Question about Samsung YP-K5 MP3 Player
YP-K5JAB not detecting....
When I connecting via USB my Yp-K5JAB and go thru the NEw Hardware installation (running WinXP) it goes thru the install process and comes back with MTP Device ca not be installed...Subsequently I can not transfer firmware update or anything else - device is useless!!! at the moment.
  • LlamaLlama Nov 24, 2007
    The problem is that it doesn't appear in the My Computer list as a device.
  • 156 Answers
After installation u get a disk drive in ur 'My Computer',just drag & drop audio files to respective folder and enjoy
Posted on Oct 23, 2007
System says fully charged when it is not
have you tried updating the firmware? Go to Samsung.com support > download center > type in the model number (yp-k5jab) click on firmware, and download the version that corresponds with your device. install the firmware updater on your computer, plug in your device. and flash the firmware. (this will erase ALL songs and settings so you will want to back those up first). After that its like brand new. Keep the updater handy, since this might crop up again.
Dec 23, 2008 | Samsung YP-K5 MP3 Player
Samsung YP-Z5F MP3 player malfunction
I have that kind of Mp3 Player too... that happened to me, but the PC was able to read mine. However, the reason why the message: "Low Battery USB Disabled" appears, is that you still have remaining battery life, but will only last for less than an hour (indicated by low light and red empty battery sign) you have to make sure the Mp3 is completely discharged. (you'll be notified when you turn on the device while it says: "Low Battery") once that it is completely discharged, you can now plug in the USB cable with the device to the PC... if problem persists, check your PC.. can it read the device? Check if a notification balloon appears at the bottom right corner of the monitor screen. It should say, "Found New Hardware... Samsung YP-Z5F..." if it did not appear, try to INSTALL using the Installation CD given when you bought the product. Just insert the disk into the PC and continue on, then when it is already installed and ready for use, plug in the device! This may be a little hard, but this is the only way I know. Feel free to ask me! I am no technician but I know a lot on devices and fine mechanics. Good luck!
Oct 11, 2008 | Samsung YP-Z5 MP3 Player
Samsung yp-k5jab/xef
I lost the driver and i cant find my samsung in my new computer.
Sep 21, 2008 | Samsung YP-K5JAB MP3 Player
USB connection problem
my YP-U3 player will not connect via my USB port. When plugged in to a port that connects my digital camera normally it first says on screen "USB Connecting" then changes after 2 to 3 seconds to "disconnected - Charging". it has fully charged and no change. I have checked the hold switch is disengaged. the media studio software is installed ok and the portable devices functions are greyed out. I cannot find the device on my pc. I am running Windows XP SP2. I will be returning it to the store where it was purchased very soon if i cannot find a solution. I notice there are a lot of people who have posted similar problems that have not recieved solutions.ya i have th same problem im using window xp 2
Aug 30, 2008 | Samsung YP-U3 MP3 Player
I think I got it guys. forget WMP 9,. 10 , 11... I run win xp service pack 2 and could not install the samsung yp-u3 player. I kept having it found as a new hardware {portable device} but as we all know this software has no drivers, and the windows update produces MTP device error. Resulting in you not being able to see your player in XP. Well go to windows update site and search for a file called "mtppk12.exe" I'm pretty sure once you install that file and reboot, you will no longer have MTP device errors. However, I installed this at the same time i installed windows media player SDK. So maybe both files are required. Finally after 2 days of troubleshooting i got mine to work.
Jul 29, 2008 | Samsung YP-U3 MP3 Player
Samsung YP-K5JAB
Either the device is bad, the pc port is bad, or the software is faulty. Try connecting to different usb port, then a usb port on a different pc with a compatible os. If still not recognized, then there is physical damage to player.
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware.
Wizard
Jun 10, 2008 | Samsung YP-K5JAB MP3 Player
Locked YP-K5JAB MP3 player
There is a lock/hold switch that is engaged - look at the user's manual to see the location of it
Mar 27, 2008 | Samsung YP-K5JAB MP3 Player
Wizard
Nov 22, 2007 | Samsung YP-K5JAB MP3 Player
Samsung YP-K5 MP3 Player Logo
Top Samsung Audio Players & Recorders Experts
Marvin
Marvin
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
