Question about Cyberhome CH-DVD 300 DVD Player
Can't get "Netflix" disc out of Player unit - remote or by pushing thebuttons on the unit.
Put disc in DVD player, it loaded and then stopped on Warning message and won't go forward for viewing the movie. Remote won't open the unit so we cannot remove the disc - we read the directions and tried the buttons on the unit and nothing happens. How do we get the disc out so we can return it to Netflix?
My CH-300 has a disc release opening under the unit that reads, "For ejection, insert a pin push to the left." Seeing the post date, your movie is really late or you have solved this issue.
Posted on Jul 26, 2009
Try unplugging the player and then plug it back in again ,then hit the open button. It worked for me . I think unplugging it resets the unit.
Posted on Jun 08, 2009
    President:
  • 814 Answers
You must take off the top of the unit and remove the disc from dvd tray. Take out the screws from the unit holding the top cover on and check the dvd tray for obstructions.if you find none then try to gently move the tray forward through the door and get you dvd movie out. Then check the mechanism for faults such as clogged gears or a broken belt or bad guide rails. You sholud see some problem in the disc carriage area.Try to repair it and test the unit with the cover off, so you can see if the fault is mechanical or electronic.If it is electronic they you should check the circuit boards for bad connections. You may find a bad wire connector or something loose.If all this fails to reactivate the dvd, then take it in to a service center and have them check it out for you. Hope this helps you with your problem.
Posted on May 15, 2009
How do I stop the player from trying to load a disc?
if you put one of the clear plastic disc that come with writeable cd's to protect them, place that in the tray you should be good to go.
Jan 08, 2016 | Televison & Video
Tip
Region free code for Daewoo DVG-6000D
Code 1:
Put a region 1, 2, 3, or 4 and so on into the player when it comes up with "wrong region". Just push the "title PBC" button on the remote and away you go.
Code 2:
Push on the remote, STOP, STOP, SETUP, >>, |<<, >>|, SELECT REGION.
Code 3:
With the player turned on and no CD, push (on the remote) "set-up, <<, >>, |<<, >>|".
Code 4:
Put in any DVD, when "WRONG REGION" appears, press the 'TITLE' button on remote or player.
Code 5:
1. Press the Open button on your remote control to open the disc tray.
2. Press the Setup button on your remote control.
3. Press the Stop button on your remote control.
4. Press the Previous button on your remote control.
5. Press the Next button on your remote control.
6. A hidden menu will appear where you can select 1 for region 1, 2 for region 2, and so on.
on Mar 07, 2010 | Televison & Video
I cannot play a dvd movie or record a tv program in ilo dvdr05 recorder, what might be the problem?
1: Get a movie and some popcorn.
2: Make sure the DVD player and the tv are turned on.
3: Push the button on either the front of the player or on the remote to open the player door to load the disc.
4. Put the disc on the tray that pops out
5. Push the same button pushed previously to close the door
6. Enjoy the movie
Jan 19, 2015 | iLO DVDR05 DVD Recorder
DVD will not load or play. Just keeps saying loading over and over
This probably means that your DVD player has a dirty lens or a tracking problem or both. If the DVD player has a tray, you can try putting an optical disc lens cleaner into the unit. (Slot-loading DVD units may not properly accept or eject the disc. So don't try a cleaning disc in that type of unit.)
Since most DVD players are cheap, it's usually better to replace the unit if the tracking is bad. Similarly, if a lens cleaner does not work, replace the unit. If the player is under warranty, contact the manufacturer.
I hope this helps.
Sep 29, 2013 | Toshiba Se-r0047 Remote Control
I can get the home page up on the tv where it says cyberhome. i put disc in and it says loading and then it says bad disc. what does a bad disc mean?
Assuming the player is fine, the 'Bad Disc' display message usually means either a disc which is an incompatible format (for example DVD-ROM) with this player; a disc which is a region that does not match that of the unit; or a defective/damaged disc. Check the discs prior to using them in this player and if they are burned discs, make sure they are a compatible standard format for playback.
This model is not region-free by default unless stated otherwise in the manual.
Apr 16, 2011 | Cyberhome CH-DVD 300 DVD Player
HOW DO I TYPE NAMES OF CD OR DVD ?
You can't add a title to a disc from a player (such as this). You can only add a title on a disc writer before finishing the disc. (The only exception is RW (rewritable) disc which can be unfinished.) If a title (disc, chapter or track) is on the disc you can display it. Press Title on the remote. If you want to read all of the information on any disc, insert the disc and press Load on the player (when in Stop mode) or press the TV/DiscExplorer/DVD button to set the unit in Disc Explorer mode. It takes about 30 seconds to load the data. Press Stop to cancel the data search. Then use the folder buttons (ALL,DVD,CD,A,B,C,D) on the remote or the player to read the various items. Press Return to leave the folders. If you enter the Disc Explorer while playing a disc, the playback will stop and you will have to press Play to restart (Resume is not an available option).
Once loaded the player will store the data even after you remove the disc. It will clear when a new disc is inserted or you press Load.
The manual for this unit is available at: http://esupport.sony.com/US/perl/model-documents.pl?mdl=DVPCX850D .
I hope this helps.
Oct 12, 2010 | Sony DVP-CX850D DVD Player
My coby-514 dvd won't open up when the open/close
disc is stuck, remove cover screws and carefully remove the disc, do not force the unit, once the disc is out use the remote to close the unit, then use remote to open and use a different disc press play and hopefully it will work, try to avoid not using the remote for all functions,including open-close. do not push tray in manually.
Dec 10, 2009 | Coby DVD-514 DVD Player
Disc not loading
You're going to have to switch off the unit and turn it back on to make it stop. the disk is either badly damaged or the infra red in the remote isn't responding to the dvd player vice versa. hope i managed to help. goodluck. PS also clean the lens of the player as dust causes disk loading probs aswell
Mar 30, 2009 | Televison & Video
Toshiba HD-E1 DVD Player - Region 1 dvd's problem
1) Turn on player
2) Open tray, put disc in tray but don´t close
3) Push T.search on remote
4) Push 1, 3, 9 and "Region number" (e.g. 1 for US discs)
5) Push T. search on remote.
You will see TEST on your player
6) Press PLAY on the remote
Aug 22, 2008 | Toshiba HD-E1 DVD Player
Toshiba SD 4800 dvd player
I've had the same symptoms on the last two Sony DVD's that I've rented. I managed to get around this by hitting one of the menu buttons after the loading message stopped.
Aug 07, 2007 | Toshiba SD-4800 DVD Player
Cyberhome CH-DVD 300 DVD Player Logo
182 people viewed this question
Top Cyberhome Televison & Video Experts
zappal
Electro Med Services...
Henry  Thomas
Henry Thomas
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
