Question about Kenmore 62602 Electric Dryer
Dryer will run about 5 mins. then trips the circuit breaker.
Model 110-62802101
Serial Mm2924922
Type: DWJR-ELE-2406028-HOMF
Please advise. Is the breaker becomes weak? or I should replace the heating element?
Thanks
Clessa
clessa@yahoo.com
  • 1 more comment
  • Anonymous Oct 27, 2008
    I have kenmore dryer series 80 which runs about 30 min then trips breaker.
    Do you think it is breaker? or...
  • Anonymous Mar 15, 2014
    after 5 mins it dryer gets hot and trips circuit breaker
  • Anonymous Mar 26, 2014
    dryer tripped breaker, then I switched breaker back on, dryer now runs but will not heat
  • 291 Answers
I would change the breaker frist and see if that sovles the problem
Posted on Oct 14, 2007
I have a Whirlpool DWJR-ELE-2406028-FM54 and when I open the door (while machine is running), the drum keeps turning. How do i remedy this?
sounds like the door switch is broken,good thing it broke in the running position or the dryer wouldn't start.that isn't a good model number either,open the door look around the opening where you put the clothes in and you should see a tag with the model number,you'll need that to order the door switch.the dwjr comes up but not the rest if this is a ge dryer.
Feb 05, 2018 | Whirlpool Dryers
What is the capacity of a Kenmore dryer model 110 62622100
The dryer should hold what the washer will hold especially if there a matched set this one looks like a super cap. hope this helps
Feb 18, 2015 | Kenmore Dryers
Kenmore electric dryer DWJR-ELE-2406028-FM54 Model 110.64632300. when we close the door the start button doesnt work until we close it 5 or 6 times. Help.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 01, 2011 | Kenmore 64722 Electric Dryer
My Kenmore 400, Mod 110.68432700, Ser MU4103673, Type DWJR-ELE-2406028 trips the breaker at the breaker-box after a few minutes of running (either low or high heat). No problems with the breaker when I...
Standard house boards trip only with two things high load or high earth leakage.
First stop check the plug wiring pay particular attention to the tightness of each terminal. Unplug and check along the incoming cable for breaks, crushes ,traps,etc.
If this fails unplug and have a look at the internal wiring, it can become brittle and touch the outer casing because the insulation is missing, check if any terminals inside are loose as well. Failing all that the heating element will probably be in a poor state and will probably cost more to replace than to buy new.
Aug 01, 2011 | Kenmore 64902 Electric Dryer
Whirlpool Ultimate Care II dryer trips breakers.
No way to know unless you do some checking. This video shows how to get into the machine: HERE
I have a repair manual that features the same basic style of dryer you may want to take a look through: HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Feb 14, 2010 | Dryers
Where do you find a heating element for a Kenmore Model #110.66662500. Serial: MT0203728 Type: DWJR-ELE-2406028-FM54
Grainger.com is easy or you can look thru the yellow pages for a local appliance repair store, for parts.
Nov 10, 2009 | Kenmore 62602 Electric Dryer
It appears the heating element went out on our older Kenmore dryer - Type DWJR ELE 2406028 FM54. mod 110.62622101. Is this an easy fix?
Yes it is fairly easy to replace from the back. First verify it is the element and not the thermal fuse or a loss of one leg of the 240VAC circuit.
Eric
Jul 06, 2009 | Dryers
My 2006 Kenmore electric dryer stopped running. We checked the plug and the breakers and don't see the problem. The codes on it are DWJR-ELE-2406028-FM54; 110.66652500. We can't find the owners manual. Any...
if you take the back off of your dryer and look for a little white thermo fuse with 2 wires on it if you unhook the wires and plug them together than start the dryer if it starts shut it off and replace the fuse and clean your venting
Mar 01, 2009 | Kenmore 659 Electric Dryer
Dryer runs no heat
Sounds to me you either blew the fuse or tripped the circuit for the heating element. Try replacing the fuse or resetting the breaker before trying any repairs.
Jan 09, 2009 | Kenmore 64602 Electric Dryer
Dryer don't blow hot air, everything else runs ok.
you need to check the heating element and the thermal fuse to see if they are blown.
Dec 19, 2008 | Kenmore 659 Electric Dryer
Kenmore 62602 Electric Dryer Logo
347 people viewed this question
Top Kenmore Dryers Experts
Sal De
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
