Question about Canon imageRUNNER C3200 Copier
Will not saddlestitch
My IR3200 will not saddlestitch on a 8.5x14 piece of paper. It will not even fold the paper??
AFAIK, not supported. Just LTR R and 11X17.
Posted on May 13, 2009
Cleaning a shredder that has sticky paper stuck to the cutters. A EPS-611x.
FIRST MAKE SURE THAT YOU HAVE REMOVED POWER
UNPLUG IT
Using pick remove the paper that is stuck to the cutters,
also you could try shredder oil to assist after you have removed
a majority of the sticky paper...Take a piece of paper fold it
in half, apply a bead of shredder oil the length of the folded paper
Run it through the shredder like you would a plain piece of paper keeping it folded
Sep 05, 2017 | The Office Equipment & Supplies
What does it mean when the instructions say to Cut On Fold. I am new to sewing.
It usually means that the pattern maker is saving paper by giving you only 1/2 of the pattern piece--the center of the pattern is laid on the fabric fold. You cut out only 1/2 of the pattern but when you unfold the fabric, you get a full piece because it is a mirror image of the other half (like the back of a shirt). The fabric is folded so the selvedges match. The pattern's center back is placed on the fabric fold. Essentially, after you've cut out the pattern and unfold the fabric, you will have the whole back.
The lay-out pattern will show those pieces placed on the fold before they are cut out.
How to cut fabric with paper pattern
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=3&ved=0ahUKEwi9p-W1iqzUAhVK64MKHQoED9UQFggxMAI&url=https%3A%2F%2Fwww.g-w.com%2Fpdf%2Fsampchap%2F9781605259970_ch08.pdf&usg=AFQjCNGRpTOJawKLsyi2ShLph4ucyEOvfQ
How To Arrange or Layout Sewing Pattern Pieces Updated
Jun 06, 2017 | Sewing Machines
How to use booklet maker
The HP booklet maker/finisher with output accessory bridge provides two 1,000-sheet stacker bins and a booklet bin with stapling, saddlestitching, and v-folding capabilities.
Sep 06, 2012 | HEWLETT-PACKARD Q6999A Finisher, Mailbox...
Left corner is folded down on page
Sounds like an issue with the feed rollers. The roller on the left side might be hung up and is causing the corner to fold over when the paper is pulled through. I would try checking the feed rollers in either the actual tray or the back of the printer. Another thing to check is the other tray (the manual one). Does the paper fold? this should help you narrow down where the problem lies.
Mar 02, 2011 | HP LaserJet 4350 Printer
When receiving a FAX or printing a receipt, it repeatedly jams. The paper is found inside the back cover baked into a folded fan shape.
This folded pattern indicates that the jam is being caused by a physical obstruction in the paper path section. I would suggest manually feeding a thick piece of cardstock paper and seeing if you can find the location of the jam, as it is most likely a piece of trapped paper or plastic tab that has come out of its original position.
-David.
Nov 05, 2010 | Brother IntelliFax-2820 Laser Fax
Printer keeps telling me that paper is jammed, but it is not. have switched on and off and tried folded paper down to rollers but nothing is blocked. what can i do?
Even the tinest piece of paper can cause this and also a sensor needing cleaned. Take a small flashlight and examine every nook and cravice of the computer. You may find a piece of paper. Take a lint free cloth and clean inside the machine as well and then try it.
Jun 18, 2010 | Lexmark X4875 All-In-One InkJet Printer
Camera plate has lots on play in it. slides and rocks back and forth. very loose.
If it is a manufacturing flaw, contact the company. If the company is unreachable, or you have to pay for a new part and want to save money: try folding a piece of paper and putting it in the mounting tray the plate attaches to. The paper between the plate and the mounting surface will serve to fill the void that the plate is free to move around in. Fold the paper as many times as you have to until it is thick enough to fill the void. Experiment with the best place to put the paper to eliminate play. You may have to put more than one piece in the tray to achieve even results and avoid the camera being cocked when the plate is mounted.
Dec 16, 2009 | Manfrotto Photography
Hp laserjet 1320 folds corner of paper after it prints.
Open the back of the printer - make sure it is clear. Then remove the toner check throughout the printer - reseat the toner and try to print
Jun 18, 2009 | HP LaserJet 1320 Printer
Martin Yale Paper Folder Problem
Im not familiar with a paper folder but if its anything like a printer, it probably has a maintenance kit you can buy or you may have to replace the rollers. Alot of the times they have a rubber grabber that wears out or a roller that gets dirty and doesnt catch the paper evenly and pulls it through at an angle, crinkling it. Check for debree or paper particles that may be floating around inside.
Jan 02, 2008 | Computers & Internet
Canon imageRUNNER C3200 Copier Logo
42 people viewed this question
old marine
old marine
