Question about Kenmore HE2 Plus Front Load Washer
Front door is locked and I can't get it open
My kenmore he2 door is locked and won't open. How do I get it unlocked?
  • 34 Answers
Hello shoya_garris,
There is a manual release tab you can use to open the door. Make sure you unplug it first. Remove the bottom front service panel. Carefully reach up and pull the manual release tab on the bottom of the door lock assembly until you hear it click. Wear some gloves there can be sharp edges on the inside of the machine panels. Hope this helps.
Thanks,
edgin96
Posted on May 13, 2009
Lights keep flashing and door locks without finishing cycle
Kenmore HE2 Plus Front Load Washer Keeps unlocking ...
www.fixya.com > ... > HE2 > Kenmore HE2 Plus Front Load Washer
flashing prewash and add garment lights My HE2 Plus will fill with water, but when ...Kenmore HE3 2plus wont finish cycle Washer wont finish the last1 minute of cycle. ...We ran a load twice and it still did not unlock. du is the code for cannot ... Why does the door keep unlocking and locking in between the drum rotating?
Admiral, Whirlpool, Maytag - Washer Repair - Not ... - YouTube
? 5:51
https://www.youtube.com/watch?v=oBihToN6dxs
Sep 6, 2013 - Uploaded by ApplianceVideo.com
Troubleshoot your Admiral Top Load Washer that has these following symptoms: Not Completing all Cycles ...
Washing machines - Ariston
Jan 05, 2016 | Washing Machines
Open locked door
To open the door when locked. Start new wash cycle and the door will lock - unlock then lock again. when it unlocks open the door quick.
Feb 15, 2015 | Kenmore HE2 Plus Front Load Washer
The machine is locked and can't open with clothes washed inside,. Add garment light is on and the time is flashing'
Whirlpool-made Front Loading such as the Kenmore Elite washing machines use a door lock and switch assembly having a tab that can be pulled manually for emergency opening of the door. This tab can be accessed with the removal of the lower front access panel. Disconnect power to the washer and drain the water from the tub before accessing it. The link below contains the detailed instructions on manual unlocking of the door.
Manual Unlocking of Whirlpool Duet and Kenmore Elite Front Load Washing Machines
Aug 26, 2011 | Kenmore HE2 Plus Front Load Washer
I have a kenmore HE 2plus. i am getting a f-21 error reading and door won't unlock, what is the problem and how do i get the door open?
f 21 usually means drain pump is bad. may need to check door lock an see if it reads 15 ohms across the output. if its more than 15 change the door lock
Jun 03, 2011 | Kenmore HE2 Plus Front Load Washer
I notice F22 error message on washer. Door seems to be jammed and will not unlock
This is a door lock failure code and it means the door lock is broken or just failed to unlock. Click on the links below for the detailed instructions for manually unlocking the door and replacing the door lock and switch assembly if it has indeed failed.
Manual Door Unlocking of Whirlpool Duet and Kenmore Elite front-Load Washing Machines
Replacing the Door Lock and Switch Assembly on Whirlpool Duet and Kenmore Elite front-Load Washing Machines
Mar 12, 2011 | Kenmore HE2 Plus Front Load Washer
My washer say f28 it is a kenmore HE2 plus
"F28" means your washer is locked and not unlocking. To unlock your washer take the bottom access panel off by removing the 3 bottom screws.Reach up near the latching assembly & attached to the door latch is a little plastic pull lever. Pull down on this lever and open the door. Unplug your washer for 60 seconds and plug your washer back in. If the error re-occurs you need to replace your door lock.
Thank you!!
Jul 18, 2010 | Kenmore HE2 Plus Front Load Washer
I want to unlock my door
Manually Unlocking the Door Lock System
1. Unplug washer or disconnect power. 2. Remove the lower kick panel. 3. Reach up along the inside of the front and locate the bottom of the door switch/lock unit. 4. Located on the bottom of the door switch/lock unit is a tear-drop shaped tab. 5. Gently pull the tab down about a ¼" or until a click is heard. 6. The door may be opened.
Apr 12, 2010 | Kenmore HE2 Plus Front Load Washer
It won;t power up at all, clothes... Solve It won;t power up at all, clothes are locked inside, no lights on the panel. Plug in is working, I... (More) It won;t power up at all, clothes are locked inside,...
This advice is for Kenmore Elite and Whirlpool Duet model front loading washers. If you experience a problem where the door becomes jammed and will not unlock or open, here's an easy way to gain access inside your washer WITHOUT calling the repairman.
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
Sometimes these doors will not unlock for whatever reason. If there are no error codes being generated, this could have just been a momentary glitch. If you see "Fdl" "DLE" or "Fdu" error codes, these are usually indications of a failed door latch assembly and will require replacement.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 04, 2009 | Kenmore HE2 Plus Front Load Washer
It won;t power up at all, clothes are locked inside, no lights on the panel. Plug in is working, I tested the plug in and checked the breakers. I don't know how to get the door to open. Is there a fuse in...
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!
Kenmore HE2 Plus Front Load Washer Logo
1,120 people viewed this question
Sal DeAngelo
fordexpert
 Brian Main
Brian Main
