Question about HP LaserJet 3330 All-In-One Printer
A few weeks ago I changed the toner, but the printer was making loud high pitch sound before I changed the toner.
    Problem Solver:
  • 6 Answers
Sounds like somethings jamed in the machine check it out if nothings looks wrong go and buy a new printer
Posted on May 12, 2009
Hp p4015x that is making a loud high pitch squeal
toner cartridge or fuser or laser/scanner assy
Feb 24, 2015 | HP LaserJet P4015N Printer
I have Samsung DLP TV 50 inch HL-P5063W
First thing to look at is the color wheel this model uses--usually it will make a high pitched fan like sound but can make a grinding sound also.
If it slows down from the 12,000 or so RPM speed it will cause color issues.
HAVE GRINDING OR HIGH PITCHED SOUND?
Apr 02, 2012 | Samsung Televison & Video
Drops toner inside machine. I just changed yellow high yield toner cartridge two weeks ago and it just went out. Changed cartridge and their was yellow toner inside machine. HELP
It sounds as if the toner has leaked, maybe it was cracked or seated incorrectly. Toner is so fine that if you use a standard vacuum cleaner the toner may just fly out of the back.
It's still worth trying to vacuum out the spilt toner. Remove all other cartridges first
Inspect the Yellow cartridge for damage to determine if it was that or the printer at fault.
May 18, 2011 | Computers & Internet
My crankshaft is very wobbley and make a very high pitched squeak
You need a harmonic balance. Very common problem!
May 21, 2010 | 1995 Geo Prizm
Our tv made a loud high pitched noise for a few weeks and then the color went green to then shutting off. Now, when we try to turn on the tv, the light blinks and then it just shuts off and keeps repeating...
Hi, Symptom shows high pitch sound is of color wheel that is not spinning any more so TV stay in protection mode and does not power up. TV requires color wheel replacement.
Jun 15, 2009 | Samsung HLN5065W 50" Rear Projection...
High pitched squeal
Hello, This sounds as if it could be a switching power supply problem or a ballast problem. Both will effect your power supply and cause malfunction in various subsystems (audio, screen control, control systems, and the like). I would suggest having a qualified TV repair technician look at the set. This is because there are no user servicable parts associated with this type of problem. I hope this helps, Thank you, Shuttle83 http://www.electron-age-technologies-llc.com
Jun 10, 2009 | Polaroid FLM-3734B 37 in. LCD HDTV
Cs-1510 makes loud high pitch noise when copying
loud noise is usually coming from the laser unit. if you can ger to it, lubricate it's polygon motor shaft with some oil. It usually works fine afterwards. It is a bit of a hassle to remove the laser unit.
Mar 11, 2009 | Copystar CS-1510 Copier
52 in. rca high def. rear proj. making high pitch noise
the set probably has lots of bad solder connection on the flyback and in the horizontal deflection circuit.
Feb 24, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Dishwasher Making Loud High Pitched Noise.
How deep do you want to get into this?It sounds like the wash pump motor bearings that are worn.You can pull the unit out flip it over and wd40 the bearings in the motor or you can replace the bearings.Try to lube them first.
Feb 23, 2008 | Dishwashers
Noisy long high pitch whining fan
Try changing the toner cartridge. I have seen this problem before.
Jun 15, 2007 | Samsung CLX 3160fn All-In-One Printer
HP LaserJet 3330 All-In-One Printer Logo
62 people viewed this question
Seeker5211
Seeker5211
