Question about Lanzar VBD1200 CD Player
No Power At All
HAVE JUST PURCHASED A VEHICLE WITH THE LAZAR VBC1200 CD PLAYER IN, ON THE WAY HOME TRIED TO INSERT A CD AND IT WOULD NOT ACCEPT IT, PRIOR TO THIS THE RADIO WAS WORKING PERFECTLY, ONCE I TRIED TO INSERT A CD THE WHOLE UNIT SHUT DOWN AND NOW WILL NOT POWER UP AGAIN, PLEASE HELP
    Problem Solver:
  • 8 Answers
I have a Lanzar radio. The same thing happened to me, as well. If you look behind the radio, you'll see a thick yellow wire, with a black 'fitting' on it. Inside this fitting is a fuse. This fuse blew at least 3 times before we broke down and bought a 20 amp fuse it. Now it plays fine. My problem is that I don't know the factory pass code that is requested to get logos and applications.
Posted on May 06, 2015
I have the same problem with my sometimes. Sometimes it is working fine and when I turn the car back on, it won't go at all. On the back of the head unit, there is a reset button. Press the reset button then press the power button and it should work.
Posted on Aug 08, 2008
Technics SC-CA 1080 CD player jumps ,can I just buy any CD player separate and connect it to my technics? It's a separates 'style' system, not sure if its compatible with a different CD player
You have tried cleaning the lens? That might cure the jumps. Make certain your CD's are not scratched and clean too.
A separate CD player will work with your system, I think. It looks like the current CD player will connect via two phono plugs to the back of the system. Since the new CD player will have the same type, just remove the old connections and the power lead and plug the new CD player in the same phono sockets. As the new separate CD player will have it's own power supply it will not need the old one.
No further adjustments are needed. Any brand of CD player can be purchased.
Jan 21, 2016 | Technics Audio Players & Recorders
My dvd player keeps saying 'incorrect disk' why? and what can i do to stop it?
I don't understand your problem.
Is it the TV or is it the DVD? You say you tried other dvds and the problem is still there. Looks like the TV is the problem. Sometimes it's hard to help people when they only mention on screen issues. How can first DVD say 'incorrect disk' and then another dvd, and another still say 'incorrect disk'? It just doesn't seem to make sense. Is the contents on the disk a computer recorded movie, film or home movie? If so, you have to record the film on the disk with a format that accept the DVD. Could the DVD be a Blu-Ray, can it play a number of video formats, DVD, DivX, KviD DVD, etc.? Try first with a purchased movie DVD disc, if it doesn't work, then the DVD is faulty. DVD players these days are meant to play a wide range of video format, including CD discs. If you have an old DVD player, you may not play latest discs. But if the DVD is incorporated with the TV, then you have to insert a new movie and see if it plays. Go to an appliance or TV DVD store and talk to them. Or you can purchase a new movie and insert it in. If it doesn't work, you can always return it. As you said, you've tried different DVDs, sounds like it is a separate DVD player. If so, try other movie discs. I get the same warning only when I insert discs with movies I recorded on my computer, such as Pinnacle video editor.
Dec 27, 2014 | Digihome LCD TV
When i insert a CD, it won't accept it, "disc error" appears. What is the solutions.
hello there soenensistva
Well first of all Compact discs are easy to be read by a DVD player then ordinary Cd player cause of their lens are made for more compressed Data discs..there for try some of the options
1. make sure that the disc Surface is Clean and don't have finger prints or any other material that is disturbing the the read process between the CD and lens present inside CD player
2.if your CD is precious for you ( that consist some important Data you may need ) then try a DVD player for that
3.if both things doesn't work try a cleaning Cd for Cleaning the Head of CD player .
i wish that your problem may be solved
Best Regards
Oct 15, 2012 | NAD T550 DVD Player
What do you do when the radio says cd failure
CD Failure is what happens when a disk is not burned correctly and trying to play in a Audio CD Player. Or you have a Mass production disk that has some scratched near the inner circle of it. What this means is that the CD player is unable to read the CD you are trying to listen to. This can also happen when the CD player is Dirty on the Lazar Eye that reads the Disk. There is kits at Wal-Mart, Target, and Bestbuy that will clean the Lazar of the CD player. But try a few other CD to see if the issues still happens if it does then might be a the Lazar Eye that is dirty.
Feb 28, 2011 | Sony Xplod CD Player w/MP3 Playback...
Xplod cd player reads Err 99 and wont accept cd
I had the same problem.
i fix it by taking out the cd player and pulling the outer case off. when i looked inside and the (in technical terms) metal bracket that holds the white plastic disc (that i guess holds the cds) inside the cd player was bent down. i am assuming that cds were hitting this when i tried to insert them! i just bent it back up using a knife from the outside. i bent it up until the white disc looked level.
good luck
May 16, 2009 | Sony Car Audio & Video
No CD
I thought they have a place on the web site tou could order one
Feb 06, 2009 | Tomtom ONE GPS Receiver
CD player acknowledge CD, starts to play, then stops
I belevie you have problem in laser assembly it might not worth to repair it
Cheers
Dec 10, 2008 | Audio Players & Recorders
Lanzar VBD1200 CD Player Logo
129 people viewed this question
Top Lanzar Car Audio & Video Experts
Morne Olivier
Chris Ward
xxxxxx xxx
Are you a Lanzar Car Audio and Video Expert? Answer questions, earn points and help others
