
THERE IS A PLASTIC COVER GRATE IN THE BOTTOM OF THE DISHWASHER TAKES A 1/4 INCH NUT DRIVER TO REMOVE IT, TAKE IT OFF CLEAN OT THE DEBRIS AND FLUSH WITH A BUCKET OF WATER, THIS IS SUPPOSED TO BE THE FILTER, IF ANYTHING IS IN THERE YOU WOULD BE ABLE TO SEE IT, I HAVE FOUND STRAWS AND KNIVES IN SOME DISHWASHERS, HOW THEY GET IN THER IS A MISTORY BUT THEY DO
May 29, 2009 | Kenmore 17252 Free-standing Dishwasher
Standing water in the bottom of the dishwasher
I had the same problem - a 10 minute fix. The issue tends to be that the trap gets clogged by debris (like broken glass etc.) and restricts the amount of water that can be evacuated by the tub.
1. Undo the trap cover (two hex headed screws)
2. Remove the trap cover
3. Remove the inner trap grate
4. BE CAREFUL NOW ! Gently remove debris - this can have broken glass in it !!! - You can use a wet vac if you have one. Ensure all debrs is removed and the trap is clear.
5. Clean trap cover and grate
6. Re-install cover and grate
7. Bingo !
Apr 20, 2009 | GE Nautilus 24" Built-in Dishwasher
Dishes all cloudy and spotty. Maytag Intellisense plus 1996 dishwasher. I have real hard water that leave white calcium build up. I can remove and clean all of the lower spray arms and filter. How do I...
The problem is hard water. Go to www.dishwasherfilter.com. They have a new product out that solves this problem once and for all. It filters the water entering your dishwasher and removes the hard minerals that cause these spots. Very affordable and guaranteed to leave your dishes looking amazing every time.
Mar 11, 2009 | Danby 22 in. DDW399 Free-standing...
Dishwasher gets no water
It is no fuse in dishwasher.
Solution1: Check if the inlet line to d/w is open(usually it located under the sink)
Solution2: To rich a fill valve filter:
1. Shut off water to d/w
2.open kick panel under front door of d/w
3.disconect the water line on left hand side
4.pull filter from center of water valve by nose pliers
5. clean the filter by old toothbrush under the sink
6.put everything back
7. if does not help the water valve needs to be replace
Nov 29, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
A01 warning on constantly. Just appeared dont know to fix
Have you checked there is no water in the base of the machine?
There is likely a float in there which activates a microswitch turning on the drain pump.
You could try tilting the machine through 45 degrees and see if any water comes out.
It could take only a cupful of water inside the base of the machine to trigger the safety switch
Dec 27, 2007 | Indesit 24 in. DE73 Evolution...
Frigidaire 24 in. FDB750RCC Stainless Steel Built-in Dishwasher Logo
305 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Robert Roath
Robert Roath
Level 1 Expert
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
