Question about Abit A17 Guru Motherboard
Os install won't let me
Hi if any on can help please let me know i have a problem of installing win nt 4.0 on my hard drive i think it is the mother board when i put the disc in and boot from the dvd rom drive it has a blinking line that looks like this-and nothing happends i have to unplug the hard drive and when it gets on to the nt setup screen it copies all the files then you have to take the disk out and reset the computer and it happends all over again
so if anyone can help i will give you all the credit
r.fearn
  • fearn45 May 13, 2009
    it was set to dvd first it's a 370 socket motherboard i don't know wat bios it is how do i find out
  • ROD GANDY May 11, 2010
    HOW MANY TIME HAVE YOU USED THIS DISC?
  • 323 Answers
Okay, this is elementary, but I've forgotten some pretty basic things before.
1. You've cleared the RTC?
2. Made sure you have the latest bios copy in it?
3. Gone into set up and set the computer to boot from the DVD before the hard drive? (If it's set to still boot from the hard drive first, it won't boot up)
4. Made sure the drives are properly defined?
By the way, does NT 4.0 run on Fat 32 or NTSC?
You don't happen to have a master/slave problem the way your drives are set up do you? Just trying to think of anything that might foul the install.
I think it sounds more like a hard drive problem with the way it is set up rather than the motherboard. I hope that is the case. Let me know how it goes.
Posted on May 12, 2009
Good day, i have a laptop that i purchased with Ubuntu 12.04 pre-installed i now wish to change to win 8.1 but i dont know how to do it please assist, ive tried everything i could think of
My Suggestion would be to stick with Ubuntu. Windows 8.1 will be much slower on the same computer.
However, if you do really need Windows, my suggestion would be do run it under Ubuntu using VirtualBox (free) and then install the Extension pack which you can download from the Tools menu, when you have your OS running. This then gives you full screen. For your communications, make sure that your network adapter has been set to 'Bridged'
Feb 12, 2015 | Ubuntu 12.04 USB Bootable Flash Drive 2 GB...
I can't install any OS because by DVD drive doesn't detect it!
have you tried using fdisk and delete partion then make new partion and set active partion then boot from CD which will then format drive then install OS
Jun 24, 2009 | Computers & Internet
Audio not working no driver / no device
Hi I'm mhel, I don't know yet *********** exact specs but you can try visit this website and it's called lostmydrivers.com. Please try to read the onboard chip manufacturer in your board to get the best result and I think it's a Realtek or VIA
hope this will help
mhel
mhel_services@yahoo.com
May 31, 2009 | SuperMicro Intel 945P Chipset, non-ECC...
Error installing windows xp
hi! there,set up exe. that was when your setting up win 98 you have to install that came from floppy disk before you can install win 98.there is an os win 98 in your system you have to delete that previous os before installing another win xp.restart ur computer. press F2 to open your bios set-up . then select bios set-up priority your cd-room drive second,your hard drive. last, quit and save set-up. and then your computer will restart. insert your cd windows xp then reinstall your window xp. delete the previous os then follow the set up on your window xp until you install your new window xp.
Apr 01, 2009 | Compaq Presario S4020WM PC Desktop
My computer cannot install os
You need a new hard drive mate..
not all hard drive fail -hard, some of them feel dizzy- no outcome.
Hope it helps..
Jul 08, 2008 | MSI Computers & Internet
I have two operating systems on my hard drive.
You can manually disconnect the IDE/SATA cable temporarily from your motherboard (the one with NT PRO & XP HOME), then you can cleanly install a Windows XP on your new Hardisk. And after installing, you can re-connect the other hardrive on your computer and format it under your NEW Windows XP, be sure to set the BIOS BOOTUP sequence that you boot on the right drive.
-mrsolution
Jun 11, 2008 | Gateway GT4022 PC Desktop
Kingston 256 usb pendrive
Dear Ekwal Imam
Install driver for usb drive for win 98. the driver comes with usb. or visit manufacturer site.
Feb 23, 2008 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Prob with compaq motherboard
My name is Vikram Kumar Thumu, I have seen your issue and would like to provide my solution on the issue...
Well, this is an issue that could happen with failure of Hard Disk Drive or Mother board type that you are using..
I think, this is to do with Motherboard specifications, since few Mother boards type or model will not support for Lagecy OS like WINDOWS 95/98.
Hence you to need to check from that point.
I request you to let me know the more information like Computer Model number and S/n and P/n number so that can research on the issue and provide you more information.
if you have any queries please mail at thumuvikram@rediffmail.com, I'll be glad to assist you..
Thank you.
Bye,
Vikram Kumar Thumu.
Feb 19, 2008 | Compaq (252608-001) Motherboard
Intel 945GCCR mother board network drivers problem
hi dear .
when start up the computer automaic run bios , when i exit it display this masseg :
reinstall jumber in normal mode .
and the jumber is in normal mode already .
thanks .
Jan 29, 2008 | Computers & Internet
Abit A17 Guru Motherboard Logo
47 people viewed this question
Top Abit Computers & Internet Experts
Alun Cox
David
David
Jerry Umali
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
