Question about Cobra 29 LTD CB Radio
Cobra 29 LTD. R56 smoked. I replaced it and it emediatly smoked again! I feel like I've read about this problem before. I'm thinking it was a problem with one of the capacitors or the final. Can someone suggest a plan of attack? Also I forgot the value of R56. I think 23ohms but not sure. Any help would be greatly appreciated! Thanks!
  • ittookashit May 13, 2009
    Thanks Benimur. I have a replacement final on hand. I have no idea how to test the final to see if it's shorted. Could you tell me how to test it with my meter? Also the final I have on hand is used and not sure if it's any good. Knowing how to test would be awesome.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
R56 is 22 ohms. Possibly the finals shorted TR14, 2SC2029. Better check R123 (1 ohm) also.
Here is the schematics should you have a need for it.
Good luck and thank you for using FixYa.
Posted on May 12, 2009
  • Louie  Role
    Louie Role May 13, 2009
    As explained here, procedures are as follows:
    • With
      the meter set to measure
      ohms, clip one meter
      lead to the base
      connection of the
      transistor.
    • Touch
      the other lead first
      onto the collector lead
      and then onto the
      emitter lead.
    • The readings should both
      be the same, either both
      high resistance or both
      low resistance.
    • Now reverse the leads
      and repeat the
      procedure.
      The results should be
      the opposite of those
      obtained before.
      If they were both high
      before they should now
      be both low.
      If they were both low
      both be high.
    • Now measure the
      resistance between
      emitter and collector.
      It should read high
      resistance in both
      directions.
Lx29 blue tut. Locked in 9/10 mode. How do I reset it?
PDF]EIi?tr,iitts - American Radio History
www.americanradiohistory.com/Archive-Radio.../90s/.../EN-1993-11.pdf
Nov 5, 1993 - 64 AUTOPATCH SELECTOR FOR RADIO AMATEURS ..... Memorymodes can store readings while ..... est way to do it is to base the circuit .... width (with increasing values of CB), .... Electronics Engineers' Book Club, Blue Ridge Summit, PA 17294- ...... lock onto the 19 -kHz pilot sub- ...... manually reset.using fgets to read one line at a time - Experts Exchange www.experts-exchange.com > Questions
Nov 11, 2008 - 1: 2: 3: 4: 5: 6: 7: 8: 9: 10: 11: 12: 13: 14: 15: 16: 17: 18: 19: 20: 21: 22: 23: ..... helium viceroy Audrey Isaac provision grammar cobra adrift died Liverpool .....wriggle do carbuncle firebug Elsinore Connally annotate anaconda could ..... pretend quadratic Euphrates RCA amuse CB
Cobra 29 LTD Classic CB Radio - YouTube? 5:42https://www.youtube.com/watch?v=vJle8vlsWLcAug 20, 2013 - Uploaded by C B WorldIn this product review we look at the Cobra 29 LTD Classic CB radio and ... Just like in the manual. most channels are below 3. a few are not.Cobra 29 LTD Classic Troubleshooting - iFixithttps://www.ifixit.com/.../Cobra_29_LTD_Classic_TroubleshootingiFixitCobra 29 LTD Classic is not transmitting or receiving. The Antenna is not tuned correctly; The Radio is not in CB mode; The Radio is on the wrong channel; The ...Marine Radios ' Cobra Electronics Corporation
Jan 07, 2016 | Cobra Radio Communications
How to change RF meter lite in cobra LTD 29 radio
It's a small bulb . There is a number on it. You may have to get a magnifying glass to read it. It is soldered in so removal will require a soldering iron of a low wattage.
Jun 20, 2015 | Cobra 29-LTD 29 LTD Classic CB Radio
Cobra 29 ltd. turned rv4 switch and cb started smoking. what is the cause of this
if this is a used radio its because some golden screwdriver got into it but if its a new one then its the radio.Check the reverse polarity diode in either case to see if its burnt. If so replace it and see if it happens again.
Oct 18, 2013 | Cobra 29 LTD CB Radio
Cobra 29 LTD LX LE vr pots
vr1 "s" 9 setting on the tx meter vr2 voltage setting vr3 squelch vr4 amc vr5 p4 display on tx signal meter.
Mar 22, 2013 | Cobra 29 LTD CB Radio
Cobra 29 ltd chrome quit transmiting still have pa and talk back changed driver and final still nothing any ideas
Have you check your voltage regulator. 2 outer legs should read 13 volts middle 9 volt. Around and about.
Nov 15, 2009 | Cobra 29 LTD CB Radio
Cobra 29 ltd (1993)
Looking at the schematic TR23 colector ties in with
the power switch ,check D22 it's a 9.1 to 10 volt
zener diode also check C11 an D21.
TR23 shows to be a 2SC1096 I would go ahead and
replace it.Be sure that the CB-PA switch is in good
working order;
Good luck maybe this helped.
Sep 03, 2009 | Cobra 29 LTD CB Radio
Cobra 29 nw ltd won't transmit
Have you cracked the radio open yet?  check for loose connections etc.  get back to me if that doesnt yeild any results
Dec 23, 2008 | Cobra 29 LTD CB Radio
My Cobra 29 ltd classic
Hello MyPete,
You have some form of short circuit in your CB, most likley I would suspect the Power supply or the RF Power Output Amplifier. Here are some basic instruction on how to tell wher the smoke is coming from.
1) disconnect and remove your CB from your vehicle and put it on a workbench
2) remove the cover from your CB and expose the circuit board to view
3) connect your CB to an external 12 volt power source and antenna or a dummy load
4) power up the CB and determine where the smoke is coming from then turn off the power supply to the CB
5) At this point you will need a schematic of your CB (get one from www.servicemanuals.com)
6) find the point on the schematic that relates to the point where the smoke is coming from
7) using a ohmmeter determine which component and or components are shorted
8) replace the shorted and or malfunctioning components.
9) test the system (power on, transmit and receive)
10) close the unit back up
11) reinstall into vehicle
12) run tests again.
This should help
Thank you
Shutle832
Nov 01, 2008 | Cobra 29 LTD CB Radio
Shorts my power supply when plugged in
do you have boots powering up the signal that can do it
Sep 27, 2008 | Cobra 29 LTD CB Radio
Cobra 29 ltd nw classic
Yes, Do Not Turn Up Too 500's Way Too Dangerous, The Problem Might Be That Inside Some Cords May Be Rubbing Wrong Or, You Have A Short Cord, If Not Any Of That It Is Probally Broke
Aug 07, 2008 | Cobra 29 WX NW ST 40-Channels Base CB...
Cobra 29 LTD CB Radio Logo
388 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
