Question about LG Heating & Cooling
LG LS-Q09BUL INVERTER AIR CONDITIONER
PLEASE CAN ANYONE HELP.
I have turned the power on and of a few times to my air con unit and now it wont come back on, inside the outside unit there is a LED01M flashing 5 times thats the only indication i have.
previous info returned with a problem on the serial connections i presume this is the inter connect from outside unit to inside unit checked all connections and they seem ok.
for help would be great.
thanks
  • 400 Answers
This is possibly either a complete outdoor pc board error or an E-Prom error on the indoor pc board. You can try shutting down supply power completely for a minute and then switch on. These units also have a delay timer system which does not like to be switched on, off repeatedly in a short period. Please also check for reset button on the outdoor pc board. Hope this helps.
Posted on May 14, 2009
LG LS-D2461HS air con on turn on just blows air out. no heat or cod air at all even when temperature setting increased to 30 degree for cold air.
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Jun 27, 2011 | LG Heating & Cooling
Hello, I have an LG Inverter Air Conditioner - LSR122V-4 and it is only turning on for 10 minutes at a time then switches itself off and the 'power indicator light' flashes slowly. Do you know what the...
Hello, I have an LG Inverter Air Conditioner - 24BTU and it is only turning on on the inside unit. When I look on the out side unit and I see a 'red light' on and no working.
Do you know what the problem could be?
Thanks,
Gil
Feb 03, 2011 | LG Heating & Cooling
Air con unit saying 'C6"
According to the service manuals:
6 is:
Excessive current at inverter
DC power circuit
so the unit shouldnt run?!?
The fault is also coming up as:
indoor unit coil sensor faulty
source:
http://www.mylg.co.uk/data%20for%20site/LG%20Fault%20Codes%20for%20SMS%20%2807%20Sept%29.pdf
all the best
Jul 05, 2010 | LG LSC183VMA Split System Air Conditioner
I have a split system model ls-k2464hl the remote works but will not turn on the unit.The unit will force run but only in cold
It sound like a defective receiver pcb. Have this professionally checked. I take the time to help, so please rate me!
Jun 15, 2010 | LG LS-K2430HL Heat Cool Mini Split Air...
ERROR CODE CH5 AIRCON SPLIT LG
This error is a communication error between your indoor and outdoor unit. You can try turning the breaker off for a few minutes and restart the unit. However if that does not work its best suggested to have an authorized HVAC technician service the unit.
Dec 24, 2009 | LG LS-L1210CL Mini Split Air Conditioner
Power led flashing on air conditioner
This generally indicates a fault with the unit. Have you tried cleaning the air filters inside the indoor unit. This may help. Otherwise call Kelvinator or LG as they have similar unit and ask for their help and if it can't be rectified call for service.
I take the time to answer your question, so please rate me.
Thankyou Mat
Aug 24, 2009 | Heating & Cooling
Cant turn air con of with control
if the remote is lg it haven't code the eye of the plate has burned
Feb 21, 2009 | LG LS-L1210CL Mini Split Air Conditioner
LG Inverter A/C Unit LSJ092V-3
I would first check the condensate drain pipe. This can be done by blowing back into the drainpipe from outside. Not to worry it is not dirty or dangerous. Also make sure that your air filters are clean.
Feb 19, 2009 | LG LS-L1210CL Mini Split Air Conditioner
No Display on controller
Try replacing the battery but if it wont work you need to replace the remote control itself, but for the main time you can operate the unit by pressing the emergency switch button to operate the unit manually.
Jan 09, 2008 | LG LS-L1210CL Mini Split Air Conditioner
Heating & Cooling Logo
806 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
