Question about Kenmore 73952 Gas Dryer
Kenmore gas dryer no heat
Kenmore gas dryer model # 110.73952102. Machine work fine, air flow good but no heat output. Do you think because of the ignitor problem ?try to locate the ignitor. Thanks Steven
  • Anonymous May 14, 2009
    I replaced the ignitor.
    burner kicks on and run for 5 to 10 minutes then burner kicks off and I have to restart it over again to get the burner to kick back on.
    I repeat it couple of time now the burner not work at all.
    What do you think is the problem?
  • 460 Answers
Hi Steven  I hope this help U to fixya your dryer's problem
http://repair2000.com/norun.html
Was this helpful?
Posted on May 13, 2009
Kenmore elete model 110.67032600 timer changes to higher # and takes a long time to dry on auto dry.
I had this and it was lint trapped in door below lint filter screen.( several handfulls) Took door apart/ reassembled and he worked fine.
Oct 07, 2015 | Kenmore Dryers
Where to find fuses. My dryer is not heating up.
Does your dryer have power? If yes, then check (1) the flow of air outside the house from your dryer tube and (2) your circuit breaker panel for each circuit in the house (I've not seen fuses/breakers built into dryers -- though that could change). Then check (3) your heating element, (4) thermostat, (5) high-temp thermal cutoff switch, and (6) for debris in the air flow path to / from from the centrifugal fan.
Here are 3 resources that helped me with my Kenmore Series 90 Dryer:
No Heat? - http://chris-doityourselfrepair.blogspot.com/2011/10/kenmore-90-series-model-110-clothes.html
Looking Inside My Dryer - http://chris-doityourselfrepair.blogspot.com/search/label/Disassembling%20Kenmore%20Dryer%2090%20Series
Exterior Exhaust Duct - http://chris-doityourselfrepair.blogspot.com/2013/08/cleaning-out-and-replacing-exhaust-duct.html
Oct 10, 2014 | Kenmore Dryers
Kenmore Gas Dryer Serial Number: MF3920158
there is a heater on the back wall of the machine left hand corner there are also two relays on that same back wall and one on the blower you have to be able to take a wire off each relay and with a multimeter check each part for continuity if t hese are all good then do the same test on your heater. hope this helps
May 01, 2010 | Kenmore 73952 Gas Dryer
Dryer won't Heat up - Kenmore Elite HE4 Gas Dryer
hi..A poor connection between the wire terminals and the
heater relay causes high current draw and damages the
terminals on the heater relay on the main control board.
check it out..
thank u..
kindly rate my response..
Jun 09, 2009 | Kenmore Elite HE4 Electric Dryer
No Heat on Kenmore Gas Dryer Model 417
Hi, You need to change the coils on the top of the gas valve. This is a very common problem with the newer gas dryers. We have them for $29.95 on out web site www.whilpoolpartssurplus.com
If I can assist you further, please let me know.
Thanks
Vic
May 18, 2009 | Kenmore 98702 Stacked Washer/Dryer
Kenmore gas dryer, no heat
Your dryer lint vent pipe out the back of the machine or maybe out the side is partially plugged. You have to pull the machine out and clear that pipe or rebuild it out to a soffit vent or static vent if it is in the attic, or out through your crawl space. This will make a huge difference. If that hot air and moisture doesn't get out of the machine it just goes back into your clothes.
Good luck!!
Mar 25, 2009 | Kenmore Dryers
Kenmore dryer will not heat
this problem is almost always an airflow problem, check everywhere the air flows including inside the drum to inside the wall.
it is very rare that the thermo switches will cause this problem, but it is possible.
May 15, 2008 | Kenmore 63942 Dryer
Kenmore 73952 Gas Dryer Logo
356 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
