Question about Maytag Performa LAT2500A
The washer wont spin.
My washing machine wont spin. I checked the belt on the bottom and it is good.
  • 181 Answers
It could be the bushes have woren out.
Posted on May 13, 2009
My washer starts of just fine but when going in spin cycle its slow and wont drain belt looks good,its just looks like the motor wont go into high speed
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 06, 2010 | Westinghouse WWS833ES Super Capacity Top...
My washer wont agitate or spin, how do I access the motor assembly to check the belt,clutch, pully ect..?
you just remove the bottom cover of the washing machine, then you can see the assembly of motor, belt and pully. check that among these parts are damaged, jammed or not. If everything is normal there is the possibility of damage to the electrical circuit. there is no power to the motor.
Aug 04, 2010 | General Electric WHDSR209DWW Top Load...
Wont spin
Yes you will find a belt under the bottom of the machine. Check out first that it did not just over balance and cut out while spinning if so you will need to hit the reset buttonand check out spin cycle. Hope this helps
May 25, 2010 | GE WDSR2080D Top Load Washer
Washing machine wont spin in spin cycle ,makes spinning sound just wont spin
It doesn't spin If your washer won't spin, check these: It doesn't pump or spin It pumps, but doesn't spin It spins only with the lid closed It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows: If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt. If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Jan 01, 2010 | Washing Machines
Washer wont spin
warning disconect machine before you work in it check under machine there is small white plastic is located in the motor is broken becarefull dont touch any electical parts or your machine belt might be broken too i recomen u use gloves good luck
Nov 05, 2009 | GE WSXH208A Front Load Washer
WASHING MACHINE DOES NOT SPIN
Remove the front cover (two bolts at bottom) and check the belt "ALL THE WAY AROUND"
Good Luck, Quentin
Oct 11, 2009 | Frigidaire FEX831CS Top Load Stacked...
Washer stopeed spinning
if machine spins while washing, transmission is good. if it does not turn at all, could be control panel .need more details
Aug 31, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My washer wont spin it shows an error e 13.
  • If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
  • If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these:
  • The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
  • The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
  • A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
  • The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
  • The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
  • The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
  • The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
It spins only with the lid closed For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
Thank you for contacting Fixya.com
Aug 19, 2009 | Bosch Nexxt 300 Series WFMC2201UC
Washer wont spin
check belt under the machine.maybe the pump or another pulley is locking up.turn your pulleys by hand to see how much tension is their.you may just need a belt
Mar 06, 2009 | Frigidaire FWS833A Top Load Washer
Kenmore washer 80 series 110 model not spinning.
unless your washer is over 20 years old, then it wont have a belt. the temperature of the water wont have anything to do with it spinning or not.
need to know if it agitates or drains and just wont spin.
if it agitates but no spin or drain, then you have a bad lid switch.
if it wont agitate or spin, but will drain, then you have a broken drive coupling.
Jan 08, 2009 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
140 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
