Question about Microwave Ovens
WON'T HEAT OR CLOSE DOOR PROPERLY. ALL ELSE SEEMS OK
  • 431 Answers
Well firstly if the door wont close properly you shouldnt use this device as if you are in the kitchen whilst it is in use your slowly cooking yourself . If the door is open microwaves can escape and that is Radiation Lethal if you get too much or too close ?.
The reason it is not heating is probably because most of the microwaves are escaping and not bouncing around your oven cooking your food .. but actually bouncing around your home cooking you . My advise to you is get it repaired by a qualified Domestic appliance engineer or bin it and get a new one ..
Regards Vortash
Posted on May 13, 2009
Sharp microwave wont heat at all.
looking for a tray or plate roller wheel for a Sylvania model SM81001 ser. no. 0008001033
Nov 24, 2013 | Sharp R-1870 Convection/Microwave Oven
I have a Haier microwave and tonight after heating some food, I went to close the door and upon closing it, the carousel started turning and it won't shut off.
It sounds like one of the door switches has become defective, each must be disconnected on the one side and tested with a digital meter using the ohms scale.
Jun 07, 2012 | Haier Microwave Ovens
Oven won't shut off
One of the door switches is defective, caused by a build up of food particles or normal ware, to correct this a professional will need to identify the problem and replace it.
Mar 07, 2012 | GE Advantium 120 Convection/Microwave Oven
My GE Spacemaker microwave just stopped heating. It is only a couple years old. Could this be a simple fix or should I just go ahead and purchase another (not GE)?
Check the door safety intelock switch. You will have to remove the cover to find these micro switches (opposite the hinge side of the door). You will need to use a ohm meter to determine if they are working properly or not.
These switches tell the oven that the door is closed and when closed, it if OK to turn on the magnatron.
If you need more help, post a comment here
thanks for posting your question here at FixYa.com
Dec 23, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
My JVM1851 model is 7 years old. Everything is working (light, fan, clock, etc). But food does not cook or warm. no heat!!!
As I understand your trouble, your 7 year old microwave does not heat.
I have found the most likely reason for this trouble is a burned door safety interlock switch.
To fix this trouble, remove the cover, find the switch opposite the door hinge. Test the switch for proper operation. You will need a continuity tester or a volt/ohm meter for this.
Let me explain what happens and you will be able to apply this to your situation. When you close the door these switches tell the oven the door is closed and it is ok to turn on the magnatron. If the switches are burned, they cannot tell the oven the door is closed - door not closed, no magnatron, no magnatron, no heat.
Why do they burn? Do you open the door while the oven is in operation? If you do, there is a spark at the tiny micro switch contact and they start to burn. Eventually, they will not close properly.
You can find replacement parts at a FixYa.com advertiser or a appliance parts store in your area or at www.repairclinic.com
The next most likely problem is the start capacitor. This is the silver can inside. Please do not servic this item unless and until you understand the danger associated with it.
This device stores a very large electrical charge. Modern capacitors are supose to drain off the power after a certain amount of time. Some say it is OK to drain the opwer by shorting with a screw driver to ground. Frankly, I'm not a fan of this method. Please try the switches first ... if that doesnt work, post a note here and we can go to the next step.
I hope this solves your trouble and you are able to get your oven back in operation. If you will search this problem here at FixYa.com, you will probably find other ideas from other volunteer workers.
Thanks for using FixYa.com. Please vote
thanks
a
Nov 09, 2009 | Microwave Ovens
Everything seems to work but not heat
the switch is ok. if it was bad itt would blow the fuse. ge had magnetron problems on the 1600 series. if you have an amprobe and are getting 110 volts from the control to the transformer. place the probe around just 1 wire to the transformer. if you get less than 12 amps replace the mag
May 18, 2009 | GE JVM1650 1000 Watts Microwave Oven
MICROWAVE NOT HEATING
I have the same problem. Everything seems to work except it doesn't heat up food.
I remember last time when it was working. I pressed the start botton before I closed the door. So it didn't start automatically, and I pushed start and it worked(it still heat up the food), but it doesn't work now. Help Please!!!
I have a Whirlpool Gold GH5184XPQ.
Thanks in advance
Aug 27, 2008 | Microwave Ovens
Microwave will not stop
Sounds like you have a bad door switch.  Will have to take control panel off and test switches resistance to see if they are opening and closing properly.  If a switch is stuck in or bad the microwave thinks the door is closed.  This is where I would start.  Let me know what you find.
Oct 13, 2007 | Sunbeam SBM1000 Microwave Oven
Microwave Ovens Logo
125 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
