Question about HP Pavilion dv6000z Notebook
Not working for my vertical scroll zone howcan activate this problem
  • PC-Pit-Stop
    PC-Pit-Stop May 11, 2010
    it doesn't work using touchpad?
  • 696 Answers
Assuming you're talking about the touchpad, this can be enabled and disabled in your control panel.
Open your start menu, then Control panel, if it's not in classic mode click the Classic View link in the top-left corner. Now open the mouse icon and select the Device settings tab(red logo), now click the settings select by single clicking the synaptics touch pad from the list. click the settings button below the list and select the "Virtual Scrolling" section.
You will see two check boxes, the First enables the marked off vertical scrolling feature, the second enables a horizontal scrolling feature that may not be marked on the mousepad but runs along the bottom of the pad and works the same way.
Click OK, on both windows and close the comtrol panel.
Hope this helps FixYa, if not reply back with any additional info you can,
Chris
Posted on May 13, 2009
  • jasonanand Jul 10, 2011
    Thanks alot man.. You saved my day.. =)
2 Suggested Answers
SOURCE: Touchpad Vertical Scroll zone not functioning
you can activate this by
1. going to the control panel on your vista machine, make sure you are in classic view
(2) double click the mouse icon.
(3) From here you will select the "Device Settings" tab,
(4) make sure your Synaptic Pointing device is highlighted and then click the settings button located directly below the "port" column, this will bring up properties for this device.
(5) With all categories in the left hand column collapsed, select "Virtual Scrolling" here is where you will find the box that needs to be checked to enable vertical and/or horizontal scrolling.
(6) make sure the "Enable Vertical Scrolling" box is checked.
(7) don't forget to hit apply!
I hope this helped some people. I am using a HP dv7 so your menu may look a little different. Happy holidays.
Posted on Dec 27, 2008
Scroll zone is active but webpages can't be scrolled
It is obvious that the problem is a compatibility problem. You need to post the problem in the Firefox community to get help.
Feb 12, 2014 | Acer Aspire 3000 Notebook
The touch mouse will scroll and move but won't click.
you might have to reset it
Most modern laptops with touchpads offer vertical scrolling, horizontal scrolling or both. These features are located along the right-hand and bottom edges of the touchpad, respectively, and are activated when you swipe your finger along the touchpad edge. Scrolling functionality is nearly always enabled by default, but some users find the feature an annoyance and elect to turn it off. In most cases you can simply turn the feature back on using the Windows Control Panel.
Click the Windows Start button, select "Settings," and then click "Control Panel." Double-click the icon labeled "Mouse." Select the Touchpad properties tab. The labeling of this tab varies, depending on your computer manufacturer, operating system version and the device drivers installed on your machine. Common labels include "Touch Pad," "Device Settings" and "Dell Touchpad." If you do not see this option, you may not be able to turn on scrolling for your laptop; skip the remaining steps and refer to the "Warnings" section below. Click the "Settings" button within the Touchpad Properties menu and look for the section labeled "Scrolling Settings" or similar. Enable scrolling within this section and define other scroll settings, such as scroll zone width and scrolling speed. Click "OK" to confirm your changes, and then close the Control Panel windows opened in the previous steps. The scrollbar on your laptop is now enabled.
Scroll Is Not Working With Windows 7 b> Certain computer touchpads have a vertical section on the pad itself that is used to scroll through the page or program window that you are currently viewing on your computer. If the scroll functionality suddenly stops working but the actual touchpad is still fine, this means that the part of the software for the device that controls the ability to use the scroll has been disabled. You can enable it again in the Control Panel.
Click "Start." Click "Control Panel." Click "Mouse." Select the "Enable Scroll" option (or whatever similarly named option is available on your specific model of laptop computer). Click "Apply." The scroll bar on your touchpad will now work again.
b>
Feb 15, 2013 | HEWLETT-PACKARD Hewlett Packard HP 6730b...
My scrollbar will not work. I can use my touchpad just right and right click and left click, but I cannot scroll on a page I have to use my arrow keys, how do I fix this?
b>
Feb 03, 2013 | Acer Aspire 5750-6438 - 25519
Scroll bar
Feb 03, 2013 | Acer Aspire Computers & Internet
I have a HP pavillion DV6-1250us Windows vista home premium and i cannot get my mouse to scroll up or down? how do i fix this?
To move the pointer, slide your finger across the TouchPad surface in the direction you want the pointer to go. Use the TouchPad buttons like the corresponding buttons on an external mouse. To scroll up and down using the TouchPad vertical scroll zone (right edge of the touchpad), slide your finger up or down over the lines.
NOTE: If you are using the TouchPad to move the pointer, you must lift your finger off the TouchPad
before moving it to the scroll zone.
Mar 03, 2011 | Computers & Internet
I dont understand where the scroll zone is on my hp mini. Is it actually on the touch pad, and if so where?
If it is on your touch pad it will be indicated with a small vertical bar, on the right hand side. Slide along that to scroll.
If it doesn't work, then the laptop doesnt have one, and you'll have to use the scroll bar at the side of a web page. (double tap but keep hold on the second tap, this indicates holding down a click) then move up or down as required.
Hope this helps,
Andy
Mar 06, 2010 | HP Pavilion dv4000 Notebook
Vertical scrolling not working
May 22, 2009 | Compaq Presario CQ60-220US PC Laptop
Jun 07, 2008 | HP Pavilion dv4000 Notebook
Gprs
Which Carrier? You can try this if its t-mobile, otherwise find the carrier specific settings and replace the t-mobile with the carrier settings.
Data Profile Setup:
  1. From the main menu select My Data > WAP > WAP Profile
  2. Scroll to an empty profile and select Edit
    • Set Profile Name to T-Zones GPRS
    • Set Homepage to wap.t-zones.com
    • Leave User ID and Password blank
    • Set IP Address to 216.155.165.050
    • Set Port to 8080
    • Set Show images to ON
  3. Press Save
  4. Select Activate
MMS Setup:
  1. From the main menu select Messaging > MMS > Settings > WAP Profile
  2. Scroll to T-Zones GPRS and select Activate
  3. Press Back
  4. Select MMS Server
  5. Scroll to an empty profile and select Edit
  6. Press Save
  7. Select Activate
  8. Power cycle phone and test
Jun 06, 2008 | NEC e122 Cellular Phone
Zone 2
I am sure this isn't it, but if all components are connected digitally Zone 2 won't work. It only allows analog connections, so anything attached via HDMI, etc. will not be able to be output to Zone 2.
Dec 08, 2007 | Onkyo TX-SR605 Receiver
HP Pavilion dv6000z Notebook Logo
667 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
