Question about Kenmore Dryers
How and where to install coils in my Kenmoore Dryer 110-87584100
I was told I needed to install coils in my dryer. I will only ignite once maybe every 2-3 hours when cooled off. Where are the coils located and how do I install the 2 new ones?
  • 4 more comments
  • ali1ahmed2 May 12, 2009
    The model number is Kenmore 100.87584100
    Sorry the model number should be 110 not 100 so it's
    110.87584100. Thanks again.
    I have the coils I just need to know where they are located inside of the dryer by the flame/inginator etc.
  • ali1ahmed2 May 13, 2009
    Thanks I had already looked this same diagram up on sears parts direct and was hoping to get a better picture. Thanks anyways.
  • gene friedman May 11, 2010
    Do you have the model number of the dryer?
  • Bruce Bracey
    Bruce Bracey May 11, 2010
    If you can get me the model number I can send you a diagram.
    Regards,
  • 1,000 Answers
Unfortunately the diagram is of poor quality for this model for some reason, but you can get an idea where the coil is located in relation to the dryer. Item # 16 is the burner assembly and item #70 is the coil. If the old coil is still in the dryer you will be able to see the exact position once you get to the burner assembly.
Good luck, let me know.
Regards,
Posted on May 13, 2009
  • 77 Answers
You can order the parts from sears
Posted on May 12, 2009
I have a LG7188RM gas dryer and it is not heating up
I had a problem with this dryer and the solution was not difficult. The dryer has a system which tests if the ignition source and igniter works. There are two coils for this. The first coil opens and ignites for about a minute or two. Then once this is "OK" the second coil opens and then the gas is allowed to flow fully. If the dryer feels warm after a couple of minutes of dry time and then seems to cool down the second coil is no good and needs to be changed. Just remove the coil wires and ohm each one with a multimeter. The open coil is the bad one. Good luck.
Aug 24, 2013 | LG Dryers
Will start, clothes will tumble but will not heat up to dry the clothes
Run it with the vent off if you feel some heat for the first minute and the airflow is strong you best bet is to change the valve coils.The vent is not a part in the dryer the vent is was connects to the back of the dryer pull the vent off and run the dryer to test.
The coils are on the top of the gas valve.
Gas dryer with no heat: The parts that I have pointed out with the arrows are the parts that you will need to check with an ohm meter if the dryer is not heating. First check and see if you have 110 volts coming to the gas valve at this type of a connector. If you have voltage, then unplug the dryer and check the parts I have pointed to. Some dryers have 3 coils instead of the 2 shown here. If you do not have voltage coming to the burner, then you will need to check the timer contacts that feed the gas burner, hi limit thermostat, operating thermostats, the safety switch on the motor, and any other point that you can see on your wiring diagram picture that feeds voltage to the burner. The coils on the gas valve are very bad for working once or twice and then quitting. If you find a open circuit on one of the gas coils, replace them all = less problems later on. If the glow coil does not work ( get red ), check it with a ohm meter for continuity. The next thing to check if the glow coil does not come on would be the radiant sensor. Inspect the igniter for small burnt spot on dark gray or black part of igniter or check for 110 volts to igniter wire plug when dryer should be calling for heat. Sometimes the ( older style ) igniter is separate from the holder and the holder can no longer hold the igniter tight enough and the two parts burn/arcwhere they touch each other = new igniter and holder ( some manufactures have new kits to replace these older style parts ).
Does the igniter get red and stay red, or does it get red, you hear a click and it goes off, then a minute later its gets red again?....if so you possibly have a bad set of coil valves. If the igniter gets red and stays red constantly then its the flame switch that is bad and maybe welded closed.
Check out, this possibilities.This should help.Thanks.Helpmech.
Mar 25, 2011 | Kenmore 93142 Gas Dryer
My dryer rotates but does not heat up. I replaced the ignitor and it did not fix the problem
Hello there
Gas dryer with no heat: The parts that I have pointed out with the arrows are the parts that you will need to check with an ohm meter if the dryer is not heating. First check and see if you have 110 volts coming to the gas valve at this type of a connector. If you have voltage, then unplug the dryer and check the parts I have pointed to. Some dryers have 3 coils instead of the 2 shown here. If you do not have voltage coming to the burner, then you will need to check the timer contacts that feed the gas burner, hi limit thermostat, operating thermostats, the safety switch on the motor, and any other point that you can see on your wiring diagram picture that feeds voltage to the burner. The coils on the gas valve are very bad for working once or twice and then quitting. If you find a open circuit on one of the gas coils, replace them all = less problems later on. If the glow coil does not work ( get red ), check it with a ohm meter for continuity. The next thing to check if the glow coil does not come on would be the radiant sensor. Inspect the igniter for small burnt spot on dark gray or black part of igniter or check for 110 volts to igniter wire plug when dryer should be calling for heat. Sometimes the ( older style ) igniter is separate from the holder and the holder can no longer hold the igniter tight enough and the two parts burn/arc where they touch each other = new igniter and holder ( some manufactures have new kits to replace these older style parts ).
Jan 10, 2011 | Kenmore Dryers
Gas dryer not heating consistatnly
Hello there
Jan 09, 2011 | Kenmore Dryers
Gas dryer no heat frigdarie
Things that could stop a gas dryer from heating:
- glow bar igniter, thermal fuse ( not all models ), coils on the gas valve, gas valve, thermostats,motor heat switch, timer, selector switch, sensor.
Gas dryer with no heat: The parts that I have pointed out (click it )
Sep 11, 2009 | Frigidaire Dryers
Kenmore 74812 Gas Dryer. Was told it ignites,
The coils are not so that it will leak when they are removed. Two screws release the bracket on top of them and they slip right off.
Eric
Jun 22, 2009 | Kenmore 74812 Gas Dryer
Dryer not drying.
I don't know what the noise is but I had the same problem with the drying. I checks several sources because I don't like to replace parts that are not broke. the problem was 2 coils near the pilot light. Each is held on by 1 screw and a wire gets plugged into it. Easy fix and ran fine again. I think the coils are a comment problem because as soon as I told the parts place what kind of dryer I had they told me what I was in for.
Mar 02, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Kenmoore Dryer will not start
ok im with you,,send me the model #..and check your door switch..i want to veiw schematic on this,,,we have a defective part..
Jan 17, 2009 | Kenmore 63942 Dryer
Kenmoore dryer
hook it back up. you need to vent it out side.
Dec 16, 2007 | Kenmore 62602 Electric Dryer
Dryers Logo
138 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
