TV wont turn on
Hi Guys,
                The red power indication on my Philips 34pt5793/79R TV just oscillates on and off when the power is turned on at the mains. There is no other symptons and attempting to turn the TV on by the remote does not achieve anything.
Any assistance would be fantastic.
  • northboy Oct 19, 2007
              Guys I have been flat out at work and ve not had a chance to investigate further. I do appreciate your assistance
  • Anonymous Nov 06, 2007
    I have the same problem with my 55 inch toshiba tv. It will not turn on unless I unplug it. Had it in the shop a few years ago for and he said a wire came loose and he had to soder it. It cost me $100 and had to haul it myself, which it fell over in the back of
    An expert who has answered 500 questions.
  • 556 Answers
Your problem is in power supply
there is a switching circuit in power supply
some capacitor or transistor might be faulty there
also check for loose contact in power supply
it is a simple problem for skilled tech.
good luck
Posted on Oct 15, 2007
My phillips 60 inch tv 60pl9200d/37 wont turn on the power button flashes blue
Look in the manual. (Page 4)
Turn the TV on From main supply: Ensure that the main supply is turned on. A blue indicator light on the front of the TV lights up. When the TV is turned on by the main supply, the blue indicator light will blink for 45 seconds. This is the lamp's start-up period. When the light goes off, press the POWER button on the remote control or power switch. Press POWER to turn on the TV.
Telephone number Philips Customer Care Center: 1-888-PHILIPS (744-5477)
Aug 14, 2011 | Philips 60PL9200D Projection Televisions
Philips 32" tv will not turn on flashing three
You have to check the power supply of you tv for any voltage missing. also check the back light inverter board for any short circuit in it. Inverter transformers in the back light controlling board can become faulty.Three blink indicate the power supply have some problem. First of all replace all the electrolytic capacitors in the power supply board. If filter capacitors in the power supply is bad then this problem can occur.
Jun 09, 2011 | Philips 32PFL5403D/27 32 in. LCD TV
Why wont my tv turn on? a red light just flashes
Right now, your TV is in " Protection Mode". A damaged part has occurred inside on one of the power supply boards. The red flashing light is a trouble code for a tech to trace the trouble circuit path.
If you have electronic experience with circuit boards, you can find a Service Manual for the TV on the internet for less than $20. This Service manual will have the schematics, red light codes, circuit diagram, and part number list you need to fix the board.
Oct 11, 2009 | Philips 42PF9631D 42 in. Plasma Television
I have a polytron tv model 21pp123. No horizontal oscillation
I have a polytron tv model 21pp123 ...whenever I turn on the power its turning off or standby.can anyone help me bout this trouble?
Jun 10, 2009 | Philips Televison & Video
Philips 60p8342 chassy ptv 916
check all your solder connection and test the resistors on the conversion IC's , also check oscilating circuts
Oct 27, 2008 | Philips 60P8341 60" Rear Projection...
Philips 32pw9527/05 tv does not start
Generally these type of problem occurs due to atmosphere contains moisture content. Even if it happens in warm area i suspect fbt leakage. Since this is high voltage transformer it can be serviced by qualified technicians only. Red light flashes indicates the tv in protection mode to avoid severe damage due to some short circuit. I think it is helpful to you
Jul 31, 2008 | Televison & Video
Red blinking light
The red light blibking 6 times indicates that the power supply board has a defective or damaged area. I know this because i had the same problem...bought a damaged tv for parts and replaced the power supply board as the tv would not turn on...wokrs like a charm now.
Jul 24, 2008 | Philips 37PF9631D 37 in. LCD HDTV
26PF8946/37 Red light
Hey habo,
The red light you are referring to most likely is the power indicator light. On many newer TV's this light will appear red when the TV is off or in "standby" mode, and green when the TV is in operation.
Please keep in mind that some TV models may use the power indicator light to notify owners of ay potential hardware problems as well, so you may wish to refer to your owner's manual documentation if you have been encountering any problems during TV operation.
Hope this helps you out.
Go Ahead. Use Us.
Jul 22, 2008 | Philips 26PF8946 26 in. HD-Ready LCD...
Samsung flat screen wont turn on red light just flashes..
wont turn on red light just flashes?
On my samsung flat screen tv when you are watching the televison there is no red light on the power button but when you turn the television off the red light stays on all the time? what can I do to turn this light off?
Jul 20, 2008 | Samsung LE32R73BD 32 in. HD-Ready LCD...
Televison & Video Logo
179 people viewed this question
Top Televison & Video Experts
