Question about Hotpoint WF430 Front Load Washer
All the lights keep flashing
Hya...got a problem with my 3yr hotpoint..
I switch on then i program....then all 3 lights on the left had side keep flashing so i switch off and reprogram...but when i do this it washes for ever and never stops unless i totally switch off and unplug...sometimes in the middle of the program it just totally stops and does it to....but mostly it just carries on forever till i have to switch off again...
really in need of some1s help...dont want to may a fortune for an engineer when mite have to just pay for a new washer....but mine is like brand spanking new...
  • 1 more comment
  • mytravel Oct 15, 2007
    Awww thank you..
    me being cheeky you wouldnt know of any1 that is reliable and cheap in the manchester area ????
    many thanks for that
    xxxxxxxxxx
  • mytravel Oct 17, 2007
    Awww thank you so much for all your help hunny..
    xxxxxxxx
  • Blackrussian Apr 06, 2008
    Hi I have the same problemon my same model machine and it is just 3 years do you get yours fixed?
    Cheryl
  • 209 Answers
Could be a heating element fault?  normally when washers tumble forever they are waiting to warm up?
check for open circuit electrically, normally a fairly low cost repair
Posted on Oct 14, 2007
  • mick d Oct 15, 2007
    sorry too far away for me to call out, no need to guess where i live? just ask neighbors, thats the best thing to do, honestly
    glad i have been of some help?/
Hotpoint wma32pr door light keep flashing and no wash
1) test the lid switch for open
2) test the door switch for open too
3) see the diagram attached, any switch faulty can not START the motor.
God bless you
Jun 19, 2012 | Washing Machines
I have an identical prestige remote which is not programed for my car iwould like to program it exatly like the one i now use so i can have a spare.
The programming procedure for Prestige/Pursuit remote is as follows:
First, locate the programming/valet switch. For newer model units the programming switch is located in the antenna, previous models have a push button LED (PBLED). Older models have a plain black push button, usually located near the driver's side kick panel (where your left foot would rest when driving).
After locating the programming switch; turn ignition on, press and release switch three (3) times,parking lights will flash once. This is channel 1 (lock button). Press lock button on remote. Parking lights flash once. Press and release switch one (1) time. Two flashes (channel 2). Press unlock button on remote. Press and release switch one (1) time. This is Channel 3 (trunk/remote starter), press the channel three button on remote. Repeat process for additional channels. Once you have programmed all available channels, turn ignition off to exit programming.
Jan 20, 2011 | Gmc Dodge Ford Reverse Back-up Sensor...
After selecting a program, the dishwasher beeps for a while and the 3 buttons on the left flash too. Program wont start, water wont fill and nothing happens. THe lights keep flashing but the beeps stop for...
Basically the dishwasher is telling you there is a fault - Not so useful I know! Plug out the machine and leave it for five minutes and see will it reset. If that does not work, you will need to reset it manually. To do this consult the manual. If you don't have a manual, go to http://www.hotpointservice.co.uk/hs/pages/manual/manualSearch.do and down load one. Good luck!
Aug 13, 2010 | Hotpoint 18 in. DC28 Slim-Line Built-in...
Selector switch keeps clicking round after 1-2
is there any flashing lights? there should b or some lights are staying on, this will b a fault code, repost the lights or pattern and i will try to find the result for you.
Apr 07, 2010 | Hotpoint BWM12 Front Load Washer
I have aquarius ,, lights keep flashing prior to
had a similar problem...sounds daft but have you unplugged it left it alone for 5 mins then tryed again? worked for mine.
Mar 02, 2010 | Hotpoint Washing Machines
FDW60 Fast40 and Delicate50 flash
heating circuit open is the fault code.
checks to be carried out to make sure of diagnosis
Check the circuit of the heating element (26 ohms).
Check for an open circuit heater cut-out.
Check pressure switch open circuit (connections 11-14).
Check wiring and connections between module card, pressure switch and heater.
If all above is OK, replace module card.
Heater Replacement
1.Remove top cover as in.
2.Remove the left hand side panel.
3.Using suitable floor protection carefully lay dishwasher on right hand side; this may result in
water spillage from the air break unit.
4.Remove the base panel.
5.Disconnect the wiring.
6.Slacken the clips securing the hoses.
7.Replace in reverse order (using jubilee clips not existing)
Dec 21, 2009 | Hotpoint 24 in. FDW60 Free-standing...
Flashing green light
Hi there. It looks like water is present in the flood catching tray at the bottom which usually indicates that there is a leak somewhere. More often than not this is just a pipe with a poor fitting and simply tightening the clip is enough to stop the leak. Our machine had a very slow leak from one pipe (not enough to trigger the alarm) which was fixed in this way. The leak is detected by a small float switch located in the flood catch tray.
Undo 4 screws on the metal plate under the dishwasher 3 at the front 1 at the back, this reveals The pump check the seals are in place on the waste pump.
Mar 10, 2008 | Hotpoint 18 in. BCI45 Slim-Line Built-in...
Hotpoint bwm129 lights flashing
What mode are you starting this machine in ? I know this may sound silly and I'm trying to determe if this is a machine fault code or something else.
Dec 30, 2007 | Hotpoint BWM12 Front Load Washer
Whirlpool Frost Free 460 door open alarm
http://www.repairclinic.com check how to repace it with the schematic diagrams you'll see how
Dec 30, 2007 | Whirlpool GS6NBEXR Side by Side...
Hotpoint WF430 Front Load Washer Logo
150 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
