Question about Garden
Replaced new gas line, new primer bulb, new gasoline. need to find out if gas line routing is correct / trimmer will start, but very hard to start, clean air filter. carb never been adjusted since new.
  • Ragoo Monistere May 11, 2010
    What type and model, model number will help. thanks
  • 8 Answers
Line from tank with the filter on it is the supply line and goes to the carb inlet fitting. This is typically on the "bottom" of the carb (with the tank being up) and will usually have a fitting with barbs or a bulge on it to ensure a tight fit. The other fitting on the carb is the return line and is usually a straight tube fitting with no barbs. That line goes the suction side of the primer bulb. The third line goes from the outlet of the primer bulb to the return barb fitting in the bottom of the tank. Fittings have to be removed from tank to properly install the new hoses on them. Remove retainer ring on outide of tank and push fittings into tank, then shake out of the fill opening. More details on replacing hoses are listed in another post about Repairing Ryobi trimmer.
Have you checked the spark plug?
Posted on May 20, 2009
Poulan P2500 weedeater want start
change over the fuel lines on the carby
Mar 24, 2016 | Poulan P2500 17" Gas Trimmer
Probably needs new fuel lines to/from and in the tank. Have you been using ethanol gas? It eats up the fuel lines on 2 cycle motors. After you get it fixed, use only pure gasoline. I've had to rebuild two of mine so far!
Aug 10, 2014 | Craftsman 25cc Gas Line Trimmer
My Craftsman 17cc gas weed trimmer wouldn't start.
Hi There, Check the primer bulb for tare or pin holes. Replace it. Check and clean carb jet it maybe plugged with debree. Also check for spark which you didn't say. Replace with correct plug.
Note; Do not use strong cleaners on rubber seals (O rings and gaskets) They dry up and crack.
If needed use a dabble of grease on seals
Jun 13, 2011 | Craftsman Garden
No gas getting from the gas tank to the carb. replaced hoses and filter already. can not even draw gas with primer button.
You either need a new primer bulb (leaking air) or you have the fuel lines routed wrong. Here is the correct fuel line routing just in case:
Small diameter line out of fuel tank (has filter in-tank on end) connects to the side of the carburetor that has the fuel pump....that is the cover without the hole in it. Other larger diameter fuel line out of tank connects to the longer nipple on the external purge/primer bulb. The bulb "pulls" fresh fuel from the fuel tank to the carb and then out of the carb to itself, where it then pushes any air/old fuel back into the fuel tank. The remaining larger diameter fuel line in this setup goes from the metering chamber (has cover with writing on it and a vent-hole) side of the carburetor to the smaller nipple on the purge/primer bulb. Again, on the primer bulb, the longer nipple has a line going directly from it to the tank. The shorter nipple on the bub has a line from it going to the metering chamber side of the carb.If the purge/primer bulb is on top of the carb...small line from carb body to small hole in tank with filter. Larger diameter line goes from the bulb on the fuel pump side of the carb to the larger hole in the fuel tank where the line is held in place with a nylon nipple connector that keeps the line from pulling out of the tank
Oct 04, 2010 | Craftsman Convertible 25cc. Gas Line...
Troy bilt gas trimmer gas lines broke and now I'm not sure which lines go where.
The gas lines probably broke because of the ethanol-laced gasoline we have to use nowadays. It deteriorates them. If the unit has the external purge/primer bulb, the way mine did, it is not that hard. Just remember...the primer bulb "pulls" fresh fuel from the fuel tank to and thru the carb, thus pushing out any air/old fuel in the metering chamber of the carb back to the fuel tank in the return line...that said..
Fuel tank...2 lines...smaller diameter line goes directly to the carb body. There are probably 2 brass nipples on the carb. This line goes to the one on the body opposite the end of the carb with the vent-hole in the cover. This is the fuel pump end...where fresh gas enters the carb.
The larger line out of the fuel tank connects to the longer nipple on the purge/primer bulb. This is the fuel return line.
The remaining fuel line (larger diameter) goes from the vented-cover (has writing on it) end of the carb to the shorter nipple on the purge/primer bulb. This line carrys air and old fuel OUT of the carb to the bulb where it is then PUSHED back to the fuel tank via the return line...so you have a small diameter supply line to carb...an intermediate larger diameter line from the carb to the bulb and finally the larger diameter return line from the bulb BACK to the fuel tank.
Go to a small engine shop and purchase about a foot each of the 2 different diameter fuel lines needed and install those new "Tygon" fuel lines as your fuel line replacement.
Jul 09, 2010 | Troy Garden
Ryobi Gas trimmer fuel line routing
The fuel fillter line goes directly to the carb.inlet first
the outlet on carb.
goes to suction side of primer and outlet side of primer back to tank
primer draws fuel through carb. to prime
May 09, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
How to replace gas lines on a Weedeater Excaliber Hedge Trimmer
My Bolens Weedeater runs for 3 or 4 seconds and stop but it will run only if I drop some gas in the caburator then stop. Can you help me with this problem?
Norris.
Sep 25, 2009 | Garden
Fails to stay running / primer bulb does not fill
Double check that the fuel lines are routed properly. Another place to look for a potential problem is where the fuel line comes out of the tank. Make sure the hose is not pinched. The typical fuel line routing is the first line (the one with the fuel filter in the end of it) comes out of the tank and goes to the bottom fitting on the carburator. The second line comes out of the tank and goes to the bottom fitting on the primer bulb and the third line goes from top fitting on primer bulb to top fitting on carburator. Hope this helped and best wishes.
Sep 04, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Need to replace the gasoline pickup tube on a Homelite SX135.
The typical fuel line routing is:
One line (the one with the fuel filter in the end of it) comes out of the fuel tank and goes to the bottom fitting on the carburator. The second line comes out of the tank and goes to the bottom fitting on the primer bulb. The third section of fuel line goes from the top fitting on primer bulb to top fitting on carburator. Hope this helped and best wishes.
Sep 02, 2009 | Craftsman 25cc Gas Line Trimmer
2 Cycle Gas Trimmer will not start
it is normal to see air bubbles in line when pumping the bulb. to make sure what the problem is, try starting several times, remove spark plug. if dry, yes no fuel, remove the carb. if wet, place plug on engine block and look for blue spark. no spark means you need new plug, plug cord or ignition module
Jul 24, 2009 | Ryobi Factory Reconditioned 18" 40cc...
Garden Logo
540 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
