Question about Ariens Garden
Ariens 935031 cuts off after about 15 minutes. what is the cause
I think my problem might be the cap vent. Anyway to check this other than running until it quits and loosening the cap to see if that fixes it? Lawn is all mowed so don't want to run it until necessary, but want problem resolved now.
Posted on Sep 08, 2012
  • 246 Answers
Hello dalefan829:
>>The Following is a Basic Instruction File I made for this. Any Input is Appreciated. I Usually Suggest you Check the Following in this Order for a Problem like yours. 1- Check the Gas Tank Cap and Ensure it is Venting the Tank. A Vacuum Builds in the Tank and the Gas Flow Stops or Slows (15 to 45 Minutes and if the Small Grainular Sand is in the Tank it can Take Several Days of Constant Running to Bring All the Sand Particales to the Tank Outlet Port) to a Point it Shuts Off the Engine. 2- Operate the Equipment Until it Quits (15min to 1hr). Then Immediately Check for Fire from the Plug. If the Plug is Firing, then 3- Check the Carburetor Solenoid. If the Carburetor Shut Off Solenoid has Current, then Remove the Carburetor Solenoid and Go to the Hardware Store. Purchase a Bolt of the Same Diameter and Threads. It Needs to be 3/4" Long. Put this Bolt in Place of the Solenoid. If this Corrects the Engine Problem, then Replace the Solenoid. ***NOTE: THIS IS FOR CHECKING THE SOLENOID ONLY I NEVER SUGGEST YOU OPERATE THE ENGINE WITH THE SOLENOID OUT OF THE CARBURETOR EXCEPT FOR TESTING PURPOSES*** Sometimes the Plunger is Moving, Just Not Far Enough to Allow the Gas to Enter the Jets. 4- Depending on the Model Mower, it can Also be the Pickup Tube in the Gas Tank. If No Fire, then Remove the Shut Off Wire from the Coil and Check for Fire. If Still No Fire, then the Ign Module or Coil is Bad. **Even if the Coil is New of Fairly New, it can Still be Bad.** On JD Mowers; Remove the Igniter/Module and the Coil and have the Local JD Dealer Test them.
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 14, 2009
What size belt other than the deck belt do I need for an ariens riding mower 42" cut?
I usually visit the manufacturer's website and download manuals that provide specific information. You will need the model number and serial number of your machine.
http://ariens.custhelp.com/app/answers/detail/a_id/15/
Apr 06, 2016 | Ariens Garden
Need deck belt diagram for Ariens ezr 1542
Go to the Ariens website for more information.
Sep 24, 2015 | Ariens Garden
How do I Determine why my lawnmower went dead?
It appears to be an electrical issue. Check the switch under the seat, mower engagement and others. Go to the Ariens website for more information on your specific riding mower.
Jul 17, 2015 | Ariens Garden
2250 zoom ztr ariens mower wiring diagram
Go to the manufacturer's website and download a manual for your specific mower. You will need the model and serial numbers.
Jun 01, 2015 | Ariens Garden
I have a ariens z 2048 when I engage the pto, it works but won't handle an even moderate load. Has new belt and blades would a bad battery cause this?
If your engine is running properly then battery has effect on the PTO.
It is more likely that your engine is running on one cylinder and that the extra load of deck is just too much for it.
Apr 17, 2015 | Ariens Garden
Brand new Ariens ST624e seized after 15 minutes of operation?
if there is oil on the sparkplug, you have blown a cylinder seal. It will need repair.
Dec 24, 2008 | Ariens 34 In. Zoom Series Riding Mower
B3101 AEG oven cuts out after approx. 15 minutes - why?
this is probably the thermal cut-out causing the problem. not sure where it is located but possibly on the roof of the oven or in the rear casing near the fan. however, the cause may be lack of ventilation to the unit as a whole
Nov 21, 2006 | AEG B3101-4 Electric Single Oven
Garden Logo
312 people viewed this question
Top Ariens Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Paul Sikkema
Paul Sikkema
Are you an Ariens Garden Expert? Answer questions, earn points and help others
