Question about Lexmark C782N Laser Printer
Lexmark C782n uesd for vinyl labels keeps jamming
We have 10 C782n printers that are continually jamming when running vinyl label stock. The stock meets the Lexmark specs. Some printers work fine as long as the drawers are full; some won't pull from the drawer at all. Other times, the jams occur in the middle of large jobs (160+ labels). No consistency, but lots of ********** users. We have the paper supply setting on *vinyl labels*. The labels come off pretty hot, but afraid the ink won't adhere properly if we reduce the setting to plain paper, which does seem to help.
  • 320 Answers
If your having problems with jamming and not picking at all. buy a can of cfc contact cleaner or equivilent. spray this on a rag and clean the surface of the rubber pick wheels in the tray. These wheels are known to get a shinny build up on them from the media. this will cause timming isssues as well as not picking the media at all.
Posted on Aug 28, 2009
    Genius:
  • 1,018 Answers
Please follow this link to the Users Guide for your printer then go to the Labels section.
http://www.lexmark.com/publications/pdfs/2007/780/ug_en.pdf
Don
Posted on Jun 03, 2009
Z4m printer error condition paper out labels will just keep feeding through ?
Sounds like a miss-match on the labels you are loading and the labels it is set up for. You'll have to go into the printer properties and check (and adjust as needed) the label stock selected to make sure they match. Next check the setting on the printer its self for the same for label stock selected. Most likely you're trying to use a label stock different then it was using before.
Jul 16, 2014 | Zebra Z4Mplus Label Printer
Own three CP3525dn's (purchased new). Two have recently begun jamming [fuser wrap] when printing labels. If it doesn't jam then the paper usually "dog ears" coming out. New fuser did not...
Over time, printing labels builds up a light residue of the adhesive (due to heat pressing) used on the labels in the paper path. A thorough cleaning of all paper path parts with alcohol prep pads, or Glass Plus and quality paper towels, will reduce this gum build up.
You should regularly print standard paper jobs on a laser printer that will be printing labels. Rule of thumb is 4:1 - four sheets of regular paper print for each sheet of labels printed. This helps keep the adhesive cleaned out of the paper path.
Patience and a lot of scrubbing should do the trick, though you may have to install a printer maintenance kit early given the issues noted. Printing labels cuts maintenance kit duration in half, at a minimum.
Jul 06, 2011 | HP CP3525DN Color LaserJet Printer
E260 will not print labels
This printer has capability to print on labels. Here are some tips when printing on labels:
· Use labels designed specifically for laser printers. Check with the manufacturer or vendor to verify that the labels can withstand temperatures up to 210°C (410°F) without sealing, excessive curling, wrinkling, or releasing hazardous emissions.
· Labels can be printed at a higher fusing temperature up to 220°C (428°F) if Label Weight is set to Heavy.
· Select this setting using the Embedded Web Server, or from the printer control panel Paper menu. Label adhesives, face sheet (printable stock), and topcoats can withstand up to 25-psi (172-kPa) pressure without delaminating, oozing around the edges, or releasing hazardous fumes.
· Do not use labels with slick backing material.
· Use full label sheets. Partial sheets may cause labels to peel off during printing, resulting in a jam. Partial sheets also contaminate the printer and the cartridge with adhesive, and could void the printer and cartridge warranties.
· Do not use labels with exposed adhesive.
· Do not print within 1 mm (0.04 in.) of the edge of the label, of the perforations, or between die-cuts of the label.
· Be sure adhesive backing does not reach to the sheet edge. Zone coating of the adhesive at least 1 mm (0.04 in.) away from edges is recommended. Adhesive material contaminates the printer and could void the warranty.
· If zone coating of the adhesive is not possible, remove a 2-mm (0.06-in.) strip on the leading and driver edge, and use a non-oozing adhesive.
· Portrait orientation works best, especially when printing bar codes.
· Use only paper label sheets. Vinyl, pharmacy, and dual-sided labels are not supported.
For further assistance, please contact Lexmark Technical Support.
Mar 04, 2011 | Lexmark E260dn Laser Printer
We use the Datamax Printer to print labels with labelview. The printer itself however keeps saying :position fault" how do I fix that?
Position fault or Out of stock when the printer is loaded with paper stock can usually be solved by calibrating the printer.
Press & hold the FEED button. Let the printer cycle 8-10 times. Should feed to the right position and say Calibration Complete in the window.
Hope this solves your problem.
Jul 12, 2010 | Datamax DMX-I-4208 Label Printer
HP 3210 getting paper jam because label stuck on roller.
I ran heavy card stock through printer several times, it caught the label and pulled it out on the paper eventually.
Feb 04, 2009 | HP Photosmart 3210 All-In-One InkJet...
Lexmark T640 won't print on label sheet a SECOND time...
try changing feed rollers. For a quick fix, remove the rubber rollers and flip them inside out. It should work
Jan 28, 2009 | Lexmark T640 Laser Printer
I get 2 labels(1 with data and 1 blank)for every label printed
THE LABEL SENSOR IS NOT SENSING THE BEGINNING OF THE NEXT LABEL
Clean the photo eye that senses the label gap with a q tip and alchol
Open side door release print head and remove label stock you will see small photo eye clean
put printer in manual mode( switch 1 on to and 1 on botom on
turn printer on it should advance one label and hit skip it should advance another
put back in computer mode
should work now if it still skips check yur label desigh=n software and label mode (continuous or sense label)
Best of luck to you
Dec 29, 2008 | Intermec EasyCoder 3400 Thermal Label...
Lexmark x83
Sounds like there is something like a part of a sticky address label, or a piece of other paper stuck inside.
Take a heavy piece of card stock and feed it through the paper path. Chances are, when you get the card stock all the way through, it will push out the offending object that is hung in the paper path.
May 19, 2008 | Lexmark X83 All-In-One InkJet Printer
Lexmark C782N Laser Printer Logo
167 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
