Question about Exercise & Fitness
Instuctions required for CPH pedometer
Instuctions for cph pedometer
4 Suggested Answers
SOURCE: replacing TSTAT for my Goodmans
5 will be the most economical CPH means cycles per hour . So the thermostat will only let the heat strips come on 5 times a hour. You should not need the aux heat except on the coldest days.
Posted on Nov 30, 2008
james3751
  • 614 Answers
SOURCE: I have a new York hybrid heat pump/gas furance
Did they check the sensor in the plenum. You are suppose to have bonnet sensor to switch from heat heat pump to gas whaen it is to cold for the heat pump. The bonnet sensor may be to bad. The unit is cycling ever five minutes because it may have five minute time delay.
Posted on Dec 15, 2009
SOURCE: I lost owners manual for
you know imei no. than come first one fir no. from police station near and go to mobile centre
Posted on Mar 24, 2011
Why is my honeywell 8320r1003 short cycling for hot water heat.I have heat set at 65 degress.cycling 2min,3min,the most is 8min.
Hi Bill, after closing your thermostat, is this correct the situation?
And how far is your thermostat from your baseboard heater, if the baseboard is underneath the stat, you should move the stat elsewhere. Hope this help you find the problem.
Jan 03, 2015 | Honeywell TH8320R1003 VisionPRO 8000 w/...
Bad instuctions
looking for a manual for a 354 pedometer with radio
May 25, 2013 | Watches
I lost owners manual for celphon cph-a640
Mar 23, 2011 | Cell Phones
AC unit goes on and off every 3 minutes
It should not be doing that. The thermostat is pre-programed for only 4 cooling cycles per hour. You can change the program by :
�� To access the configuration menu, press both up/down buttons
simultaneously for 3 seconds.
�� To go to the next parameter (menu item), briefly press both
buttons simultaneously.
�� To modify a parameter, press one of the buttons.
�� Repeat steps 2 and 3 if necessary.
�� Press both buttons simultaneously for 3 seconds to exit
the configuration menu.
You are looking fpr parameter CPH this number tells the unit how many time per hour to come on lower it to leghten the time betwen cycles.
Jul 12, 2010 | Honeywell Electronic Programmable...
My furnace ignites and runs but wont run long enough to bring the house up to temp.
How long does it run? a few seconds or a few minutes?
I would check the air filter first. Then next time it runs, check the circuit board for any flashing lights. You may have an error code stored. There should be a small viewing port in the lower panel that looks into the cabinet of the furnace. If you have to remove a panel to see the circuit board, you may shut off power to the unit which will erase any error code. Once you find the light, check on the wiring diagram that is pasted on the reverse side of one of the panels for a diagnostic chart. It may give you a starting point where to look if you have an error code.
Feb 22, 2010 | Goodman GMS90703BXA Heater
Dec 15, 2009 | Honeywell Programmable Thermostat Heater
Replacing TSTAT for my Goodmans 3 ton heat pump. Only question I have is optimal setting for AUX heat CPH .. I think 5 or 6. ????
Nov 30, 2008 | Heating & Cooling
Dell Dimension 8250 Memory Question
Computer Memory Information Upgrade Questions Troubleshooting Memory Diagram Upgrade Help Buying Tips · Memory definitions. MEMORY ABCs. Memory, which is commonly referred to as RAM
Installing PC computer memory Additional information and help with isntalling PC computer memory. ... Installing a PC computer memory. Question:. Installing PC computer memory.
Determining type of hardware within computer Reference, Issue / Question. Memory, Information and help with computer memory. CH000149, How to determine system resources / RAM available?
Buying tips on computer memory. How much memory should I get? This question really depends on the type of computer user you're and what type of programs you plan on running on the computer
Determining what type of memory to use in a memory upgrade. Determining what type of memory to use in a memory upgrade? Question:. Determining what type of memory to use in a memory upgrade.
E-mail CHID: 5683
Good Luck read and follow instructions will find your answer.
Good Luck, Please dont for get to Vote/Thank You.
Dec 20, 2007 | Dell Dimension 8250 PC Desktop
Exercise & Fitness Logo
Top Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
