Question about Pc Ware PC CHIPS: PC-Chip M957G V1.0/LGA775/PM800/DDR400/A&V&L/MATX Motherboard
Pc-chip m957g when I turn on the power only the fan comes on. power is to hd, dvdr. no post audio beeps, prior to this pressing power button, system came on after several attempts to power it up. also prior to this series of continuous beeps, now nothing cant access cmos, tried switching jumper on bios. no video nothing! any solutions? sam
  • 101 Answers
Sounds like the motherboard has failed. I had those same symptoms this summer. Replaced m/b and it's good again.  Did you count the 'continuous' beeps? That's a code to say what is wrong.
Posted on Oct 14, 2007
Lx6810 blinking power light
Whenyou plug in the power cord is there any lights whatsoever on the laptop, wherethe plug goes in or on the AC Adapter of the power cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous. Most times the problemis with the memory or Video Card. Count the Blinking Lights or Beeps and takenote of their pattern (1 Long or 1 Long followed by 2 Short).
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button.
Maybe you have a Static Charge Buildup. Remove the Power Cord, then Pressand Hold the power button for 30 seconds. After 30 seconds plug the powercord back in and hit the power button to see if it boots. Maybeyour memory is bad or the memory slot is bad.Removethe Power Cord, Open the Case and remove one of the memory chips. Set thechip aside then try rebooting the computer. If it boots, then you knowthe memory chip you set aside is bad so mark an x on it with an ink pen. If it fails to boot then move the chip to the next memory slot and tryrebooting. If it fails take the chip out and set it aside, then put theother chip in and try booting it in both slots. If it boots, just toverify that the chip set aside is bad, mark an x on it and put it into the openmemory chip slot and try booting.
Maybe your power supply is bad. Sometimes there is enough power to make the power light come on but not enough power to make the fan turn on or hard drive spin.
May 10, 2012 | Gateway LX6810-01 PC Desktop
Sony PCV RZ44G irresponsive
Remove the Power Cord, Open the Case and remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.Just because you see lights around the power button does not mean that the Power Supply is ok. I've seen many times when the Power Supply makes the light around the power button come on and makes the light on the motherboard come on, but it does not have enough power to make the Fan inside the power supply come on or anything else.
Apr 22, 2012 | Sony VAIO PCV-RZ44 (PCV-RZ44G) PC Desktop
No video output to the monitor
Dear,
first of all, check if there is any beep sound coming from the board.
Because beep sound represents the error as its code.
After this, check it accordingly. If non of above then board can be problematic. Check it by the way by removing all removable devices like hard disk, cd/dvd rom, floppy etc and let the system ON only for motherboard.
best of luck!
Apr 18, 2012 | PC Chips M957G Motherboard
I just got a usd m957g in an Xblade tower ...and it wont boot i have no beep on power up all the lights are on and i hear the hdd spin up! any one know what i shod do?
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Jan 02, 2011 | PC Chips M957G Motherboard
SATA HDD not connected ?
I had to jumper the drive to slow it down. Then it does not show on the first cmos screen with the dvd drive, but the system does show it in the boot order and does find it.
Mar 12, 2009 | Pc Ware PC CHIPS: PC-Chip M957G...
Power wont turn on with M957G mobo
try and check the manual you will see the picture there thanks
May 16, 2008 | Pc Ware PC CHIPS: PC-Chip M957G...
M957g mb
This is a PC-Chips model M957G and is still in production.
Google is your friend.
Apr 03, 2008 | Pc Ware PC CHIPS: PC-Chip M957G...
Soltek m b
Sounds like your memory.
How many sticks do you have in it?
Try removing all but 1, or moving that 1 around. You'll have to reset the bios and let it set without power for about 5minutes, between each try.
Oct 14, 2007 | Pc Ware PC CHIPS: PC-Chip M957G...
Pc Ware PC CHIPS: PC-Chip M957G V1.0/LGA775/PM800/DDR400/A&V&L/MATX Motherboard Logo
216 people viewed this question
Top Pc Ware Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a Pc Ware Computer and Internet Expert? Answer questions, earn points and help others
