Question about Motorola Mobility RAZR V3
SIM Card My SIM card some how got disabled and i can not find out how to fix it or unlock it. I tried everything i possible could.
  • 626 Answers
If it says SIM card disabled, you will need to get a new one.
The password was entered too many times incorrectly.
Best of Luck.
Posted on Oct 14, 2007
How to fix my nokia n97 sim card not valid
There are two possibilities available to get sim card not valid situation while inserting Sim on your phone.
1.There may be a problem in your Sim card so try another one.
2.Your mobile is locked to particular network provider.
If your problem persists,Your mobile phone is restricted by some network so try to unlock your mobile phone.You can unlock your mobile phone using network unlock code.It's the best way to unlock your phone.If you need an unlock code for your phone visit ProUnlocking.com I hope it will be very useful to you.
Aug 14, 2014 | Nokia N97 mini Smartphone
Tip
How to Unblock Network lock of SAMSUNG SGH-J700
SAMSUNG SGH-J700 UNLOCKING:
1- Power on pone ,, type : *#7465625#
you will identify which code is active , which is inactive
2- Remove battery ,, Put your sim card , not all of it ,, just to prepare it to be full inserted , put your battery back and power on pone ,, you must see " insert sim" not "invalid sim.."
3- type : *2767*3855#
your pone should restart after 1 min ,,
now ,, and before it restart , push your sim card ,,without removing battery
4- your pone should work and accept the sim card ,, but if you check locks you will find that your pone is still Locked
5- now type : *7465685*638*00000000*00000000#
your UNLOCK CODE is 00000000 now ,
6- now , back to Locks table with : *#7465625# ,, and for each active code you can disable it ,,,Here details :
* Disables CP lock : #7465625*27*00000000#
* Disables Network lock : #7465625*638*00000000#
* Disables SIM lock : #7465625*746*00000000#
* Disables SP lock : #7465625*77*00000000#
* Disables Subset lock : #7465625*782*00000000#
on Jan 21, 2010 | Cell Phones
My Samsung Galaxy S2 GT-I9000 doesn't read my SIM Card
Can't figure out exactly what the problem is. Try with the following methods.
1) The SIM card might be damaged. To check this, Try inserting the SIM card into any other active network free phone. If it doesn't work then sure the SIM card is damaged. If it works fine then the SIM card is in good condition.
2) The SIM port on your phone might be damaged. Try inserting any other active SIM card to it. If it doesn't work, then sure the SIM port is damaged. If it work fine, Then the SIM port is in good condition.
3) The phone might be network locked. If the phone doesn't allow any network SIM cards to work with it except any one specific SIM card, Then it is sure network locked. You can unlock a Samsung Galaxy S2 safer and easier using unlock code. You can get the unlock code for a Samsung Galaxy S2 from ProUnlocking.Com at affordable cost with easy unlocking guide. Good luck.
May 30, 2014 | Samsung Galaxy S GTI9000 Smartphone
Showing invalid sim
The most common thing for any mobile/cell phone.
Easy fix simply take an eraser & rub over the contact of the sim card then making sure not to touch the sim cards chip re-insert in to the phone & it should be problem solved. If the problem still exists insert in to another phone if possible to test the integrity of the sim card if the sim card works in another phone it could be the phone you are attempting to use it maybe faulty or the sim card is incompatible or the phone is not unlocked entirely, if it doesn't work in another phone the sim card has failed & a new sim card is required.
Apr 29, 2014 | Huawei Unlocked G6600 Qwerty Smart Cell...
Update my phone now its writing insert correct sim card
Hi there! It's possible that your SIM card has become loose or has moved. Take the back off your phone and pull the battery out. Under your battery you'll see the SIM card somewhere (unless this is an iPhone, in which case you need to poke a little hole at the top of the phone with a paper clip to get at the SIM card). Pull the SIM card out and then reinsert it. This can "reseat" the SIM card and fix problems like this.
If you've tried to unlock your phone and it went poorly, then you will need to go to your carrier to get this problem fixed.
Alex
Jun 01, 2011 | Computers & Internet
Invalid usim card
unlock phones are so unperdictable...there may not be a fix for this issue..other then getting an AT&T phone....and even if u are able to get it to start working again more then likely u wil continue to have many more isses..mainly becuz of the network changes..for example....using 3g and 3g only...last year the AT&T network was stil using both 2 and 3g network and there was even a few 2g SIM cards being sold in stores...now it almost all 3g..which of course complicates many things...even if u own a 2g AT&T phone a 3g SIM card can be and will be used on that phone....with unlock phones running on the 2g network the issues with not having a SIM card where possible...it was still unstable when wanting to use data services....but voice services were possible...now with everything going 3g...its makes things alot more complicated with AT&T if using a phone without SIM cards...if ur phone has the fuction to beable to shut off 3g networking and run on 2g.(like the apple iphone has) then try that....good luck
Apr 17, 2010 | LG KU990 Viewty
Sim card rejected
Two possible things have happend:
A: the SIM card is blocked by your provider.
Hot to test:
Try the SIM card in another phone. If it doesn't works there, call your provider.
B: the phone itself has blocked the SIM. This shouldn't happen with just little settings chaning... there has to be a major misuse happend.
This could maybe disabled by starting the phone with another SIM-card inserted and the security settings should changed. There's a setting that's checking the SIM (no idea at the moment what the name of it is). This should be disabled. Than the SIM-card of you should work again.
Sep 19, 2009 | Nokia 1600 Cellular Phone
Puk disabled
You will have the PUK code in your welcome kit. Else call the customer care number. Answer the basic questions and ask them to tell your PUK code. Write it down and never lose it. Use this to unlock puk. There are no other solution possible.
Sep 14, 2009 | Teac (DV-W58GA-PUK) Burner
PUK disabled card blocked
Well it doesn't block your card, it just blocks your sim card, If you will try a diffrent SIM in your phone that will work and if you want your sim to unlock than contact your Connection service provider means the company from you have you phone connection and you need to give them your sim no, which wouldb located at the back of your SIM and they will provide you with your PUK no for the SIM card.
Jul 28, 2009 | Samsung SGH-X530 Cellular Phone
Motorola Mobility RAZR V3 Logo
78 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
