Question about Kenmore 63352 / 63359 1100 Watts Microwave Oven
How do i set it to 50 percent cooking power
1100 watt kenmore microwave: How do I set it to 50% power for cooking? I have lost my manual... please and thank you!
SOURCE: Model 721.80803400 microwave blank control panel
How old? Probably better to buy a new one instead.
Posted on May 30, 2007
MicrowaveSvc
  • 9086 Answers
SOURCE: Kenmore Microhood 401.80089 - L SE L error
The 401 model prefix means it's actually made by Samsung.
On some Samsung models, there is an odd SE error message that seems to be vexing a lot of people.
It's probably a sensor going bad, or maybe scrambled code in the microprocessor, but it's odd.
There is one discussion of it here.
I hate to say it, but since it's a Kenmore brand, you're going to have to call Sears for service.
You can find them at http://www.sears.com
I really hope they can help you.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jun 08, 2008
SOURCE: wiring diagram Problem - Maytag MMV5207A 1100 Watts Microwave Oven
I have a micro wave national nn-v688w. now the high voltage control bc board which is gos to magnatron is useless i want to use a simple transfomer to oprate. the problem is it works for about 15-30 sec and stop the display say H87. i know i need to bild a new circut to oprate the oven so do hahe an idea.my email; raju karki05@gmail.com. thahk you
Posted on Nov 12, 2008
MicrowaveSvc
  • 9086 Answers
SOURCE: kenmore galaxy microwave model 721.80002 1500 watts does not heat
With the symptoms you have, I would most strongly suspect a shorted high voltage rectifier diode or a bad magnetron, or a loose and possibly corroded connection on the magnetron's terminal.
The diode is a fairly cheap fix, and the mag will cost more.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you don't find yours, or if you want to look at it without disassembling the oven, you can download it here.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
http://www.gallawa.com/microtech/diode.html (if it's not shorted, it's probably okay)
http://www.gallawa.com/microtech/mag_test.html
http://www.gallawa.com/microtech/xformer.html
Posted on Dec 22, 2008
  • 3 Answers
SOURCE: my microwave is locked and i dont know how to unlock it
"Locke" meaning the door? or locked meaning the buttons don't work? If it is the buttons then you have the child lock on. Push and hold the "Start" button for 4 to 5 seconds, and it will unlock.
Posted on Jun 05, 2009
If I want to cook a microwave dinner that cooks for 9 minutes @ 50 percent power how do I do this?
Cut the time in half if your machine doesn't have the setting for 50% power.
Jul 19, 2017 | Microwave Ovens
How do I set the timer and use the cook function at the same time on my Kenmore microwave model 405
Either your microwave is defective or you don't understand how to use it. Try Googling (Kenmore)(74229)(manual) without parens to get instructions or go to www.searspartsdirect.com for the same.
Sep 16, 2016 | Kenmore 74229 Elite Black Countertop...
Kenmore Elite countertop microwave model 721.79153010 has no power, completely stopped working.
has an internal fuse. but you need to find out why it has blown, has it been making any funny sounds while cooking. ??
Mar 09, 2014 | Kenmore Elite 1.5 Cu. Ft. Countertop...
How to set microwave 50%
You have to put the cook time in first and then you press the power level button (just below the number 7 on the keypad) and put the power level in. The choices are 1 through 10. Fifty percent is probably power level 5. Once you have put in the power level, just push the Start button and it will start cooking.
May 11, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Question: Can the Tastiwave oven be used?
I don't own one but per the TastiWave Quick Start Guide (which can be downloaded as a PDF document), The wattage must not exceed 1300 Watts. In the Instruction manual and quick cook recipe guide (also a downloadable PDF document) it states that:
"The recipes in this booklet have been written for an 1100 Watt microwave oven. Please adjust your “cook times” accordingly. Microwave must have a revolving turntable and the interior
must measure at least 14” wide x 14” deep x 7 3/4” high".
I hope this answers your question ;-)
Jul 24, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
I have a microwave and I am not sure of the wattage . The model # is JES738WJ02 And seriall # is DS991786u could you please help me find the answer to how many watts this product is. Thank you
Your microwave oven is 700 watts. Its printed on front of the owner's manual. If you no longer have an owner's manual, you can go to managemylife.com and download or print a copy for FREE. Just type in the model number you provided under the "Manuals" link. Your manual is listed in .pdf (Adobe) format. I hope this help you.
Feb 28, 2010 | Microwave Ovens
Oven cooks but turntable will not turn, so it cooks unevenly. How do I reset the keypad so it goes back to normal factory presets, in case I entered something that stops the turntable revolving. Is there...
The manufacturer has set the rotational plate in motion at the same time the microwave tube is energized. They work together as a team. At no time should the plate be idol, unless you remove it completely, and then only the center spindle will turn by itself. It is possible for the rotational spindle in the center of the oven to break, but that is unusual unless some sort of pressure (like stopping it when it was moving) was applied. Also, it has been reported that some individuals tend to put items with too much weight or too large for the oven to manage; thus damaging the rotator. As long as the oven still provides Microwaves to cook your food, it is still OK. Years ago, there were no rotating plates and using the energy was all it took to get the job done. For even cooking, just manually stop the oven at times and turn the food to avoid over heating in one spot.
Jan 14, 2018 | Kenmore 62222 / 62229 1100 Watts Microwave...
Power level
The numbers DO NOT equal a certain power level Erin. They equal a percentage! This is very confusing. Even the factory reps. can't explain it adequately. I recently replaced my old 600 watt oven with a GE 1100 watt model. The 600 watt unit came with a great cookbook. (I searched the internet but couldn't find one for the GE oven and the factory was no help!) A chicken recipe in the 600 cookbook said cook on high for 30 minutes. Since 600 is approx. half of 1100, I cooked on high for 15 minutes. Result: Uncooked chicken...
The next time I cooked 30 minutes on 50% power (button 5) and It came out OK. I have since used 50% power with meats in cooking bags with good results. Remember to check for correct temp. with a meat thermometer when oven stops. Trial and error is your best test at this point I'm afraid. Also you may want to type "Microwave Conversion Chart" into your browser. You will get some additional information from this. But read carefully!
Ray
Nov 16, 2008 | GE XL1800 1100 Watts Microwave Oven
Instruction manual
I have found that GE dosn't support their products very well. As a technician I have researched this as I also have a GE Microwave. Sadly there are no cookbooks for this unit either. I have found (don't hold me as an expert on this) that you can generally use your 600 or 700 watt recipes in the 1100 watt unit by using cooking level 5. (50%) Also type "Microwave conversions" in your browser for other ideas. Hope that helps.
Ray
Nov 13, 2008 | Microwave Ovens
1100 watt diplomat microwave
Please reply back with your brand and model number so we can help you.
Aug 20, 2008 | Microwave Ovens
Kenmore 63352 / 63359 1100 Watts Microwave Oven Logo
315 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
