Question about IBM 6400 Matrix Printer
Need to change the printer ribbon on ibm 6400
Which way does it feed. Last time the ribbon got twisted and broke, please help.
  • 1,602 Answers
BY WWW.IBM.COM/SERVICE
GO ON LINE AND TYPE THE FOLLOWING:
HOW TO CHANGE A PRINTER RIBBON IBM 6400
BEFORE YOU DO ALL THAT FIND THE RIBBON BOX AND SEE IF IT HAS ANY TYPE INSTRUCTION WHAT TO DO?????????
ROD
Posted on May 12, 2009
Ibm 6400-08p matrix printer service centre in tamilnadu where?
Might not find any anymore, IBM has discontinued and no longer supports the IBM 6400 series printers and or any printers at all. If you need some support or printer parts please contact me. Rory 708--597-4222
Sep 15, 2011 | IBM 6400 Matrix Printer
Hello I have an IBM 6400 printer at work. It prints documents, but every now and then it will print the documents with a white streak running down the paper, like it doesn't print in that spot. I tried...
Hi there, I hope you haven't throw away the printer.. :)
i face similar problem.. its solve by tightening the ribbon latch screw that secure the latch to the ribbon motor.
Feb 02, 2011 | IBM 6400 Matrix Printer
IBM 6400 Emulation software change
Hello !
I have a IBM 6400 printer in AS 400 system. I want to convert that printer to PC system to print daily to day printing which I can support Window XP and Windows 7.Please let me know the coorrect way to do that and what are the software I need to download.?
Mayuri
May 14, 2009 | IBM 6400-I2S Matrix Printer
IBM 6400 Dot Matrix Printer - Need Drivers for Windows XP
Try running couple of these test, to see if it might be another issue.
It should be printing these test at 1500 Line Per Minute... ?
1500LPM is at 10CPI if you have (Font size: 6, 8, 12, 14) it will make a difference.
Change your driver to Generic/Text, rerun your report... any difference?
Apr 15, 2009 | IBM 6400 Model i10 Matrix Printer
I need instructions for tractor replacement on IBM 6400 printer
GO ONLINE ASK THE FOLLOWING:
WWW.IBM.COM/SERVICE
IBM 6400 TRACTOR REPLACEMENT INSTRUCTIONS
SERVICE MANAUL IBM 6400 PRINTER
IBM 6400 TRACTOR ASSEMIBLEY/DETAILS
ROD
Apr 02, 2009 | IBM 6400 Matrix Printer
089 Ribbon Stall Check Ribbon
Your Ribbon HUB is Broken. Replace it.
Problem will be Solved.
Regards,
Pawan Dahake
( IPS, Nagpur )
INDIA.
Feb 24, 2009 | IBM 6400 Matrix Printer
Cutting letters off in 2 spots down whole report
IF trouble in first row - you ribbon is tracking wrong - replace
You may have junk in the ribbon mask also. No parts needed for that. You need to rotate the hammerbank. Remove ribbon and black cover, the whole shuttle will tipback toward you when you unscrew the allen wrench - watch out for the paper tractors they will hang on the ribbon mask. The ribbon mask is held on by magnetic field - just pop off carefully. clean holes with toothbrush and water - dry. (if the trouble is a bad actuator - 4 allen screws to remove a group of hammers - if using short paper - you can use a group from the end of the printer). reverse to fix
Feb 02, 2009 | IBM 6400 Matrix Printer
Error 058 Shuttle Jam on an IBM 6400 Matrix printer
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 06, 2009 | IBM 6400 Matrix Printer
Need Program files to Flash IBM 6400 Printers
If you haven' tlooked into any of the print management utilities here is a link.
I am not familiar with this printer .. but maybe this is what you need.
Sometimes we just try .. because we really want to help and hope that maybe we "stumbled" on something.
Dec 09, 2008 | IBM 6400 Matrix Printer
058 shuttle jam
This can happen for a number of reasons.:-
a. The print mechanism needs to be adjusted ( You'll need a technician to do this if yu are not familiar.
b. Something is clogging the print mechanism, eg Old ribbon residue, or sticky labels etc.
c. The paper thickness lever is set to incorrect setting . Try adjusting it out .
Aido
Jan 18, 2008 | IBM 6400 Matrix Printer
IBM 6400 Matrix Printer Logo
152 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
