Question about Broksonic CTSGT8118T 13 in. TV/VCR Combo
Sap playing we would like to remove from our tv
    Problem Solver:
I called the company and they told me the only way to solve this problem was to
buy a remote from them! No other works with their tv. thank you
Posted on May 15, 2009
How can I stop an audio description being played on my Lowry GS32FHD TV?
You are referring to SAP which is a secondary audio program. It is enabled when you do initial set up of your TV. Return to setup and disable SAP (one of several audio choices).
Jun 10, 2014 | Music
Sound plays on some stations and not others- how to fix this?
look for MTS or SAP button on remote or in tv menu depending on make--you have it set to SAP--change it to mono or stereo
Oct 15, 2012 | Supersonic 15 in. LCD TV
How to I disable the SAP function on RCA FLAT 19 INCH screen?
Hello
From its main Menu, surf towards its sound Menu.
By using UP/DOWN buttons of the remote handset, select SAP
SAP (Second Audio Program) (for analog channels only) Plays the
program's audio in a second language, if one is available. The TV displays
the word SAP in the channel banner when you tune to a program that is
broadcast with SAP information. SAP audio is broadcast in mono. SAP is also
used to broadcast a program's audio with descriptions of the video for the
visually impaired. Press the right arrow button to turn SAP on or off.
OK.
Sep 22, 2011 | RCA TruFlat 27F520T 27" TV
Audio is not working
Check to see if you accidentally went to SAP mode which os secondary audio for english to Spanish language. Check mute buttons on tv and cable boxes. If have dvd player hooked up play a movie if I get audio check tv sap settings
Aug 01, 2011 | Toshiba CF19H25 TV
The vcr writing on the tv screen says "SAP" and the sound won't play. How do I turn SAP off?
Hello
SAP means Secondary Audio Programme. To cancel this, you have to get into the Minu of your TV, and surf through to get the SAP display window. There you have to set the SAP of OFF. For more details go to the user manual of your TV. OK.
Apr 29, 2011 | Samsung CXM2785TP 27 in. TV/VCR/DVD Combo
How to use sap with a rx-v463?
the trick is, it has NOTHING to do with your receiver, and EVERYTHING to do with your TV, you need to choose SAP on the TV not the stereo. That will send the SAP sound to the stereo you are playing the sound through.
Oct 10, 2009 | Yamaha RX-V463 Receiver
Background voice, 27 inch "truflat" 2005 model
What you're hearing is the descriptive audio track included on many DVDs for vision-impaired viewers. Does this happen when you're watching regular TV or just with DVDs? If it happens with regular TV, do you have a cable box?
Regular broadcasting sometimes uses SAP (second audio program) to send additional audio, and this descriptive audio may be the SAP channel on some programs. Check your TV's audio settings to make sure you don't have SAP turned on. There may also be settings for SAP in your cable box as well, so check there too.
When playing a DVD, descriptive audio is usually an alternate audio track. Check your DVD player setting to make sure you've selected normal audio for playback.
Apr 04, 2009 | RCA TruFlat 27F520T 27" TV
SAP
Hi Suezie,
The problem is most likely your SAP being turned On.
SAP was created for audio programing including translations into a 2nd language. On nearly all sets, the SAP being ON will essentially select an alternate audio stream and will de-select or mute the main audio from the channel your are viewing. However not all TV stations have SAP enabled.
I am the Chief Engineer of a TV station in Denver, CO. We are not using SAP so if you selected SAP while watching my station you would get noise or static. There would not be any audio there.
Go to the front panel of your TV and select the "MENU" function. Step through the menus to Audio features and De-select SAP or Enable your main audio and this should take care of the problem. Alternatively you might be able to unplug your set for a period of time and it would reset itself. I used to get calls from elderly viewers when the set wouldn't pick up the UHF TV stations anymore. These were always after a power failure and the set had defualted to factory settings,
Different set manufacturers use different menu schemes and withou a password feature, these menus are so simple a small child playing with those fascinating buttons can change them for you to something you really don't want.
Good luck and write back if you can't find it. The set manufacturer and model number would help me look up a menu tree for your TV set.
Thak you,
Bernarr Howell
Feb 03, 2008 | Televison & Video
Vcr spanish language
You may have your SAP settings turned on in your VCR. Check your setup menu and turn SAP off SAP stands for Secondary Audio Program, it allows for bilingual sound if the station is transmitting a SAP signal. Thank you,
Aug 27, 2007 | Sanyo VWM-900 VHS VCR
TV plays some channels in spanish
The tv may a SAP circuit fault (Second Audio Program). This circuit can mess up and cause some channels which are carrying SAP to put out the wrong language. I've seen this happen a few times. AN IC may have gotten zapped when the transformer blew. Possibly the microprocessor IC. Stargazer
Mar 03, 2007 | Durabrand DWT2405 24" TV
Broksonic CTSGT8118T 13 in. TV/VCR Combo Logo
64 people viewed this question
Top Broksonic Televison & Video Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Broksonic Televison and Video Expert? Answer questions, earn points and help others
