Question about Zyxel P660HW-D1 Router
Problem trying to change the settings in my P-2602R-D1A router.
P-2602R-D1A Zyxel router.
Cleaned my pc and was about to reconfigure my settings.
Ok so Im trying to change the settings in the router. (And ive done it many times before.)
But now its all messed up. Everytime i try to log in its like a 50/50 epic battle ´to see if it will let me enter.
Otherwise I have to reset the router and try again. (so took me about 5 tryes just to get in first time today.)
Then I make the first changes and press aply. Then i try to make the next changes and it shows me a screen saying something like - - -
Object Protected. (ive done it a million times before.)
then i cant do anything. Log off and try to log in again.
Password icorrect.
Great!
Start over. (/- Reset router and fight the battle again -)
Now its done the same thing like 6 times and im about to give up.
So please what could be the error here?
How long after the router resets should i wait before log in`?
And why wont the password work after it says ''object protected''?
For any help there might come. Thanks.
  • iwolfi May 13, 2009
    thx for the effort. But the Download link doesnt seam to work- And searched a little on the net for it. They all lead to the same page. No of another page you know of?
    Sergeant:
    Novelist:
  • 197 Answers
You may want to try updating your routers firmware, it seems like it's gotten scrambled. Here is a link for your routers firmware, click the 'Download' next to 'Description'
http://www.findmysoft.com/drivers/ZyXEL-P-2602RL-D1A-3-40-ADP-1-C0-340ADP1C0-firmware-driver.html
Posted on May 12, 2009
2602 hw d1a
AirPrint Basics
Routers don't have software
Apr 12, 2014 | Zyxel Prestige 100IH Router
How do i accesses my router's configuration page, and how do i find out it's username and password? I have a Lxair b-3000.
If you forgot your username and password to any wireless router, the normal procedure is to do a factory reset. This means it will set the router back to the way it was the day you bought it. Warning: this will forget all the configuration you have done and you will need to reconfigure. If you don't know how to reconfigure then I don't recommend this.
To do this there is a RESET button on the side of the router. Hold it for 10 seconds or until one of the LED lights turns red. Release the reset button and if the SYS LED light begins to blink the defaults have been restored and ZyAir will restart.
If this doesn't work you have a second option
Turn off the ZyXel ZyAir B-3000, then while holding the RESET button turn the ZyAir back on. Continue holding the RESET button. The SYS Led light will begin to flicker and blink rapidly for 20 seconds. Release the RESET button and the ZyAir will restart. Wait for it to restart.
The factory password for the ZyAir B-3000 is 1234
Click here http://192.168.1.2 and type in the 1234 password and click LOGIN. You will probably see a screen to change your password. I recommend you do this.
You will need to reconfigure the router
As I said before change the password from 1234 to something else, plus If there is no security after the factory reset I would read the manual (see below) and setup at WPA or WPA-PSK security on the wireless router (I do not recommend WEP security it is too easy to crack).
You can find the ZyXel ZyAir B-3000 manual here: ftp://ftp.zyxel.com/B-3000/user_guide/B-3000_3.50.pdf
and the
ZyXel ZyAir B-3000 quick start guide here: ftp://ftp.zyxel.com/B-3000/quick_start_guide/B-3000_.pdf
Jan 28, 2011 | Zyxel ZyAIR B-3000 802.11b (ZAB3000)...
How do i change my NAT from Strict to open on my Zyxel P-2602R-D1A ?? so i can start playing Call of Duty modern warfare 2 ?
you will need to change the some settings on the router.
reduce the MTU. If the MTU settings on the router is 1500 then change 1365.
Also you will need to open some ports on the router.
Click here for more info
Nov 14, 2009 | Zyxel P660HW-D1 Router
I am trying to set up the post office preconfigured Zyxel router, but the network found is called 'Setup' and I cannot change it, name field is greyed out - how can I fix this?
hi
plz double chk the enable ssid broadcast is not unchked under w/l setting of ur router settings
or
u can check the firmware of the router and if it is old u can try to upload the firmware from the zyxel website. then u can try to see r you able to change the name field or not
if not
try to reset and reconfigure the router if u can.
gud luck
thanx and regards
sukhiii
Jul 23, 2009 | Zyxel P660HW-D1 Router
Zyxel router disconnecting every 10-15 minutes!
Try to update the firmware of the said router and checked if the connection will be fine. You may download on their website the firmware of the said device.
Jun 26, 2009 | Zyxel P-2602HW Router (P2602HW)
Cant hook up
ok... so im guessing your using sat for internet, so you would set one plug with zyxel PL-100 and it sending signal in, while adding zyxel PL-100 a computer works, and another craps out... Solution: use a router
insert satalite into wan port, set up router
run a client wire from the router to a zyxel PL-100
and the others should pick up off that one..
like so.. :direct from zyxel website specific for pl-100
http://www.zyxel.com/upload/images/app_diagram/app_pl100_550x0.gif
Apr 22, 2009 | Computers & Internet
Is there other way to recover my old password
You dont have to reconfigure if all you did was change to dsl.
Unplug dsl modem. Unplug router. Turn off computer.
Wait at least 30 seconds, plug in dsl modem.
Wait at least 2 minutes, plug in router.
Reboot computer. All should be OK. If not, reply back, and I'll helo you further.
Feb 01, 2009 | Zyxel ZyAIR G-302 (760559111205) 802.11g/b...
Zyxel P660HW T1 V2 main screen in Turkish
go to settings of that and then change its language to english.
if u dont understand that then press reset button for 10 seconds which is back on router.then it reset but u have to reconfigure your router again if u reset it.
Nov 24, 2008 | Zyxel Prestige 660HW Wireless Router...
Modem router
I can tell that your network topology is not the most complicated ever.So u ve got 3 terminals,1 desktop pc and 2 laptop.Simple,reset your zyxel(from the button on the back) and reconfigure the Local area interface connection(ip & subnet mask for the zyxel),reconfigure your internet connection,(WAN zyxel interface) in case the zyxel is your Internet gateway too.Third,make sure NAT & Firewall are up and running(usually are by default) Finally,reconfigure the WiFi interface with the correct SSID name & WEP key or whatever security you prefer.Write down the security pass for your wireless and you are done.Good Luck.
Apr 19, 2008 | Zyxel Prestige 660H Router
Zyxel P660HW-D1 Router Logo
1,840 people viewed this question
Top Zyxel Computers & Internet Experts
Prashant M
Prashant M
mark
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
