I have an HP Deskjet 5440 which performs perfectly with Windows. With Suse 11.1 I am using the Foomatic hpijs 2.8.7.3 driver which the system puts in place, On attempting to print, the printer produces page after page each having 3 lines of rubbish and the printer can only be stopped by unplugging the the power
  • 2 more comments
  • alexanderosb May 14, 2009
    All your solutions assume that there is something wrong with the printer; the printer works faultlessly with Windows! You are barking up the wrong tree; I need a Linux expert; I have learned from the internet of this kind of problem with Linux/HP
    I will reinstall the printer. This will take some time so please suspend this conversation 'til I come back again.
    I have found the solution!
    I have a Canon printer connected to the USB as well as the HP.
    I assumed when I installed the HP printer that it would not cause a problem because it was never powered up while using the Linux.
    However, disconnecting the Canon from the USB before installing the HP was the solution.
    I remember the only other time i solicited your help, I ended up myself solving the problem and I was able to enable to add this from your database
  • alexanderosb May 20, 2009
    I believed that you operated a no solution no fee basis!
    I am appalled that you have charged me twice even though you didn't come up with any solution!
    Alexander Osborne
  • 355 Answers
Clean the contacts on the HP Cartridge. I've had the same error before and i switched it to a fresh new cartridge.. works fine ever since. THen i decided to switch back to the old cartridge, same error as you but i cleaned the contacts on the cartridge, works for a while but done after a week. Problem is that the ribbon circuit is rusted and the printer doesnt recognize the ink anymore.
Also make sure you both have the ink cartridges in place. Make sure it is seated properly inside.
hope this helps!
Posted on May 14, 2009
HP Deskjet 5440 inkjet photo driver
You can download drivers for your printer on Hp's website located at www.hp.com. Click on support and then downloads and follow the prompts. Good luck!
Sep 22, 2011 | HP Deskjet 5440 InkJet Photo Printer
I have the disc and still cant download my hp 5440 on windows 7
The drivers for your HP product are already included in the new Windows 7 operating system
Please check this link to get a clear idea on how to use the printer with Win 7
Click Here
Regards,
Riztech
May 21, 2010 | HP Deskjet 5440 InkJet Photo Printer
I have a HP F380 All in One Deskjet Printer Mac OS 10.5.8 Printing for over 2 years using Airport Scanning I need to connect by usb Issue: I reset the settings and can't find the driver I used to...
Thanks for using Fixya.
First, Uninstall your HP F380 and then again reinstall it.
If your printer is connected via usb to airport extreme you will have to download and install the following.
1. espgs-7.07.1.ppc.dmg
2. hpijs-foomatic-2.0.2.ppc.dmg
Do this by going to The Linux Foundation (http://www.linux-foundation.org/en/OpenPrinting/MacOSX/hpijs)
Install in the order listed above, they both must be installed for this to work.
Then do the following:
1. Go to > system preferences > print & fax
2. Click "+" to add a printer
3. The HP F380 will be listed with the connection type "Bonjour"
4. Highlight this printer
5. At the bottom of the window you will see the option for "Print Using" and than you can choose something from the drop down menu.
6. Scroll down to "HP" and choose that
7. This now propagates a window full of HP printers including the HP F380 drivers that you installed above.
8. Scroll down until you see "HP F380 FOOTMATIC" and highlight this.
9. Click "add".
That's it, your done and it should work.
Good Luck and have a nice day.
Rating the solution is highly appreciated.
Mar 18, 2010 | Office Equipment & Supplies
Hello, I just bought a new laptop that has Windows Vista. My printer is a Hp Deskjet 5440 and it is not working. I dont think it is compatible with windows vista... is there a way to MAKE it compatible?......
HP Deskjet 5440 is compatible with 32Bit version of Windows Vista. You can check for device compatibility with Windows Vista at the link below:
http://www.microsoft.com/windows/compatibility/Default.aspx?type=Hardware
You need to install the drivers for this printer to make it work with Vista. To download the updated drivers for this printer, go to the link below:
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=dj-48092-1&lc=en&cc=us&dlc=en&product=445441&os=2093&lang=en
Aug 17, 2009 | HP Deskjet 5440 InkJet Photo Printer
Printer Driver
You can download the drivers for your printer , both on MAc and Windows, from the link below:
HP Deskjet 5440 Printer series - Download drivers and software
Mar 07, 2009 | HP Deskjet 5440 InkJet Photo Printer
Need Power Supply/Cord to HP 5440 Deskjet
Hi have you tried ebay ? search,--- low voltage power supplies, check out advertising at bottom of pages.
Oct 27, 2008 | HP Deskjet 5440 InkJet Photo Printer
Printer
Windows comes with drivers for many HP printers.
You can try to install your HP deskjet 5440 by going to (depending on operating system) "Start", "Printers and Faxes", "Add Printer". Select a local port. Select "HP" and Model "HP Deskjet 5440".
If 5440 is not in your list, or if you want the latest driver, you can download the driver for your specific operating system here:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=445441&lc=en&cc=us&dlc=en&lang=en&cc=us
Aug 02, 2008 | HP Deskjet 5440 InkJet Photo Printer
k24674
jasbo
jasbo
