Question about GE DBSR453GBWW Gas Dryer
Model DBSR453GB1WW bought around 2004/2005 - Dryer runs but will not heat up?
My GE gas dryer # DBSR453GB1WW runs but does not have warm or hot air. Could it be the pilot?
    President:
  • 1,865 Answers
This model uses an ignitor, you can replace the ignitor for about $80
Posted on May 12, 2009
Dbxr 463 gas dryer no heat
Check the pilot light to see that it works when trying to use. Also gas valve could be stuck or bad.
Aug 24, 2014 | GE DBXR463GB Gas Dryer
WHIRLPOOL GAS DRYER MODEL LFI 5801 PROBLEM= WARM AIR, NOT HOT LIKE BEFORE. CK THE VENTS ALL CLEAR. PLEASE HELP
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 16, 2011 | Dryers
I have an LG model DLE2532W dryer that is taking forever to dry our clothes. I have checked the continuity on the coil and it seems to be fine. I have also replaced the cycling thermostat. The heating unit...
heatman101
Aug 04, 2011 | LG DLE2532W Electric Dryer
When the dryer is turned on it runs for about 5 minutes and shuts off and only gets warm not hot . I tried different cycles but same result the drier is gas you can hear it light so its not a gas Problem...
heatman101[]
Jul 24, 2011 | GE Profile DPSB620GCWW Gas Dryer
GE Dryer DBSR453GB1WW AFTER RELEASING THE START SWITCH THE DRUM STOPS!
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 17, 2011 | GE DBSR453GBWW Gas Dryer
GE Gas Dryer DBSR453GB1WW began squeaking during the most recent drying cycle. We should we try to repair ourselves or get a repair tech?
The squeaking noise is most likely emitting from the drum bearing (key#543). In order to access and replace the drum bearing will require removing the drum. The drum bearing/sleeve is part# WE1M462. I added the instructions on how to remove the drum in the images below. NOTE: Disconnect the power cord from the power source before servicing the dryer.
Jan 13, 2011 | GE DBSR453GBWW Gas Dryer
Changing heat element on a ge 223 dryer
open the door there are twp screws there remove them take top off then the front remove belt and drum the element is in the back
Apr 21, 2010 | GE DVLR223 Dryers
GE DBSR453GBWW Gas Dryer Logo
426 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
