Sata drive not recognised - Computers & Internet
  • 1 more comment
  • RescueTechLA
    RescueTechLA May 11, 2010
    Can you give some more details. Desktop / Laptop.
    Where you got the drive? Details, details, details...
  • jkpf May 11, 2010
    Can you give us the model and brand of your motherboard?
  • Serbob May 11, 2010
    Is the a new drive or old drive? Are you installing it? What OS?
    Sergeant:
    Champion:
  • 225 Answers
Good morning! please check if it has a drive letter. Go into Control Panel -> Administrative Tools -> Computer Management and choose Disk Management from the left pane. Right-click the drive, pick "Change Drive Letter" and start fiddling. regards
Posted on May 13, 2009
I installed a sata dvd drive in my dc5100 sff the boot order recognises it as an ide drive
i dont think it matter if your system detects it as sata or ide, both interface will work in installing OS, the important thing is you changed your boot order. originally it was supposed to boot in 1st drive whichever it is hard drive or dvd drive. go to bios then follow the instruction in how to move the order of boot sequence, mine is SHIFT key then PLUS.
Feb 28, 2014 | HP Compaq dc5100 Small Form Factor PC...
Compaq Mini 700EL hdd not recognised
If you are installing Windows XP then -
The problem is that XP installation CD does not have a SATA driver, unless you have a SATA drive on a disk etc. and can install the driver when XP asks for a hard drive driver then, XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS and disable the SATA drive (enable IDE emulation), this will make XP think it is a IDE/PATA hard disk. Then you can install XP normally. When Windows has been installed then install all the device drivers (including the SATA driver), then shut down and boot up and got into the BIOS and enable the SATA drive.
Oct 08, 2012 | Computers & Internet
Am trying to reistall Win XP. Have run Fdisk and reformatted HDD. PC will not recognise install CD, keeps coming up with errors, does not find CD or HDD. Hav also tried running setup from floppy, again...
IF the hard drive is a SATA hard drive, you will first of all need to download the SATA drivers for te motherboard and copy them to a Floppy drive on another computer if yours will not work, this may also affect why it is not "seeing" the Cd drive if this is a SATA one too
Try installing Windows and when the message " press F6 if you want to ...." appears, have the floppy inserted in teh floppy drive so it can find thr SATA drivers, it will then recognise the Hard drive and install
If you have further problems please repost
Jan 03, 2011 | Gateway GT5056 PC Desktop
SATA hard drive not recongised.
hi, sorry but i have to ask the question , why did you take the drive out of a external drive then buy a kit so as you can use it as an external drive , if its because the Seagate casing is damaged then its highly likely the drive is damaged too .
Apr 28, 2010 | Seagate 1 TB SATA II Hard Drive
Iam having a pcchips m861g mainboard,and the problem ihav now is my mainboard isnot recognising the sata hard drives,its recognising the ide hard drives.i checked my satahard drive in another mainboard and...
Its settings in the bios. Press DEL or F2 at startup and look for something like drive configuration in there and set SATA to enable. Most boards have this turned off by default. Cheers from Scott
Jan 20, 2010 | PC Chips M861G Motherboard
Maxtor one touch iii unable to read drive; the external hard drive previously worked and now it doesn't read the drive
please remove the raw drive from the casing
it may be a sata drive of maxtor please power it up directly to your pc with a sata power and sata cable
the drive will get recognised .
if it gets recognised it means the interphase between the disk and the ext casing has been damaged
if you fail , the disk has lost its firm ware or rom chip rom bin file.
both can be flashed and recover the drive
BEcaerful you can break the plastic casing while removing the raw drive as it had been machine dyed and fixed and you may not find any screw s outside
datarecoveryfactory
Sep 04, 2009 | Maxtor OneTouch III FireWire 400 (F01G500)...
Cant load xp onto sata HDD
To use XP with a SATA drive you'd need to use the HDD disc software first as XP didn't come with preloaded SATA drivers. This is what is preventing you from installing XP on the drive. Once the driver is loaded you should have no problem. If your new hdd didn't come with a disc then you can download it from the hdd manufacturers website under the support link. Hope this helps.
Jul 12, 2009 | Seagate (ST3250824AS) 250 GB Hard Drive
Windows 2000 advanced Server does not support Seagate 250 GB Hard Drive.
I am inclined to think that this would be a problem with the jumper settings limiting the size of the drive.
I can't offer anything more than that, sorry. Hope it will help a bit.
Aug 08, 2008 | Seagate (ST3250824AS) 250 GB Hard Drive
SATA Disk Problem
Is it a SATA II drive?
If so, you need to jumper the drive to "downgrade" to SATA I before the Via controller will recognise it.
WD5000AAKS needs to jump 5+6. I don't know about other drives, but I'm sure you can find it.
I hope I've made your day, just as this info did to me when I found it!
Nov 02, 2007 | Foxconn MB KT600 600A01-6LRS Motherboard
Computers & Internet Logo
107 people viewed this question
David Payne
David Payne
