I dropped my PSP on the floor and ever since it won't vome on without the AC Adaptor plugged into it. The Orange charging light comes on but the PSP just won't come on withot the Adaptor. Is it bircked or do I need a new battery?
i have a psp that stop workin the light wont come and when i have it pulg in the light sitll wont come on will someone pz tell me what happen E-mail at [email protected]i have a psp that stop workin the light wont come and when i have it pulg in the light sitll wont come on will someone pz tell me what happen E-mail at [email protected]
i dropped my psp and when i tried turning it on it didnt but when i plugged it in the ac adapter it worked and played perfectly for 5 minutes then goes turns back on i can play with out with the the battery with the ac adapter fine as well but not without it any solutions would be appreciated thank you.
You can't post conmments that contain an email address.
Something more than likely chipped off/broke from the impact of the drop. Have you tried opening the PSP? *Note - opening your PSP will void your warranty.
Hi, Better bring it first to some PSP tech to verify the problem of the board, some micro fuses might have blown. It takes some soldering to replace it Hope that helps you!
first check the power cable if its properly plugin, and check if ac to dc adaptor has a output power. you can check it by using digital voltmeter or an analog multimeter, you can see the pin output in the back of the adaptor, it has positive and negative sign.
You could try another battery.But if another battery doesn't work,sorry mate I think it's dead.In future make sure you only use what you know is compatible,also NEVER try to run the PSP with the AC adaptor without the battery in.The PSP safety and support booklet states: Do not use the PSP system with the AC Adaptor when the Battery Pack is not inserted in the system.If the AC Adaptor is disconnected suddenly,it may result in damage to the system.
If it is the motherboard that's burnt out I think you can replace it but they're expensive I think,I saw one for a PSP1000 for
Try to connect the AC adaptor of your laptop and plug it to the wall outlet and let it charge for 3 hours or more. When you plug it on the wall socket, it won't show the laptop's led blinking since it was totally drained. But after 3 minutes or more, it will start to show the blinking led to indicate charging. When blinking stops led light disappears, it is fully charged and ready to use.
Remember: Do not use your laptop while it is plugged in to save your battery life. When at home, remove the battery while it is fully charged and plug the AC adaptor directly to the wall outlet. It will still work without the battery as long as it is plugged directly to the wall socket.
Hi! TRY THESE TO SEE IF WE CAN GET YOU POWERED UP! :)
Confirm the system is not in HOLD mode Make sure the PSP system is not in Hold Mode (in the down position). Slide the Power/Hold switch up to clear Hold Mode. Or try sliding the Power/Hold switch up and holding it there until the power indicator light turns off and the PSP system is completely turned off. Then try turning the PSP on again.
Confirm the backlight is ON Make sure the LCD screen's backlight is not turned off. If it is, press any button to turn ON the backlight.
Confirm use of only licensed products (AC Adaptor, battery pack and charger) The AC Adaptor, battery pack and battery charger must be licensed for use with the PSP system. All licensed products for use with the PSP will have the following logos displayed directly on the product and/or the packaging: If any of the products you are using does not have these logos on them, we recommend that you immediately discontinue the use of these products, as they void the PSP system's warranty, and can cause damage to the system. See compatible peripherals for the PSP system for a full list of supported products. There are some products that can be used with the PSP system that may not display our logos. Products such as San Disk 1GB Memory Sticks, or various USB cables, needs only to be genuinely certified. Look for the genuine certified logos on these products or contact the company which manufactures these products for more information.
Try the battery pack only Unplug the AC adaptor from the PSP system. Make sure a charged PSP battery pack is inserted inside the PSP system. Turn on the unit. If you get power, then the problem may be with the AC adaptor and power cord.
Try the battery pack in a different PSP system If possible, try your PSP battery pack in a different PSP system. If your battery works on a different PSP system, it may indicate an issue with your PSP system.
Try a different PSP battery pack If possible, try a different battery in your PSP system. If a different battery pack does work on your PSP system, it may indicate an issue with the original battery pack.
Try the AC adaptor and the PSP battery pack Insert the battery pack and plug in the AC adaptor. If you still do not get any power, your PSP system may need to be sent in for service (see PSP Service for details).
Try the AC adaptor / power cord only Turn off the PSP system, unplug the AC adaptor, and remove the battery. Now plug in the AC adaptor to the PSP system with the battery removed. Confirm the AC adaptor and power cord are firmly connected to each other. Now make sure they are also firmly connected to the PSP system and the electrical outlet. If the PSP system powers on, the battery may need to be replaced.
Check AC adaptor and power cord for damage Visually inspect the AC adaptor and the power cord for damage. Do not use if frayed, cut, or damaged in any way.
Check the electrical outlet Confirm the electrical outlet that you are using is active (receiving power). Try using a different electrical outlet.
Try a different AC adaptor and power cord If possible, try a different AC adaptor and power cord. If a different AC adaptor and power cord does not work, the PSP system may need to be sent in for service (see PSP Service for details).
Confirm no unauthorized system software or downloads were used Confirm that you have not used any unauthorized system software updates or downloads on the PSP system. Use of such unauthorized firmware updates voids the warranty and can damage the PSP system.
WLAN turned off Make sure the wireless (WLAN) network function is not in use while charging. The battery pack cannot be recharged when the WLAN function is being used.
Power surge If you experienced a power surge, shortage, or a lightning storm in your geographical area recently, this may have affected the PSP system's power supply. Please contact Consumer Services below for information.
check battery, run without the battery, using ac adapter, see if problem persists
did you update psp firmware?
if so, undo the update, go back to previous firmware version
