Question about Dryers
Dryer wont dry
The dryer works fine with the hose off but as soon as we hook the brand NEW hose back on it takes several times to dry. What could be the problem?
    Problem Solver:
  • 16 Answers
If your dyer has the filter on top remove filter ,ck with hand for air flow .this will till u if u have proper air flow
Posted on May 13, 2009
3 month old dryer is not drying, takes two drying cycles to get clothes dry.
Bad airflow to outside. To prove this, remove the hose and dry a load with windows open back and front of house. If they dry fast, you have a blockage in the hose to the wall or in the connector through the wall. Can also get birds nests in there if the flaps are faulty or weak.
Sep 14, 2015 | Dryers
Maytag model #: med5770tq0 won't dry. Please help
Dear Emily.
Several problems.
First, did this dryer ever work properly hooked up as it is?
I mean hooked to the roof event?
If it used to work just fine, then I suspect the vent to the roof is clogged with lint and is not allowing the heat to escape.
If it never did work right,(for example: it is new to us) then I'd venture dryers are not supposed to vent their hot air that far away, they do not have a strong enough blower to push that air that distance.
Then, you might try to find another place to vent the hot air, with a total distance of only 10 feet from the dryer, even if you only vented it while you were actually drying clothers.
I doubt if the last item is for you, but I have sometimes seen where the washing machine did not spin all the water out of the clothes, and then the dryer needed all day to get the clothes dry.
Be blessed.
Apr 17, 2013 | Maytag Dryers
LONG DRYING TIME
Most likely the vent is plugged - check the vent hose (usually start at the outside location & work back to dryer). If hose is not clogged, unplug dryer, remove vent hose from back of dryer and check there.
Aug 02, 2012 | Roper REX4634KQ Electric Dryer
My dryer is a whirlpool electric dryer that was brand new in 1998. The dryer was on, working fine...suddenly it just stopped. It was making a clicking noise. It refused to cut back on when I pushed the...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jun 27, 2011 | Whirlpool GEW9250 Electric Dryer
Whirlpool gas dryer heats but wont dry the clothes
If your
dryer is not drying like it once did or if you just have not taken the time to give yourself a clean dryer in a long time then you need to do that. At least once a year the dryer cleaning should take place. Lint build up in the dryer duct is one of the main causes for your dryer to fail.
Here is the rest of this tip about
Dryer Maintenance
heatman101
Dec 14, 2010 | Whirlpool LGB6300 Gas Dryer
Sometimes dryer will heat right, next time it won't
You more than likely have a buildup of lint in the vent hose. Even what looks like not much lint in there can cause the dryer to have issues drying the clothes. Clear the hose out really well, take it outside and shake it all out, then hook it back up and give it a shot. If that doesnt work you may have a bad thermal fuse which regulates the dryer temperature and you will need to have it replaced.
Dec 14, 2009 | Whirlpool Dryers
Dryer taking a long time to dry. Is it normal for the tube in the back to have water in it? I know water has to go somewhere, is it normal for water to accumulate in the tube/?
Sounds like the Vent hose is blocked.
Turn the Dryer on then go outside and check for air. If it's clogged ... Unplug the unit, take the hose off either at the dryer or outside vent, use something to probe the inside like a hanger , (put a small hook on the end) .. or completly remove the vent hose,take it outside ..see if you can see daylight , if not the unclog it.
BEFORE DOING ANY WORK ...DISCONNECT THE POWER
Oct 04, 2009 | Maytag Neptune MDE4000 Electric Dryer
LG dryer (model DLE3733W) takes forever to dry the clothes.
check your vent hose for a clog. If dryer dont vent clothes wont dry.
Aug 25, 2009 | LG DLE3733 Electric Dryer
Wash machine sometimes gets stuck on rinse cycle & dryer not dry
Sounds like the drain hose for the washer is too far down in the stand pipe at the wall causing a siphon effect, try raising drain hose a little. The dryer sounds like the vent line from back of dryer too wall is pinched causing an air flow obstruction. Hope this helps.
Mar 19, 2009 | Whirlpool Washing Machines
I have a Kenmore Elite HE3 gas dryer. The dryer worked great. And then we moved to a new house. We had to have a gas line installed for the washer and dryer. Ever since we've been in the new house the...
The first thing to do is check the venting from the back of the dryer to the outside of the house including the venthood make sure it is clear. Blocked airflow can increase dry time decrease efficiency.
Dec 30, 2008 | Dryers
Dryers Logo
43 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
